Page 1 of 2 1 2 LastLast
Results 1 to 25 of 35
Thread: Adafruit BMP390 over I2C with Wire.h on Teensy 3.6 ok but not for Teensy 4.1
    Dec 2020
    10
    two weeks ago I bought a Teensy 4.1 primaily for the built in RTC for time stamping measured values.
    Attached a Adafruit BMP390 over the first I2C connection (18/19) to it using the Adafruit_BMP3XX library (Wire.h) and the scetch bmp3xx_simpletest.
    I also have an Teensy 3.6 with an Adafruit BMP388 connected and working with the same scetch.
    However the T4.1 only shows on the serial:
    "Adafruit BMP390
    Sekunden,Temp,TempK,Press,PressK,Alt
    Failed to perform reading
     * Sekunden,Temp,TempK,Press,PressK,Alt
      This is a library for the BMP3XX temperature & pressure sensor
      Designed specifically to work with the Adafruit BMP388 Breakout
      ----> http://www.adafruit.com/products/3966
      These sensors use I2C or SPI to communicate, 2 or 4 pins are required
      to interface.
      please support Adafruit and open-source hardware by purchasing products
      from Adafruit!
      Written by Limor Fried & Kevin Townsend for Adafruit Industries.
      BSD license, all text above must be included in any redistribution
     *  Teensy4.1 BMP390 0x77
     *  Adafruit BMP390
     *  Failed to perform reading :(
    #include <Adafruit_Sensor.h>
    #include "Adafruit_BMP3XX.h"
    #include <SimpleKalmanFilter.h>
    const int CounterMax = 90;
    // 2s
    const int DelayTime = 1000;
    // passender
    const int CounterAdd = DelayTime / 1000;
    SimpleKalmanFilter PressureKalmanFilter(1, 1, 0.01);
    SimpleKalmanFilter TempKalmanFilter(1, 1, 0.01);
    //SimpleKalmanFilter PressureKalmanFilter(0.5, 0.5, 0.01);
    //SimpleKalmanFilter TempKalmanFilter(0.5, 0.5, 0.01);
    #define SEALEVELPRESSURE_HPA (1013.25)
    Adafruit_BMP3XX bmp;
      while (!Serial);
      Serial.println("Adafruit BMP390");
      if (!bmp.begin_I2C()) {   // hardware I2C mode, can pass in address & alt Wire
      //if (! bmp.begin_SPI(BMP_CS)) {  // hardware SPI mode
      //if (! bmp.begin_SPI(BMP_CS, BMP_SCK, BMP_MISO, BMP_MOSI)) {  // software SPI mode
        Serial.println("Could not find a valid BMP3xx sensor, check wiring!");
        while (1);
      // Set up oversampling and filter initialization
      bmp.setTemperatureOversampling(BMP3_OVERSAMPLING_2X);
      // BMP3_OVERSAMPLING_2X
      // BMP3_No_OVERSAMPLING
      bmp.setPressureOversampling(BMP3_OVERSAMPLING_32X);
      bmp.setIIRFilterCoeff(BMP3_IIR_FILTER_COEFF_3);
      //DISABLE);
      //COEFF_3);
      bmp.setOutputDataRate(BMP3_ODR_25_HZ);
      Serial.println("Sekunden,Temp,TempK,Press,PressK,Alt");
    int Counter = 0;
      float Temp, TempK, Press, PressK, Alt;
      if (! bmp.performReading()) {
        Serial.println("Failed to perform reading :(");
        while (1);
        return;
      Serial.print(Counter); Serial.print(",");
      Temp = bmp.temperature;
      //Serial.print("Temperature = ");
      Serial.print(Temp); Serial.print(",");
      TempK = TempKalmanFilter.updateEstimate(Temp);
      Serial.print(TempK); Serial.print(",");
      //Serial.println(" *C");
      Press = bmp.pressure / 100.0;
      //Serial.print("Pressure = ");
      Serial.print(Press); Serial.print(",");
      PressK = PressureKalmanFilter.updateEstimate(Press);
      Serial.print(PressK); Serial.print(",");
      //Serial.println(" hPa");
      Alt = bmp.readAltitude(SEALEVELPRESSURE_HPA);
      //Serial.print("Approx. Altitude = ");
      Serial.println(Alt);
      //Serial.print(",");
      //Serial.println(" m");
      //Serial.println();
      switch (Counter) {
        case CounterMax:
          Serial.println("");
        default:
          // do not do anything
      Counter = Counter + CounterAdd;
      delay(DelayTime);
    I do not see any hints on the log files (attached) why it does not work out as on T3.6.
