ghostintranslation
About a year ago I posted here to show the very first version of my work.
Now I have a pretty stable platform, but I'd like to hear any ideas how to improve quality of the electronics, or even the concept itself.
The platform I made is in the Eurorack physical format, but it uses midi which is connected on the back of the modules to avoid the classic Eurorack spaghetti.
I have made 3 versions of what I call Motherboards, the bases of any modules: Motherboard6 has 6 controls, Motherboard9 has 9 controls, and Motherboard12 has 12 controls.
But it's not that simple, the PCBs allow to solder either a potentiometer, or a rotary encoder, or a push button for each control. The PCB is modular itself basically.
That means it's meant to handle all these types of inputs and it gives the ability to reuse the same PCB to build different modules, then it's just a matter of making a front panel.
To be able to use the Audio Board, that means a very limited number of inputs are available on Teensy. And I had to deal with a lot of inputs, up to 12 controls but because I allow for rotary encoders that means 12 * 3 = 36 inputs, and also some analog some not, and also a dipswitch to select a MIDI channel, and up to 12 LEDs. So in order to deal with all of these I use multiplexers all connected to 1 main multiplexer. That means on Teensy there is only 1 pin receiving inputs and outputing for the LEDs, and luckily it switches fast enough. I also use a matrix to reduce the number of multiplexers required.
On the code side, because the 3 are very similar, I made a class that is almost identical for each of them which handles the inputs and outputs and abstracts all the low level work. Then when I want to make a new module I don't have to think again about how to get the value of the rotary encoder number 3 basically, I can just get its value and handle the logic of the module instead. That makes making modules very easy.
With that flexibility I have made a few modules already.
They communicate via midi, which is directly connected to the Teensy serial in and out. Which I know means in case I want to connect something else than Teensy I have to be careful of the power applied to the pin.
See the schematics and code of the 3 Motherboards here:
https://github.com/ghostintranslation/motherboard6
https://github.com/ghostintranslation/motherboard9
https://github.com/ghostintranslation/motherboard12
And the modules I made based on these 3 Motherboards:
https://github.com/ghostintranslation/synth
https://github.com/ghostintranslation/drone
https://github.com/ghostintranslation/ds909
https://github.com/ghostintranslation/psyc03
https://github.com/ghostintranslation/cycle
https://github.com/ghostintranslation/byte
You can see photos in those GitHub links too to have an idea of what it looks like, if you want to see videos I would suggest you to look at my Instagram:
https://www.instagram.com/ghostintranslation
So far I used only through hole components to keep it simple so people with not too much soldering practice can try it, and they did I got some good feedback so far.
But in the next big version increment I think I'll embrace fully SMD to be able to use chips like the Cirrus Logic CS42448 to add 8 audio outputs, and the PCA9685 to handle the LEDs, and 16:1 multiplexers to keep it small.
In the future version I also plan on adding an optocoupler for the MIDI In.
So if you have any ideas, or comments... if you see something bad in the schematics, tell me
