I did a search and it's still not quite clear. On ALL the most recent Teensy boards (I have 3.6 and 4.1) if you have external power and want to connect USB for programming you have to cut the power either in the cable or on the board between pads?
If YES then the power must be hooked up in serial no? If so connecting both would result in 10v power? But looking at the schematics it looks to me that the power is connected in parallel. If that is so then why does the power need to be seperated?
I'm using my Teensy for controlling many 5v LED strips with logic converters. Lots of long strips so I have a 40 watt external power supply.