    If I include i2c_t3.h of course I get compiler errors (Adafruit uses Wire.h).
    Any other ideas why it does not work and/or how to get it working?
    KR,
    Jrg
    Attached Files Attached Files
    Jul 2020
    15
    I have seen the same issue with 4.1 and the BMP390 over I2C.
    SPI works fine. but I also need to use I2C for my project.
    I used a MCP9808 i2C temperature sensor with teensy 4.1 without issue. difference could be the pull up resistors?..... so I added different sizes pullups to the BMP390 and this didn't result in anything working.
    I added a question to the Adafruit forum but no answer.
    i could be wrong but looks like an issue with the library? or something subtle with the teensy 4.1 ?
    If you find anything out please let me know, and i will also post back here if I find a solution.
    Regards
    Wess
    9,214
    Sorry, I was going to order one of them from Adafruit, but they won't ship to my mailbox... And Neither Digikey nor Mouser had them in stock nor found it on Amazon...
    SO I ordered a 388 version from Sparkfun. Probably the same software should work (or not work)... Maybe here sometime this next week.
    Could be PU resistors. Could be a timing issue. ...
    Dec 2020
    10
    Quote Originally Posted by Wez View Post
    My four cables are only 8cm short/long so at first I did not bother about the two Pull Ups.
    However today I tried some values (min, max: https://www.pjrc.com/teensy/td_libs_Wire.html):
    • no Pull Up
    • 2kOhm
    • 4,7kOhm
    I am usind the Vin (5V, green SMD-LED is on) on the Adafruit BMP390 not sure how far this is an issue, but worked in the past and I did not worry about level shifting.
    I also lowerd the baud rate from 115200 down to 9600.
    question marks still remain...
    Jul 2020
    15
    I managed to find an old Arduino uno.
    Fired up first time with the test sketch with I2C, so the I2C bus is functional on my sensor.
    So upto now we have tested:
    Teensy 4.1 +SPI with BMP390 = works
    Arduino uno + I2C with BMP390 = works
    Teensy 4.1 + I2C with MCP9808 = Works (this is a thermometer with 10k pullups.)
    Teensy 4.1 + I2C with BMP390 = does not work,
    Tested teensy 4.1 with pullups 2k and 4.7K (you) and 2.2k , 4.7K and 10k (me). = not working
    Im going to look into if this is another issue like impedance or some setting on the 4.1 thats new to me, i looked at the library but this is a massive amount of code and would need an expert to spot a 4.1 issue in it.
    24,470
    Have you tried the Wire library Scanner example?
    Does it detect the BMP390 hardware on Teensy 4.1?
    Jul 2020
    15
    Yes i have and thank you for the reply Paul, i get the return = 0x77
    9,214
    Again I could not order one of the Adafruit ones, but ordered a Sparkfun 388 version, which should ship soon. (I ordered too late on New Years Eve) so will probably ship Tomorrow.
    2,633
    You could define BMP3XX_DEBUG in the Adafruit_BMP3XX library, and it should print out progress in performReading() that might help you locate the problem. Since the Teensy 4 is so fast you might look for places in the library where delay's might be increased ...
    New York
    7,209
    Just catching up as been a bit out of it for several days. But I just ordered one from Adafruit and should be Tuesday afternoon.
    Jul 2020
    15
    In response to 'manitou' this is what i got when i run the debug, however i don't have the knowledge of the 4.1 to understand what might create the issue.
