Results 1 to 8 of 8
Thread: Teensy 4.1 + Circuitpython + Ethernet
    Dec 2020
    2
    Teensy 4.1 with wired Ethernet is a great package. But reading at many places, I can't find any positive info for Ethernet being available on Circuitpython? Do I reed the wrong information? I hope some one can give some positive feedback, please.
    Marry Christmas
    nobyte
    25,073
    Pretty sure it's not supported by CircuitPython. Also pretty sure nobody is working on supporting it. Only likely path to using it is Arduino or the other environments which use the Arduino libs.
    Dec 2020
    2
    Thank you very much for the fast answer!
    Jul 2021
    1
    Any change on this subject?
    Python + Teensy4.1 would be my preferred solution to create a remote IOTdevice.
    New York
    7,552
    Quote Originally Posted by dutchie View Post
    As far as I know Circuit Python for the Teensy is done/maintained by Adafruit. You might what to check post #118 that further explains it in this thread: https://forum.pjrc.com/threads/59040...circuit+python.
    318
    Looks like there is CircuitPython for Teensy 4.1. Here is the hex file:
    https://circuitpython.org/board/teensy41/
    Does the teensy loader use drag and drop for hex files?
    4,090
    Quote Originally Posted by Bill Greiman View Post
    No. You have to use the Teensy loader to load the hex file.
    Be sure to check whether CP supports the Teensy 4.1 ethernet.
    318
    On the Teensy loader page it claims you can drop the hex file on the loader window:
    You can also open the file using the toolbar button, or using drag-and-drop onto the upper portion of the window.
    I have been searching for the full specs and repo for Teensy 4.1 and have not found it. There is lot of activity with frequent builds showing up here:
    https://adafruit-circuit-python.s3.a...eensy41/en_US/
    Drag and drop worked. I now have a CIRCUITPY folder for the Teensy 4.1 on my Windows machine.
    I opened a PuTTY window and:
    >>> print("Hello World!")
    Hello World!
    Droping or editing a .py file causes it to execute.
    Who knows what features are implemented for Teensy 4.1?
    Installed Mu editor. Has REPL interface. No wonder people like CircuitPython.
    Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
    Press any key to enter the REPL. Use CTRL-D to reload.
    Adafruit CircuitPython 6.3.0 on 2021-06-01; Teensy 4.1 with IMXRT1062DVJ6A
    code.py output:
    Hello World
    Code done running.
