Hello, I am just beginning Teensy 4.0+audio shield for 4.0.
I am trying to play audio files in my SD card, but
when I write "SDTEST1.WAV" ~ "SDTEST4.WAV" which I downloaded, all the files are played back without any problem.
but, other files are not played. Teensy cannot read other files, which I dragged in as '44.1khz/16bit' wave file format.
How can I fix this problem? Probably, naming the files? I just named my tune as 'ELECSWING.WAV'.
Any advice would be appreciated.
P.S mp3 or other sampling rated files can't be read by teeny 4.0?
The source code is as below:
// Advanced Microcontroller-based Audio Workshop
// [URL]http://www.pjrc.com/store/audio_tutorial_kit.html[/URL]
// [URL]https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015[/URL]
// Part 1-3: First "Hello World" program, play a music file
// WAV files for this and other Tutorials are here:
// [URL]http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html[/URL]
#include <SerialFlash.h>
AudioPlaySdWav playSdWav1;
AudioOutputI2S i2s1;
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 1, i2s1, 1);
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 11
#define SDCARD_SCK_PIN 13
// Use these with the Teensy 3.5 & 3.6 SD card
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.25);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing");
playSdWav1.play("ELECSWING.WAV");
delay(10); // wait for library to parse WAV info
// do nothing while playing...
