I am making an addon pcb for the teensy 4.1 which will need to passthrough the 48 outer teensy pins along with the 6 ethernet pins. I will use two of the 24x1 Sockets on the pjrc store to pass through the teensy pins but I am still searching for which components I should use (pins + socket) for the ethernet. Has anyone made a board in which the teensy is plugged in to a socket which also has a socket for the ethernet pins to be passed through? If anyone has experience or suggestions it would be greatly appreciated!
