Art-Net to DMX Emulator
TexasHeat
Hi Folks,
Pretty new to Teensy/Arduino and programming in general. I am looking to build an ethernet to DMX node, similar to the Enttec ODE or DMXKing eDMX1. I already have a Teensy 4.1 and I have an ethernet board and a Max485 to TTL board on order from Amazon.
https://www.amazon.com/gp/product/B07B667STP/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B08CTM1L64/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I play bass in a band and want to use my iPad to control the DMX RGB par lights from the stage. I want to use Vibrio (supports ArtNet) in the iPad, wifi to a router, then LAN to the Teensy and out to the DMX par lights with the 3-pin XLR connectors; 3 or 4 channels per light. Since I'm already using my iPad for lyrics and sound, I want to use it for lights as well. I am not keen on taking my laptop to gigs, plus it will be one less thing to go wrong.
Over the summer I built a midi to usb controller using a teensy 3.2. It sends triggers to my laptop where QLC+ is running which then goes out to the lights using a Lixada USB to DMX adaptor. I got most of the code from links here at PJRC forums and I made changes to fit my needs. One of those changes was to add pages for presets. The controller has 8 push buttons for presets and 2 buttons to page up or down through 3 pages giving me 24 presets altogether. Each preset button has an LED indicator so I know which one I'm using and there are the 3 LEDs to indicate which page I'm on.
It's a lot of cabling and sometimes I don't have a good spot to put my laptop so not finding it to be the best solution. My iPad is attached to my mic stand so it very convenient to use.
I'm willing to bet most of the code I need already exists, but there is just so much information available, I'm a little overwhelmed as to which one to use. I'm hoping you guys can point me in the right direction. (Or better yet, write the code for me - lol)
Any advice would be appreciated.
thnx
Check out some of the examples with TeensyDMX. It’s accessible through the Arduino IDE (or Teensyduino); just search for “TeensyDMX” in the Library Manager (v4.1.0-beta.2 is the current, but v4.1.0 will appear very soon). That should get you set up for outputting DMX. If you don’t have much Arduino IDE experience, one of the menus has “Examples”, then find the library you’re looking for, then choose an example.
To receive Art-Net, I’m sure there’s some Arduino libraries for that (I haven’t released mine at this time), but when you receive data, simply call the ‘set’ function on your transmitter object (‘dmxTx’ in the TeensyDMX examples) with the received DMX data.
So basically:
  1. Initialize the DMX transmitter, Ethernet, and Art-Net receiver.
  2. Loop and receive Art-Net packets.
  3. For each received DMX data packet, shove the data into the DMX transmitter.
That’s a bird’s eye view. Hopefully it gets you started.
Thank you Shawn. I have some of those libraries downloaded, just didn't really know which ones to use or how to implement them. This will definitely get me started, but after the holiday; I gave the ethernet and DMX boards to my daughter so she can give them to me for christmas - lol
Cheers
I am not sure if I said this before, but I have very little programming experience. The last thing I learned was machine language for the old MOStek 6502 processor back in the early 80's (yikes).
So, I'm having a bit of trouble getting this project to work.
I am using the receiver.ino example from Artnet-Master code I downloaded. I made some changes to include NativeEthernet and I edited the artnet.h file to reflect the change. It compiles and uploads, but it does not connect to my router. The green light on the rj45 jack comes on, but not the orange. The router's status does not show the Teensy connected.
If someone could point me in the right direction, I'd appreciate it. I know I'm missing a lot and it probably has to do with the libraries.... Better yet, if anyone wants to code this up and make the hex file available to me, I would return the favor with a few cups of coffee or maybe a paypal payment (if that's not against the rules here).
Here is the code I used.
