Results 1 to 3 of 3
Thread: T4.1 External USB C Connector
    Apr 2017
    732
    Here's a quick write up for a permanent and relatively simple way for anyone wanting to add an external USB connector to a Teensy 4.1 based PCB.
    First step is to make 2 solder balls on the D+ and D- pads
    Next you want to similarly make 2 solder balls on the ends of 2 pins
    Take those 2 pins and slide them in position on your PCB without soldering them
    Now you can place your Teensy into position and solder it down
    Then you have to carefully reach your soldering iron under the Teensy and heat the solder balls together while pushing up on the pins from the bottom
    Once you have it soldered to the Teensy you can then solder it to the PCB and cut the pins to size
    I made use of this through hole USB 2.0 Type-C connector, but any other one would work fine. I've only tested uploading sketches and Serial communication, so as far as signal integrity goes I haven't had issues yet and my prototype board had some errors in it so I had to use a couple inches of hookup wire between the Teensy and the USB C connector which is definitely not ideal in any way.
    Germany
    1,369
    Interesting idea and a nice Type-C connector. If you don't mind I'll steal this idea and try to make a small castellated adapter board to add a USB-C connector to the T4.1. Care to mention which one is D+ in your first picture?
    Apr 2017
    732
    As per the schematic D+ is on the ground side and D- is on the power side, I thought about designing a small board, but personally I probably won’t need it so I didn’t.
