analogInputToDigitalPin() on Teensy 4.1
spot
New member
The analogInputToDigitalPin macro for the Teensy 4.1 in teensy4\pins_arduino.h seems to be broken. It does not properly handle A10-A17.
#elif defined(__IMXRT1062__) && defined(ARDUINO_TEENSY41)
#define analogInputToDigitalPin(p) (((p) <= 9) ? (p) + 14 : (( ((p) >= 14 && (p) <= 27)) || ((p) >= 38 && (p) <= 41) ? (p) : -1))
can be replaced with:
#define analogInputToDigitalPin(p) (((p) <= 13) ? (p) + 14 : (( ((p) >= 14 && (p) <= 17)) ? (p) + 24 : -1))
#define newanalogInputToDigitalPin(p) (((p) <= 13) ? (p) + 14 : (( ((p) >= 14 && (p) <= 17)) ? (p) + 24 : -1))
  delay(300);
  //  Test analogInputToDigitalPin macro
  for (int i = 0; i < NUM_ANALOG_INPUTS; i++)
    Serial.printf("analogInputToDigitalPin(%d)=%d\n", i, analogInputToDigitalPin(i));
    Serial.printf("newanalogInputToDigitalPin(%d)=%d\n", i, newanalogInputToDigitalPin(i));
Generates the following output:
analogInputToDigitalPin(0)=14
analogInputToDigitalPin(1)=15
analogInputToDigitalPin(2)=16
analogInputToDigitalPin(3)=17
analogInputToDigitalPin(4)=18
analogInputToDigitalPin(5)=19
analogInputToDigitalPin(6)=20
analogInputToDigitalPin(7)=21
analogInputToDigitalPin(8)=22
analogInputToDigitalPin(9)=23
analogInputToDigitalPin(10)=-1
analogInputToDigitalPin(11)=-1
analogInputToDigitalPin(12)=-1
analogInputToDigitalPin(13)=-1
analogInputToDigitalPin(14)=14
analogInputToDigitalPin(15)=15
analogInputToDigitalPin(16)=16
analogInputToDigitalPin(17)=17
newanalogInputToDigitalPin(0)=14
newanalogInputToDigitalPin(1)=15
newanalogInputToDigitalPin(2)=16
newanalogInputToDigitalPin(3)=17
newanalogInputToDigitalPin(4)=18
newanalogInputToDigitalPin(5)=19
newanalogInputToDigitalPin(6)=20
newanalogInputToDigitalPin(7)=21
newanalogInputToDigitalPin(8)=22
newanalogInputToDigitalPin(9)=23
newanalogInputToDigitalPin(10)=24
newanalogInputToDigitalPin(11)=25
newanalogInputToDigitalPin(12)=26
newanalogInputToDigitalPin(13)=27
newanalogInputToDigitalPin(14)=38
newanalogInputToDigitalPin(15)=39
newanalogInputToDigitalPin(16)=40
newanalogInputToDigitalPin(17)=41
I could be wrong here, but I think this Macro is setup to handle the funky stuff on how analogRead works...
That is if you do something like: analogRead(0); It will read pin 14... This is true for 0-9 to match back to early Arduino boards.
But above 9 you pass in the actual pin number. And analogRead(17) reads pin 17 not A17.
If you wish to use A17 you pass it in to analogRead(A17).
Where A17 is defined in the sources as:
#ifdef ARDUINO_TEENSY41
#define PIN_A14 (38)
#define PIN_A15 (39)
#define PIN_A16 (40)
#define PIN_A17 (41)
const static uint8_t A14 = PIN_A14;
const static uint8_t A15 = PIN_A15;
const static uint8_t A16 = PIN_A16;
const static uint8_t A17 = PIN_A17;