    Defining BMP3XX_DEBUG prints out this in the serial monitor
    Adafruit BMP388 / BMP390 test
    Reset result: 0
    Init result: 0
    Valtrim result: 0
    T1 = 27483
    T2 = 19161
    T3 = -7
    P1 = 7248
    P2 = 5548
    P3 = 6
    P4 = 1
    P5 = 18780
    P6 = 23990
    P7 = 3
    P8 = -6
    P9 = 3978
    P10 = 6
    P11 = -11
    Setting sensor settings
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Failed to perform reading ..............................................
    Dec 2020
    10
    It also works on my setup.
    Dec 2020
    10
    With default bmp3xx_simpletest.ion over I2C with Debug enabled.
    On a Arduino Uno:
    Reset result: 0
    Init result: 0
    Valtrim result: 0
    T1 = 27582
    T2 = 19163
    T3 = -7
    P1 = 7275
    P2 = 5592
    P3 = 6
    P4 = 1
    P5 = 18782
    P6 = 23696
    P7 = 3
    P8 = -6
    P9 = 4028
    P10 = 6
    P11 = -11
    Setting power mode
    Getting sensor data
    Temperature = 24.80 *C
    Pressure = 974.56 hPa
    Approx. Altitude = Setting sensor settings
    Setting power mode
    Getting sensor data
    327.26 m
    On the Teensy 4.1:
    Reset result: 0
    Init result: 0
    Valtrim result: 0
    T1 = 27582
    T2 = 19163
    T3 = -7
    P1 = 7275
    P2 = 5592
    P3 = 6
    P4 = 1
    P5 = 18782
    P6 = 23696
    P7 = 3
    P8 = -6
    P9 = 4028
    P10 = 6
    P11 = -11
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Getting sensor data
    Setting power mode
    Some how the
    Setting power mode
    indication is not shown regular from the beginning.
    9,214
    You might also check that your library Adafruit_BusIO is up to date as well.
    Also you may want to turn on the debug printing in here as well. That is in the file Adafruit_I2CDevice.cpp at the top uncomment the line //#define DEBUG_SERIAL ...
    And see where it probably fails.
    Beyond that hard to know yet. Could not tell from datasheet how fast it can do I2C interface. I also don't see anywhere where it is set. So I think Wire defaults to maybe 100khz? which should be slow enough.
    Dec 2020
    10
    Hi KurtE,
    first: All libs are up to date.
    With both Debugs enabled the results are:
    Kdiff
Name:	2021-01-04 18_29_11-T41.txt _-_ Uno.txt - KDiff3.png
Name:	2021-01-04 18_30_04-T41.txt _-_ Uno.txt - KDiff3.jpg
    First measuring of the Arduino Uno:
Name:	2021-01-04 18_33_30-C__Users_max_Documents_Arduino_Uno.txt - Notepad++.png
    First measuring of the Teensy 4.1:
Name:	2021-01-04 18_34_01-C__Users_max_Documents_Arduino_T41.txt - Notepad++.png
    Now the questions are:
    1. Why i2cRead delivers: 0x70 instead of 0x10
    2. Why i2cWrite delivers: 0x0 instead of 0x9
    3. Why "I2CWRITE @ 0x77 :: 0x4," does not result in "I2CREAD @ 0x77 :: 0x40, 0x2D, 0x68, 0xE0, 0x8D, 0x81,"
    and were and how to fix it.
    9,214
    Maybe a quick thing to try:
    Try adding a delay at startup:
    Something like:
      while (!Serial);
      delay(1000); // wait a second to see if the device is slow to startup...
    If that helps, than shorten...
    If not, I would maybe try adding some delays in library:
    Like where you see the output the debug output: Setting power mode
    Try adding a delay to there, before it does anything else... Maybe it is turning on power to device and UNO is slow enough that the device has a chance to respond, but faster device may take some time...
