Results 1 to 5 of 5
Thread: Soft reset not working on Ubuntu 20.04 LTS - Please help
    Dec 2020
    2
    I have been stumped on this issue for quite a while now. It seems that line 337 in teensy_loader_cli.c throwing an error when opening USB device
    https://github.com/PaulStoffregen/te...y_loader_cli.c
    serial_handle = open_usb_device(0x16C0, 0x0483);
    Example output:
    root@ubuntu:/home/ubuntu/teensy_loader_cli# ./teensy_loader_cli --mcu=TEENSY41 /home/ubuntu/firmware.hex -v -s
    Teensy Loader, Command Line, Version 2.2
    Read "/home/ubuntu/firmware.hex": 355478 bytes, 4.4% usage
    Error opening USB device: No error
    Waiting for Teensy device...
    (hint: press the reset button)
    The only way I seem to be able to remotely upload my code is by pressing the button on the teensy, but this is not viable for my situation. I know that there is a workaround if using raspbian which I have used before
    SERIAL_TEENSY_DEVICE=find /dev/serial/by-id/ -name "usb-Teensyduino*";
    echo "-> Performing soft resset (baud = 134 hack). $SERIAL_TEENSY_DEVICE";
    lsusb | grep Teensy;
    stty -F $SERIAL_TEENSY_DEVICE 9600
    sleep 1;
    stty -F $SERIAL_TEENSY_DEVICE 134
    sleep 1;
    echo "-> Should be ready to program...";
    sudo ./teensy_loader_cli --mcu=imxrt1062 -v -w TEENSY4_CODE.hex
    But I really need to get this command working on Ubuntu 20.04. Is there anything anyone can do to please help me out ? Does anyone know of any other workarounds I could use ?
    Thanks,
    Dan
    Oct 2019
    Calgary
    99
    You could try replacing these lines 344 and 345 in teensy_loader_cli.c
    	char reboot_command = 134;
    	int response = usb_control_msg(serial_handle, 0x21, 0x20, 0, 0, &reboot_command, 1, 10000);
    with these
    	char reboot_command[] = {0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08};
    	int response = usb_control_msg(serial_handle, 0x21, 0x20, 0, 0, reboot_command, sizeof reboot_command, 10000);
    and seeing if it makes a difference. That's what I've done in Raspbian to get the soft reboot to work with my Teensy 4.x's. Now, granted, under Raspbian the unaltered code got past the open_usb_device() call that you say you're getting caught on, and then died with a broken pipe error on the usb_control_msg() call. Still, it's easy enough to try and see if it makes a difference in your situation.
    23,977
    There's no error about *why* open_usb_device() failed to open the device. All the cases where it finds a matching device print errors. The absence of such an error suggests teensy_loader_cli isn't finding a matching device to open.
    So your first step is to just run "lsusb" and check whether you really do have a Teensy detected with ID numbers 0x16C0, 0x0483. If Teensy isn't on the list of usb devices, then something is wrong that can't be fixed by teensy_loader_cli.
    If you do see 16C0:0483 with lsusb, then the big question is why would teensy_loader_cli not try to open it. I'd recomment uncommenting this:
    	//printf_verbose("\nSearching for USB device:\n");
    	for (bus = usb_get_busses(); bus; bus = bus->next) {
    		for (dev = bus->devices; dev; dev = dev->next) {
    			//printf_verbose("bus \"%s\", device \"%s\" vid=%04X, pid=%04X\n",
    			//	bus->dirname, dev->filename,
    			//	dev->descriptor.idVendor,
    			//	dev->descriptor.idProduct
    Then compare the list of devices it prints to the list you get from running "lsusb" or "lsusb -t".
    Dec 2020
    2
    Thanks for the replies guys. Today I setup a fresh raspberry pi installation with Ubuntu 20.04 and was able to get everything working properly with Silverlocks code change suggestion (thank you!).
    What I suspect might be the cause of the USB error is that the teensy4.1 may not have been plugged into the raspberry pi correctly. This is something I have no visibility of as the device is remote. I will be able to test again with the remote device tomorrow to hopefully confirm.
    Oct 2019
    Calgary
    99
    Good to hear that you've got it working.