//#include <Ethernet.h>
#include <Artnet.h>
#include <NativeEthernet.h>
// Ethernet stuff
const IPAddress ip(192, 168, 0, 201);
uint8_t mac[] = {0x01, 0x23, 0x45, 0x67, 0x89, 0xAB};
ArtnetReceiver artnet;
uint32_t universe1 = 1;
uint32_t universe2 = 2;
void callback(const uint8_t* data, const uint16_t size) {
// you can also use pre-defined callbacks
Ethernet.begin(mac, ip);
//NativeEthernet.begin(mac, ip);
artnet.begin();
// if Artnet packet comes to this universe, this function is called
artnet.subscribe(universe1, [&](const uint8_t* data, const uint16_t size) {
Serial.print("artnet data (universe : ");
Serial.print(universe1);
Serial.print(", size = ");
Serial.print(size);
Serial.print(") :");
for (size_t i = 0; i < size; ++i) {
Serial.print(data);
Serial.print(",");
artnet.subscribe(universe2, callback);
artnet.parse(); // check if artnet packet has come and execute callback
Here is the artnet.h file... (Not sure what to do about the smiley emojis)
#pragma once
#ifndef ARDUINO_ARTNET_H
#define ARDUINO_ARTNET_H
// Spec (Art-Net 4) : http://artisticlicence.com/WebSiteMaster/User Guides/art-net.pdf
// Packet Summary : https://art-net.org.uk/structure/packet-summary-2/
// Packet Definition : https://art-net.org.uk/structure/streaming-packets/artdmx-packet-definition/
#include <Arduino.h>
#include "util/ArxTypeTraits/ArxTypeTraits.h"
#include "util/ArxContainer/ArxContainer.h"
#if defined(ESP_PLATFORM) || defined(ESP8266) || defined(ARDUINO_AVR_UNO_WIFI_REV2) || defined(ARDUINO_SAMD_MKRWIFI1010) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_NANO_33_IOT)
#define ARTNET_ENABLE_WIFI
#if defined(ESP8266) || !defined(ARTNET_ENABLE_WIFI)
#define ARTNET_ENABLE_ETHER
#if !defined(ARTNET_ENABLE_WIFI) && !defined(ARTNET_ENABLE_ETHER)
#error THIS PLATFORM HAS NO WIFI OR ETHERNET OR NOT SUPPORTED ARCHITECTURE. PLEASE LET ME KNOW!
#ifdef ARTNET_ENABLE_WIFI
#ifdef ESP_PLATFORM
#include <WiFi.h>
#include <WiFiUdp.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#elif defined(ARDUINO_AVR_UNO_WIFI_REV2) || defined(ARDUINO_SAMD_MKRWIFI1010) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(ARDUINO_SAMD_NANO_33_IOT)
#include <WiFiNINA.h>
#elif defined(ARDUINO_SAMD_MKR1000)
#include <WiFi101.h>
#endif // ARTNET_ENABLE_WIFI
#ifdef ARTNET_ENABLE_ETHER
#include <NativeEthernetUdp.h>
#include "util/TeensyDirtySTLErrorSolution/TeensyDirtySTLErrorSolution.h"
#endif // ARTNET_ENABLE_ETHER
namespace arx {
namespace artnet {
enum class OpCode : uint16_t {
// Device Discovery
Poll = 0x2000,
PollReply = 0x2100,
// Device Configuration
Address = 0x6000,
Input = 0x7000,
IpProg = 0xF800,
IpProgReply = 0xF900,
Command = 0x2400,
// Streaming Control
Dmx = 0x5000,
Nzs = 0x5100,
Sync = 0x5200,
// RDM
TodRequest = 0x8000,
TodData = 0x8100,
TodControl = 0x8200,
Rdm = 0x8300,
RdmSub = 0x8400,
// Time-Keeping
TimeCode = 0x9700,
TimeSync = 0x9800,
// Triggering
Trigger = 0x9900,
// Diagnostics
DiagData = 0x2300,
// File Transfer
FirmwareMaster = 0xF200,
FirmwareReply = 0xF300,
Directory = 0x9A00,
DirectoryReply = 0x9B00,
FileTnMaster = 0xF400,
FileFnMaster = 0xF500,
FileFnReply = 0xF600,