    Dec 2020
    10
    Hi KurtE,
    tried the 1 Second delay: same, same as above
    I do not think that some delays will solve it:
    1. is a read (feedback) from the sensor
    2. is a the last bit of a write of some bits which is different
    3. is a read (temperature, perssure and altitude, 6 bits) from the sensor which are not recieved from the Teensy 4.1
    The adjustment of the power is also different, there is still a bit change ongoing:
Name:	2021-01-04 21_28_04-Uno_vs._41.txt.jpg
    Uno:
    I2CREAD @ 0x77 :: 0x3,
    Teensy 4.1: several times
    I2CREAD @ 0x77 :: 0x13,
    In the data sheet page 44 the SCK frequency typ 400, max. 3400kHz
    9,214
    Understood, but I know with some sensors that work on a slower platform and not on faster ones, it can often be a timing issue, like you do a write operation to the device to ask it for something and then ask for the results and maybe a delay is needed...
    Have you tried the library that Sparkfun points you to with their sensor? https://github.com/MartinL1/BMP388_DEV
    I don't know how much different the 388 interface is to the 390.
    Their code for reading has calls in to ask the device if the conversion has completed. Again not sure how different they are. Won't have my Sparkfun version until later this week.
    Dec 2020
    10
    I have tried delay(40) betweeen the two returns, which did not work out. However 20ms did but with the same errors.
    Or is the place wrong?
    Adafruit_BMP3XX.cpp
        @brief  Reads 8 bit values over I2C
    int8_t i2c_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len,
                    void *intf_ptr) {
       //Serial.print("I2C read address 0x"); Serial.print(reg_addr, HEX);
       //Serial.print(" len "); Serial.println(len, HEX);
      if (!i2c_dev->write_then_read(&reg_addr, 1, reg_data, len))
        return 1;
      return 0;
        @brief  Writes 8 bit values over I2C
    int8_t i2c_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len,
                     void *intf_ptr) {
       //Serial.print("I2C write address 0x"); Serial.print(reg_addr, HEX);
      if (!i2c_dev->write((uint8_t *)reg_data, len, false, &reg_addr, 1))
        return 1;
      return 0;
    As far as I understood the interface is the same for both versions.
    using BMP388_I2C_Normal.ino
    Only for the first compilation I got the following messages:
    C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\Device.cpp: In member function 'void Device::notUsingInterrupt(uint8_t)':
    C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\Device.cpp:70:34: warning: invalid conversion from 'uint8_t {aka unsigned char}' to 'IRQ_NUMBER_t' [-fpermissive]
      spi->notUsingInterrupt(pinNumber);
    In file included from C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV/Device.h:34:0,
                     from C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\Device.cpp:29:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI/SPI.h:1162:7: note:   initializing argument 1 of 'void SPIClass::notUsingInterrupt(IRQ_NUMBER_t)'
      void notUsingInterrupt(IRQ_NUMBER_t interruptName);
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\YX\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\YX\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\YX\Documents\Arduino\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10813 -build-path C:\Users\YX\AppData\Local\Temp\arduino_build_215017 -warnings=all -build-cache C:\Users\YX\AppData\Local\Temp\arduino_cache_740608 -verbose C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\examples\BMP388_I2C_Normal\BMP388_I2C_Normal.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\YX\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\YX\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\YX\Documents\Arduino\libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10813 -build-path C:\Users\YX\AppData\Local\Temp\arduino_build_215017 -warnings=all -build-cache C:\Users\YX\AppData\Local\Temp\arduino_cache_740608 -verbose C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\examples\BMP388_I2C_Normal\BMP388_I2C_Normal.ino
    Using board 'teensy41' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Alternatives for BMP388_DEV.h: [BMP388_DEV@1.0.3]
    ResolveLibrary(BMP388_DEV.h)
      -> candidates: [BMP388_DEV@1.0.3]
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\YX\\Documents\\Arduino\\libraries\\BMP388_DEV" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Alternatives for Wire.h: [Wire@1.0]
    ResolveLibrary(Wire.h)
      -> candidates: [Wire@1.0]
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\YX\\Documents\\Arduino\\libraries\\BMP388_DEV" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Alternatives for SPI.h: [SPI@1.0]
    ResolveLibrary(SPI.h)
      -> candidates: [SPI@1.0]
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\YX\\Documents\\Arduino\\libraries\\BMP388_DEV" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Using cached library dependencies for file: C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\BMP388_DEV.cpp
    Using cached library dependencies for file: C:\Users\YX\Documents\Arduino\libraries\BMP388_DEV\Device.cpp
    Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp
    Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireIMXRT.cpp
    Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp
    Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c
    Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\YX\\Documents\\Arduino\\libraries\\BMP388_DEV" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp" -o "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Sketch wird kompiliert...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy4" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/pch/Arduino.h" -o "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\pch\Arduino.h.gch
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\YX\\Documents\\Arduino\\libraries\\BMP388_DEV" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp" -o "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp.o"
    Compiling libraries...
