TimRedfern
I'm trying to use i2c with teensy 4.1 and running into some problems.
I'm trying to write data in master mode. I'm seeing the same problem with the master_writer sample for Teensy 4.1 that ships with Teensyduino, and my code.
I'm not what the status is of support for the Wire library for the newest Teensy as this page is the only info I can find about compatibility and does not mention Teensy 4.x: https://www.pjrc.com/teensy/td_libs.html
When I upload the master_writer sample, and monitor pins 18 and 19, I see the i2c address being transmitted, but no data is being written.
Expected result: The i2c address would be written, then a number of bytes of data ("x is 1"). The clock signal should transmit 64 or more pulses.
Actual result: Just the i2c address is written. The clock only transmits 8 pulses.
Has anyone had any success using i2c with Teensy 4.x, or can comment about the status of i2c support from the Teensyduino libraries?
Thanks in advance.
Tim
Thanks in advance.
Tim