// N/A
NA = 0x0000,
constexpr uint16_t OPC(OpCode op) { return static_cast<uint16_t>(op); }
enum class Index : uint16_t {
ID = 0,
OP_CODE_L = 8,
OP_CODE_H = 9,
PROTOCOL_VER_H = 10,
PROTOCOL_VER_L = 11,
SEQUENCE = 12,
PHYSICAL = 13,
SUBUNI = 14,
NET = 15,
LENGTH_H = 16,
LENGTH_L = 17,
DATA = 18
constexpr uint16_t IDX(Index i) { return static_cast<uint16_t>(i); }
constexpr uint16_t DEFAULT_PORT{6454};
constexpr uint16_t HEADER_SIZE{18};
constexpr uint16_t PACKET_SIZE{530};
constexpr uint16_t PROTOCOL_VER{0x0014};
constexpr uint8_t ID_LENGTH{8};
constexpr char ID[ID_LENGTH]{"Art-Net"};
constexpr float DEFAULT_FPS{40.};
constexpr uint32_t DEFAULT_INTERVAL_MS{(uint32_t)(1000. / DEFAULT_FPS)};
static constexpr uint8_t NUM_PIXELS_PER_UNIV{170};
using CallbackAllType = std::function<void(const uint32_t universe, const uint8_t* data, const uint16_t size)>;
using CallbackType = std::function<void(const uint8_t* data, const uint16_t size)>;
#if ARX_HAVE_LIBSTDCPLUSPLUS >= 201103L // Have libstdc++11
template <uint16_t SIZE>
using Array = std::array<uint8_t, SIZE>;
using CallbackMap = std::map<uint32_t, CallbackType>;
using namespace std;
#else
using Array = arx::vector<uint8_t, SIZE>;
using CallbackMap = arx::map<uint32_t, CallbackType, 8>;
using namespace arx;
union ArtPollReply {
struct {
uint8_t id[8]; // 8
uint16_t op_code; // 10
uint8_t ip[4]; // 14
uint16_t port; // 16
uint8_t ver_h; // 17
uint8_t ver_l; // 18
uint8_t net_sw; // 19
uint8_t sub_sw; // 20
uint8_t oem_h; // 21
uint8_t oem_l; // 22
uint8_t ubea_ver; // 23
uint8_t status_1; // 24
uint8_t esta_man_l; // 25
uint8_t esta_man_h; // 26
uint8_t short_name[18]; // 44
uint8_t long_name[64]; // 108
uint8_t node_report[64]; // 172
uint8_t num_ports_h; // 173
uint8_t num_ports_l; // 174
uint8_t port_types[4]; // 178
uint8_t good_input[4]; // 182
uint8_t good_output[4]; // 186
uint8_t sw_in[4]; // 190
uint8_t sw_out[4]; // 194
uint8_t sw_video; // 195
uint8_t sw_macro; // 196
uint8_t sw_remote; // 197
uint8_t spare[3]; // 200
uint8_t style; // 201
uint8_t mac_h; // 202
uint8_t mac[4]; // 206
uint8_t mac_l; // 207
uint8_t bind_ip[4]; // 211
uint8_t bind_index; // 212
uint8_t status_2; // 213
uint8_t filler[8][26]; // 421
uint8_t b[421];
template <typename S>
class Sender_ {
Array<PACKET_SIZE> packet;
String ip;
uint16_t port{DEFAULT_PORT};
uint8_t target_net{0};
uint8_t target_subnet{0};
uint8_t target_universe{0};
uint8_t seq{0};
uint8_t phy{0};
uint32_t prev_send_ms{0};
S* stream;
public:
#else
Sender_() { packet.resize(PACKET_SIZE); }
virtual ~Sender_() {}
void net(const uint8_t n) { target_net = n & 0x7F; }
void subnet(const uint8_t s) { target_subnet = s & 0x0F; }
void universe(const uint8_t u) { target_universe = u & 0x0F; }
void universe15bit(const uint8_t u) {
net((u >> 8) & 0xFF);
subnet((u >> 4) & 0x0F);
universe((u >> 0) & 0x0F);
void set(const uint8_t* const data, const uint16_t size = 512) {
packet[IDX(Index::pHYSICAL)] = phy;
packet[IDX(Index::NET)] = target_net;
packet[IDX(Index::SUBUNI)] = (target_subnet << 4) | target_universe;
packet[IDX(Index::LENGTH_H)] = (size >> 8) & 0xFF;
