Soft reset not working on Ubuntu 20.04 LTS - Please help
I have been stumped on this issue for quite a while now. It seems that line 337 in teensy_loader_cli.c throwing an error when opening USB device
https://github.com/PaulStoffregen/te...y_loader_cli.c
serial_handle = open_usb_device(0x16C0, 0x0483);
Example output:
root@ubuntu:/home/ubuntu/teensy_loader_cli# ./teensy_loader_cli --mcu=TEENSY41 /home/ubuntu/firmware.hex -v -s
Teensy Loader, Command Line, Version 2.2
Read "/home/ubuntu/firmware.hex": 355478 bytes, 4.4% usage
Error opening USB device: No error
Waiting for Teensy device...
(hint: press the reset button)
The only way I seem to be able to remotely upload my code is by pressing the button on the teensy, but this is not viable for my situation. I know that there is a workaround if using raspbian which I have used before
SERIAL_TEENSY_DEVICE=find /dev/serial/by-id/ -name "usb-Teensyduino*";
echo "-> Performing soft resset (baud = 134 hack). $SERIAL_TEENSY_DEVICE";
lsusb | grep Teensy;
stty -F $SERIAL_TEENSY_DEVICE 9600
sleep 1;
stty -F $SERIAL_TEENSY_DEVICE 134
sleep 1;
echo "-> Should be ready to program...";
sudo ./teensy_loader_cli --mcu=imxrt1062 -v -w TEENSY4_CODE.hex
But I really need to get this command working on Ubuntu 20.04. Is there anything anyone can do to please help me out ? Does anyone know of any other workarounds I could use ?
Thanks,
Dan
- You may not post replies
- You may not edit your posts
Forum Rules
