Results 1 to 4 of 4
Thread: Teensy 3.6 Fast pinMode alternative?
    Hi, I can switch the complete ports with GPIOE_PDOR and GPIOE_PDIR very fast (High/Low ~7ns)
    I was searching here in this forum for an also fast pinMode alternative, but I found nothing.
    My question: I want to switch a whole port from Input to Output. Is this possible?
    I've tried GPIOE_PDDR, but this is not working
    "pinMode" alone takes ~200ns ... and this is very slow.
    I found the solution by myself.
    You have to use pinMode(x, INPUT) and then you can manipulate the Port with GPIOE_PDDR very fast. Without pinMode before its not working!
    7,999
    This is the code for Teensy 3.x pinMode(): https://github.com/PaulStoffregen/co...teensy.c#L1090
    Maybe it is somehow useful.
    Dec 2013
    East Stroudsburg PA.
    302
    Use Global Pin Control Low Register (PORTx_GPCLR) :https://forum.pjrc.com/threads/64970...x_GPCHR-How-to