packet[IDX(Index::LENGTH_L)] = (size >> 0) & 0xFF;
memcpy((&packet[IDX(Index::DATA)]), data, size);
void set(const uint32_t universe_, const uint8_t* const data, const uint16_t size = 512) {
universe15bit(universe_);
set(data, size);
void set(const uint8_t net_, const uint8_t subnet_, const uint8_t universe_, const uint8_t* const data, const uint16_t size = 512) {
net(net_);
subnet(subnet_);
universe(universe_);
set(data, size);
void set(const uint16_t ch, const uint8_t data) {
packet[IDX(Index::DATA) + ch] = data;
void send() {
packet[IDX(Index::SEQUENCE)] = seq++;
stream->beginPacket(ip.c_str(), port);
stream->write(packet.data(), packet.size());
stream->endPacket();
void send(const uint8_t* const data, const uint16_t size = 512) {
set(data, size);
send();
void send(const uint32_t universe_, const uint8_t* const data, const uint16_t size = 512) {
set(universe_, data, size);
send();
void send(const uint8_t net_, const uint8_t subnet_, const uint8_t universe_, const uint8_t* const data, const uint16_t size = 512) {
set(net_, subnet_, universe_, data, size);
send();
void streaming() {
if ((millis() - prev_send_ms) > DEFAULT_INTERVAL_MS) {
send();
prev_send_ms = millis();
void physical(const uint8_t i) const { phy = constrain(i, 0, 3); }
// void poll_reply(const IPAddress& remote_ip, const uint16_t remote_port) {
void poll_reply() {
ArtPollReply r;
for (size_t i = 0; i < ID_LENGTH; i++) r.id = static_cast<uint8_t>(ID);
r.op_code = (uint16_t)OpCode::pollReply;
IPAddress my_ip = WiFi.localIP();
IPAddress my_ip = Ethernet.localIP();
for (size_t i = 0; i < 4; ++i) r.ip = my_ip;
r.port = DEFAULT_PORT;
r.ver_h = (PROTOCOL_VER >> 8) & 0x00FF;
r.ver_l = (PROTOCOL_VER >> 0) & 0x00FF;
r.net_sw = 0; // TODO:
r.sub_sw = 0; // TODO:
r.oem_h = 0; // https://github.com/tobiasebsen/ArtNode/blob/master/src/Art-NetOemCodes.h
r.oem_l = 0xFF; // OemUnknown
r.ubea_ver = 0; // UBEA not programmed
r.status_1 = 0x00; // Unknown / Normal
r.esta_man_l = 0; // No EATA manufacture code
r.esta_man_h = 0; // No ESTA manufacture code
char short_name[18] = "Arduino ArtNet";
memcpy(r.short_name, short_name, sizeof(short_name));
char long_name[64] = "Arduino ArtNet Protocol by hideakitai/ArtNet";
memcpy(r.long_name, long_name, sizeof(long_name));
static size_t counts = 0;
char node_report[64];
sprintf(node_report, "#0001 [%d] Arduino ArtNet enabled", counts++);
memcpy(r.node_report, node_report, sizeof(node_report));
r.num_ports_h = 0; // Reserved
r.num_ports_l = 1; // This library implements only 1 port
for (size_t i = 0; i < 4; ++i) {
r.port_types = 0xC0; // I/O available by DMX512
r.good_input = 0x80; // Data received without error
r.good_output = 0x80; // Data transmittedj without error
r.sw_in = 0; // TODO:
r.sw_out = 0; // TODO:
r.sw_video = 0; // Video display shows local data
r.sw_macro = 0; // No support for macro key inputs
r.sw_remote = 0; // No support for remote trigger inputs
memset(r.spare, 0x00, 3);
r.style = 0x00; // A DMX to / from Art-Net device
r.mac_h = 0; // Do not supply mac address
memset(r.mac, 0x00, 4);
r.mac_l = 0;
for (size_t i = 0; i < 4; ++i) r.bind_ip = my_ip;
