philip.porhammer
Adafruit_NeoPixel seems to be limited to 110 LEDs in the string.
the clock is 60 LEDS in the outer ring and 48 in the inner ring and 12 markers. is there a quick mod to this to fix this?
my setup:
my setup:
#include <SparkFunDS3234RTC.h>
#define DS13074_CS_PIN 10 // DeadOn RTC Chip-select pin
#include <Adafruit_NeoPixel.h>
#define PIN 1 // led serial
#define NUMPIXELS 120
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_RGB + NEO_KHZ800);
This file is part of the Adafruit NeoPixel library.
NeoPixel is free software: you can redistribute it and/or modify
it under the terms of the GNU Lesser General Public License as
published by the Free Software Foundation, either version 3 of
the License, or (at your option) any later version.
NeoPixel is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with NeoPixel. If not, see
<http://www.gnu.org/licenses/>.
#ifndef ADAFRUIT_NEOPIXEL_H
#define ADAFRUIT_NEOPIXEL_H
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#include <pins_arduino.h>
// The order of primary colors in the NeoPixel data stream can vary
// among device types, manufacturers and even different revisions of
// the same item. The third parameter to the Adafruit_NeoPixel
// constructor encodes the per-pixel byte offsets of the red, green
// and blue primaries (plus white, if present) in the data stream --
// the following #defines provide an easier-to-use named version for
// each permutation. e.g. NEO_GRB indicates a NeoPixel-compatible
// device expecting three bytes per pixel, with the first byte
// containing the green value, second containing red and third
// containing blue. The in-memory representation of a chain of
// NeoPixels is the same as the data-stream order; no re-ordering of
// bytes is required when issuing data to the chain.
// Bits 5,4 of this value are the offset (0-3) from the first byte of
// a pixel to the location of the red color byte. Bits 3,2 are the
// green offset and 1,0 are the blue offset. If it is an RGBW-type
// device (supporting a white primary in addition to R,G,B), bits 7,6
// are the offset to the white byte...otherwise, bits 7,6 are set to
// the same value as 5,4 (red) to indicate an RGB (not RGBW) device.
// i.e. binary representation:
// 0bWWRRGGBB for RGBW devices
// 0bRRRRGGBB for RGB
// RGB NeoPixel permutations; white and red offsets are always same
// Offset: W R G B
#define NEO_RGB ((0 << 6) | (0 << 4) | (1 << 2) | (2))
#define NEO_RBG ((0 << 6) | (0 << 4) | (2 << 2) | (1))
#define NEO_GRB ((1 << 6) | (1 << 4) | (0 << 2) | (2))
#define NEO_GBR ((2 << 6) | (2 << 4) | (0 << 2) | (1))
#define NEO_BRG ((1 << 6) | (1 << 4) | (2 << 2) | (0))
#define NEO_BGR ((2 << 6) | (2 << 4) | (1 << 2) | (0))
// RGBW NeoPixel permutations; all 4 offsets are distinct
// Offset: W R G B
#define NEO_WRGB ((0 << 6) | (1 << 4) | (2 << 2) | (3))
#define NEO_WRBG ((0 << 6) | (1 << 4) | (3 << 2) | (2))
#define NEO_WGRB ((0 << 6) | (2 << 4) | (1 << 2) | (3))
#define NEO_WGBR ((0 << 6) | (3 << 4) | (1 << 2) | (2))
#define NEO_WBRG ((0 << 6) | (2 << 4) | (3 << 2) | (1))
#define NEO_WBGR ((0 << 6) | (3 << 4) | (2 << 2) | (1))
#define NEO_RWGB ((1 << 6) | (0 << 4) | (2 << 2) | (3))
#define NEO_RWBG ((1 << 6) | (0 << 4) | (3 << 2) | (2))
#define NEO_RGWB ((2 << 6) | (0 << 4) | (1 << 2) | (3))
#define NEO_RGBW ((3 << 6) | (0 << 4) | (1 << 2) | (2))
