manicksan
I don't really understand how digitalWriteFast should make it faster,
it's fast for the first set of pins
but for pin 54 it have to go through all the first 0-53 pins so there is a shift in time which pin you use,
in VHDL it's another matter because there everything "executes" at the same time.
but in the original
it uses a big lockup table which "generates" the same timing for each pin
its very messy but a similar structure could be used for the fast variants?
/jannik
static inline void digitalWriteFast(uint8_t pin, uint8_t val)
if (__builtin_constant_p(pin)) {
if (val) {
if (pin == 0) {
CORE_PIN0_PORTSET = CORE_PIN0_BITMASK;
} else if (pin == 1) {
CORE_PIN1_PORTSET = CORE_PIN1_BITMASK;
} else if (pin == 2) {
CORE_PIN2_PORTSET = CORE_PIN2_BITMASK;
} else if (pin == 3) {
CORE_PIN3_PORTSET = CORE_PIN3_BITMASK;
} else if (pin == 4) {
CORE_PIN4_PORTSET = CORE_PIN4_BITMASK;
} else if (pin == 5) {
CORE_PIN5_PORTSET = CORE_PIN5_BITMASK;
} else if (pin == 6) {
CORE_PIN6_PORTSET = CORE_PIN6_BITMASK;
} else if (pin == 7) {
CORE_PIN7_PORTSET = CORE_PIN7_BITMASK;
} else if (pin == 8) {
CORE_PIN8_PORTSET = CORE_PIN8_BITMASK;
} else if (pin == 9) {
CORE_PIN9_PORTSET = CORE_PIN9_BITMASK;
} else if (pin == 10) {
CORE_PIN10_PORTSET = CORE_PIN10_BITMASK;
} else if (pin == 11) {
CORE_PIN11_PORTSET = CORE_PIN11_BITMASK;
} else if (pin == 12) {
CORE_PIN12_PORTSET = CORE_PIN12_BITMASK;
} else if (pin == 13) {
CORE_PIN13_PORTSET = CORE_PIN13_BITMASK;
} else if (pin == 14) {
CORE_PIN14_PORTSET = CORE_PIN14_BITMASK;
} else if (pin == 15) {
CORE_PIN15_PORTSET = CORE_PIN15_BITMASK;
} else if (pin == 16) {
CORE_PIN16_PORTSET = CORE_PIN16_BITMASK;
} else if (pin == 17) {
CORE_PIN17_PORTSET = CORE_PIN17_BITMASK;
} else if (pin == 18) {
CORE_PIN18_PORTSET = CORE_PIN18_BITMASK;
} else if (pin == 19) {
CORE_PIN19_PORTSET = CORE_PIN19_BITMASK;
} else if (pin == 20) {
CORE_PIN20_PORTSET = CORE_PIN20_BITMASK;
} else if (pin == 21) {
CORE_PIN21_PORTSET = CORE_PIN21_BITMASK;
} else if (pin == 22) {
CORE_PIN22_PORTSET = CORE_PIN22_BITMASK;
} else if (pin == 23) {
CORE_PIN23_PORTSET = CORE_PIN23_BITMASK;
} else if (pin == 24) {
CORE_PIN24_PORTSET = CORE_PIN24_BITMASK;
} else if (pin == 25) {
CORE_PIN25_PORTSET = CORE_PIN25_BITMASK;
} else if (pin == 26) {
CORE_PIN26_PORTSET = CORE_PIN26_BITMASK;
} else if (pin == 27) {
CORE_PIN27_PORTSET = CORE_PIN27_BITMASK;
} else if (pin == 28) {
CORE_PIN28_PORTSET = CORE_PIN28_BITMASK;
} else if (pin == 29) {
CORE_PIN29_PORTSET = CORE_PIN29_BITMASK;
} else if (pin == 30) {
CORE_PIN30_PORTSET = CORE_PIN30_BITMASK;
} else if (pin == 31) {
CORE_PIN31_PORTSET = CORE_PIN31_BITMASK;
} else if (pin == 32) {
CORE_PIN32_PORTSET = CORE_PIN32_BITMASK;
} else if (pin == 33) {
CORE_PIN33_PORTSET = CORE_PIN33_BITMASK;
} else if (pin == 34) {
CORE_PIN34_PORTSET = CORE_PIN34_BITMASK;
} else if (pin == 35) {
CORE_PIN35_PORTSET = CORE_PIN35_BITMASK;
} else if (pin == 36) {
CORE_PIN36_PORTSET = CORE_PIN36_BITMASK;
} else if (pin == 37) {
CORE_PIN37_PORTSET = CORE_PIN37_BITMASK;
} else if (pin == 38) {
CORE_PIN38_PORTSET = CORE_PIN38_BITMASK;
} else if (pin == 39) {
CORE_PIN39_PORTSET = CORE_PIN39_BITMASK;
#if CORE_NUM_DIGITAL >= 55
} else if (pin == 40) {
CORE_PIN40_PORTSET = CORE_PIN40_BITMASK;
} else if (pin == 41) {
CORE_PIN41_PORTSET = CORE_PIN41_BITMASK;
} else if (pin == 42) {
CORE_PIN42_PORTSET = CORE_PIN42_BITMASK;
} else if (pin == 43) {
CORE_PIN43_PORTSET = CORE_PIN43_BITMASK;
} else if (pin == 44) {
CORE_PIN44_PORTSET = CORE_PIN44_BITMASK;
} else if (pin == 45) {
CORE_PIN45_PORTSET = CORE_PIN45_BITMASK;
} else if (pin == 46) {
CORE_PIN46_PORTSET = CORE_PIN46_BITMASK;
} else if (pin == 47) {
CORE_PIN47_PORTSET = CORE_PIN47_BITMASK;
} else if (pin == 48) {
CORE_PIN48_PORTSET = CORE_PIN48_BITMASK;
} else if (pin == 49) {
CORE_PIN49_PORTSET = CORE_PIN49_BITMASK;
} else if (pin == 50) {
CORE_PIN50_PORTSET = CORE_PIN50_BITMASK;
} else if (pin == 51) {
CORE_PIN51_PORTSET = CORE_PIN51_BITMASK;
} else if (pin == 52) {
CORE_PIN52_PORTSET = CORE_PIN52_BITMASK;
} else if (pin == 53) {
CORE_PIN53_PORTSET = CORE_PIN53_BITMASK;
} else if (pin == 54) {
CORE_PIN54_PORTSET = CORE_PIN54_BITMASK;
but in the original
void digitalWrite(uint8_t pin, uint8_t val)
const struct digital_pin_bitband_and_config_table_struct *p;
uint32_t pinmode, mask;
if (pin >= CORE_NUM_DIGITAL) return;
p = digital_pin_to_info_PGM + pin;
pinmode = *(p->reg + 1);
mask = p->mask;
if (pinmode & mask) {
// pin is configured for output mode
if (val) {
*(p->reg + 0x21) = mask; // set register
*(p->reg + 0x22) = mask; // clear register
// pin is configured for input mode
// value controls PULLUP/PULLDOWN resistors
if (val) {
*(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3) | IOMUXC_PAD_HYS;
*(p->pad) = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(0) | IOMUXC_PAD_HYS;
/jannik