r.bind_index = 0;
r.status_2 = 0x08; // sACN capable (maybe)
memset(r.filler, 0x00, 208);
static const IPAddress DIRECTED_BROADCAST_ADDR(2, 255, 255, 255);
stream->beginPacket(DIRECTED_BROADCAST_ADDR, DEFAULT_PORT);
stream->write(r.b, 421);
uint8_t sequence() const { return seq; }
protected:
void attach(S& s, const String& user_ip, const uint16_t user_port = DEFAULT_PORT) {
stream = &s;
ip = user_ip;
port = user_port;
for (size_t i = 0; i < ID_LENGTH; i++) packet[IDX(Index::ID) + i] = static_cast<uint8_t>(ID);
packet[IDX(Index::OP_CODE_H)] = (OPC(OpCode::Dmx) >> 8) & 0x00FF;
packet[IDX(Index::OP_CODE_L)] = (OPC(OpCode::Dmx) >> 0) & 0x00FF;
packet[IDX(Index::pROTOCOL_VER_H)] = (PROTOCOL_VER >> 8) & 0x00FF;
packet[IDX(Index::pROTOCOL_VER_L)] = (PROTOCOL_VER >> 0) & 0x00FF;
class Receiver_ {
IPAddress remote_ip;
uint16_t remote_port;
CallbackMap callbacks;
CallbackAllType callback_all;
S* stream;
public:
#else
Receiver_() { packet.resize(PACKET_SIZE); }
virtual ~Receiver_() {}
OpCode parse() {
const size_t size = stream->parsePacket();
if (size == 0) return OpCode::NA;
uint8_t d[size];
stream->read(d, size);
if (size <= HEADER_SIZE) return OpCode::NA; // discard packet if incomplete
if (checkID(d)) {
switch (opcode(d)) {
case OPC(OpCode::Dmx): {
memcpy(packet.data(), d, size);
remote_ip = stream->S::remoteIP();
remote_port = (uint16_t)stream->S::remotePort();
if (callback_all) callback_all(universe15bit(), data(), size - HEADER_SIZE);
for (auto& c : callbacks)
if (universe15bit() == c.first) c.second(data(), size - HEADER_SIZE);
return OpCode::Dmx;
case OPC(OpCode::poll): {
return OpCode::poll;
default: {
return OpCode::NA;
return OpCode::NA;
inline const IPAddress&
ip() const {
return remote_ip;
inline uint16_t port() const { return remote_port; }
inline String id() const {
String str;
for (uint8_t i = 0; i < ID_LENGTH; ++i) str += packet[IDX(Index::ID) + i];
return str;
inline uint16_t opcode() const {
return (packet[IDX(Index::OP_CODE_H)] << 8) | packet[IDX(Index::OP_CODE_L)];
inline uint16_t opcode(const uint8_t* p) const {
return (p[IDX(Index::OP_CODE_H)] << 8) | p[IDX(Index::OP_CODE_L)];
inline uint16_t version() const {
return (packet[IDX(Index::pROTOCOL_VER_H)] << 8) | packet[IDX(Index::pROTOCOL_VER_L)];
inline uint8_t sequence() const {
return packet[IDX(Index::SEQUENCE)];
inline uint8_t physical() const {
return packet[IDX(Index::pHYSICAL)];
inline uint8_t net() const {
return packet[IDX(Index::NET)] & 0x7F;
inline uint8_t subnet() const {
return (packet[IDX(Index::SUBUNI)] >> 4) & 0x0F;
inline uint8_t universe() const {
return packet[IDX(Index::SUBUNI)] & 0x0F;
inline uint16_t universe15bit() const {
return (packet[IDX(Index::NET)] << 8) | packet[IDX(Index::SUBUNI)];
inline uint16_t length() const {
return (packet[IDX(Index::LENGTH_H)] << 8) | packet[IDX(Index::LENGTH_L)];
inline uint16_t size() const {
return length();
inline uint8_t* data() {
return &(packet[HEADER_SIZE]);
inline uint8_t data(const uint16_t i) const {
return packet[HEADER_SIZE + i];
template <typename F>
inline auto subscribe(const uint32_t universe, F&& func)