#define NEO_RBWG ((2 << 6) | (0 << 4) | (3 << 2) | (1))
#define NEO_RBGW ((3 << 6) | (0 << 4) | (2 << 2) | (1))
#define NEO_GWRB ((1 << 6) | (2 << 4) | (0 << 2) | (3))
#define NEO_GWBR ((1 << 6) | (3 << 4) | (0 << 2) | (2))
#define NEO_GRWB ((2 << 6) | (1 << 4) | (0 << 2) | (3))
#define NEO_GRBW ((3 << 6) | (1 << 4) | (0 << 2) | (2))
#define NEO_GBWR ((2 << 6) | (3 << 4) | (0 << 2) | (1))
#define NEO_GBRW ((3 << 6) | (2 << 4) | (0 << 2) | (1))
#define NEO_BWRG ((1 << 6) | (2 << 4) | (3 << 2) | (0))
#define NEO_BWGR ((1 << 6) | (3 << 4) | (2 << 2) | (0))
#define NEO_BRWG ((2 << 6) | (1 << 4) | (3 << 2) | (0))
#define NEO_BRGW ((3 << 6) | (1 << 4) | (2 << 2) | (0))
#define NEO_BGWR ((2 << 6) | (3 << 4) | (1 << 2) | (0))
#define NEO_BGRW ((3 << 6) | (2 << 4) | (1 << 2) | (0))
// Add NEO_KHZ400 to the color order value to indicate a 400 KHz
// device. All but the earliest v1 NeoPixels expect an 800 KHz data
// stream, this is the default if unspecified. Because flash space
// is very limited on ATtiny devices (e.g. Trinket, Gemma), v1
// NeoPixels aren't handled by default on those chips, though it can
// be enabled by removing the ifndef/endif below -- but code will be
// bigger. Conversely, can disable the NEO_KHZ400 line on other MCUs
// to remove v1 support and save a little space.
#define NEO_KHZ800 0x0000 // 800 KHz datastream
#ifndef __AVR_ATtiny85__
#define NEO_KHZ400 0x0100 // 400 KHz datastream
// If 400 KHz support is enabled, the third parameter to the constructor
// requires a 16-bit value (in order to select 400 vs 800 KHz speed).
// If only 800 KHz is enabled (as is default on ATtiny), an 8-bit value
// is sufficient to encode pixel color order, saving some space.
#ifdef NEO_KHZ400
typedef uint16_t neoPixelType;
#else
typedef uint8_t neoPixelType;
class Adafruit_NeoPixel {
public:
// Constructor: number of LEDs, pin number, LED type
Adafruit_NeoPixel(uint16_t n, uint8_t p=6, neoPixelType t=NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel(void);
~Adafruit_NeoPixel();
void
begin(void),
show(void),
setPin(uint8_t p),
setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b),
setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b, uint8_t w),
setPixelColor(uint16_t n, uint32_t c),
setBrightness(uint8_t),
clear(),
updateLength(uint16_t n),
updateType(neoPixelType t);
uint8_t
*getPixels(void) const,
getBrightness(void) const;
uint16_t
numPixels(void) const;
static uint32_t
Color(uint8_t r, uint8_t g, uint8_t b),
Color(uint8_t r, uint8_t g, uint8_t b, uint8_t w);
uint32_t
getPixelColor(uint16_t n) const;
inline bool
canShow(void) { return (micros() - endTime) >= 50L; }
private:
boolean
#ifdef NEO_KHZ400 // If 400 KHz NeoPixel support enabled...
is800KHz, // ...true if 800 KHz pixels
begun; // true if begin() previously called
uint16_t
numLEDs, // Number of RGB LEDs in strip
numBytes; // Size of 'pixels' buffer below (3 or 4 bytes/pixel)
int8_t
pin; // Output pin number (-1 if not yet set)
uint8_t
brightness,
*pixels, // Holds LED color values (3 or 4 bytes each)
rOffset, // Index of red byte within each 3- or 4-byte pixel
gOffset, // Index of green byte
bOffset, // Index of blue byte
wOffset; // Index of white byte (same as rOffset if no white)
uint32_t
endTime; // Latch timing reference
#ifdef __AVR__
volatile uint8_t
*port; // Output PORT register
uint8_t
pinMask; // Output PORT bitmask
#endif // ADAFRUIT_NEOPIXEL_H