-> std::enable_if_t<arx::is_callable<F>::value> {
callbacks.insert(make_pair(universe, arx::function_traits<F>::cast(func)));
inline auto subscribe(const uint32_t universe, F* func)
inline auto subscribe(F&& func)
callback_all = arx::function_traits<F>::cast(func);
inline auto subscribe(F* func)
inline auto subscribe(const uint8_t net, const uint8_t subnet, const uint8_t universe, F&& func)
uint32_t u = ((uint32_t)net << 8) | ((uint32_t)subnet << 4) | (uint32_t)universe;
subscribe(u, func);
inline auto subscribe(const uint8_t net, const uint8_t subnet, const uint8_t universe, F* func)
subscribe(u, func);
inline void unsubscribe(const uint32_t universe) {
auto it = callbacks.find(universe);
if (it != callbacks.end())
callbacks.erase(it);
inline void unsubscribe() {
callback_all = nullptr;
inline void unsubscribe(const uint8_t net, const uint8_t subnet, const uint8_t universe) {
unsubscribe(u);
inline void clear_subscribers() {
unsubscribe();
callbacks.clear();
#ifdef FASTLED_VERSION
inline void forward(const uint32_t universe, CRGB* leds, const uint16_t num) {
subscribe(universe, [&](const uint8_t* data, const uint16_t size) {
if (size < num * 3) Serial.println(F("ERROR: Too many LEDs to forward"));
for (size_t pixel = 0; pixel < num; ++pixel) {
size_t idx = pixel * 3;
leds[pixel].r = data[idx + 0];
leds[pixel].g = data[idx + 1];
leds[pixel].b = data[idx + 2];
inline void forward(const uint8_t net, const uint8_t subnet, const uint8_t universe, CRGB* leds, const uint16_t num) {
forward(u, leds, num);
protected:
void attach(S& s) {
stream = &s;
private:
inline bool checkID() const {
const char* idptr = reinterpret_cast<const char*>(packet.data());
return !strcmp(ID, idptr);
inline bool checkID(const uint8_t* p) const {
const char* idptr = reinterpret_cast<const char*>(p);
}; // namespace artnet
class Manager : public Sender_<S>, public Receiver_<S> {
S stream;
public:
void begin(const String& send_ip, const uint16_t send_port = DEFAULT_PORT, const uint16_t recv_port = DEFAULT_PORT) {
stream.begin(recv_port);
this->Sender_<S>::attach(stream, send_ip, send_port);
this->Receiver_<S>::attach(stream);
void parse() {
OpCode op_code = this->Receiver_<S>::parse();
switch (op_code) {
case OpCode::poll: {
// this->Sender_<S>::poll_reply(
// this->Receiver_<S>::ip(),
// this->Receiver_<S>::port());
this->Sender_<S>::poll_reply();
default: {
class Sender : public Sender_<S> {
S stream;
public:
void begin(const String& ip, const uint16_t port = DEFAULT_PORT) {
stream.begin(DEFAULT_PORT);
this->Sender_<S>::attach(stream, ip, port);
class Receiver : public Receiver_<S> {
S stream;
public:
void begin(const uint16_t port = DEFAULT_PORT) {
stream.begin(port);
} // namespace artnet
} // namespace arx
using ArtnetWiFi = arx::artnet::Manager<WiFiUDP>;
using ArtnetWiFiSender = arx::artnet::Sender<WiFiUDP>;
using ArtnetWiFiReceiver = arx::artnet::Receiver<WiFiUDP>;
using Artnet = arx::artnet::Manager<NativeEthernetUDP>;
using ArtnetSender = arx::artnet::Sender<NativeEthernetUDP>;
using ArtnetReceiver = arx::artnet::Receiver<NativeEthernetUDP>;
#endif // ARDUINO_ARTNET_H
Thanks much!!