    Compiling library "BMP388_DEV"
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\BMP388_DEV\BMP388_DEV.cpp.o
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\BMP388_DEV\Device.cpp.o
    Compiling library "Wire"
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\Wire\Wire.cpp.o
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\Wire\WireKinetis.cpp.o
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\Wire\WireIMXRT.cpp.o
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\Wire\utility\twi.c.o
    Compiling library "SPI"
    Zuvor kompilierte Datei wird verwendet: C:\Users\YX\AppData\Local\Temp\arduino_build_215017\libraries\SPI\SPI.cpp.o
    Compiling core...
    Using precompiled core: C:\Users\YX\AppData\Local\Temp\arduino_cache_740608\core\core_e612ed3a92f8769e6d06d6bf8e29c1af.a
    Linking everything together...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.elf" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\sketch\\BMP388_I2C_Normal.ino.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\BMP388_DEV\\BMP388_DEV.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\BMP388_DEV\\Device.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\Wire\\WireIMXRT.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\Wire\\WireKinetis.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/..\\arduino_cache_740608\\core\\core_e612ed3a92f8769e6d06d6bf8e29c1af.a" "-LC:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017" -larm_cortexM7lfsp_math -lm -lstdc++
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.elf" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.eep"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.elf" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.hex"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.lst" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.elf"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.sym" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.elf"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=BMP388_I2C_Normal.ino "-path=C:\\Users\\YX\\AppData\\Local\\Temp\\arduino_build_215017" "-tools=C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY41
    Bibliothek BMP388_DEV in Version 1.0.3 im Ordner: C:\Users\max\Documents\Arduino\libraries\BMP388_DEV  wird verwendet
    Bibliothek Wire in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire  wird verwendet
    Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI  wird verwendet
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\max\\AppData\\Local\\Temp\\arduino_build_215017/BMP388_I2C_Normal.ino.elf"
    Der Sketch verwendet 26144 Bytes (0%) des Programmspeicherplatzes. Das Maximum sind 8126464 Bytes.
    Globale Variablen verwenden 45756 Bytes (8%) des dynamischen Speichers, 478532 Bytes fr lokale Variablen verbleiben. Das Maximum sind 524288 Bytes.
    C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile -file=BMP388_I2C_Normal.ino -path=C:\Users\max\AppData\Local\Temp\arduino_build_215017 -tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools -board=TEENSY41 -reboot -port=usb:20000/0/0/1/3/1/1/4 -portlabel=hid#vid_16c0&pid_0478 Bootloader -portprotocol=Teensy
    No serial output at all, UNO/Teensy4.1
    San Francisco Bay Area
    645
    From your debug, it looks like it's receiving the temperature and pressure calibrations (T1, P1, etc).
    I've used the BMP280 and BME280 with the teensy, and am about to find a BMP390 to try.
    I'm wondering if it's the 24-bit sample and possibly being stored in a default # of integer bytes or casting on the teensy maybe being different.
    edit: I may be misremembering how the calibrations stuff works, so what I said may not make sense.
    BTW, I found these, and I've had good luck with their boards in the past:
    http://www.diymalls.com/MP390-Barome...ature%20Sensor
    Also, Bosch driver here in case this is helpful:
    https://github.com/BoschSensortec/BMP3-Sensor-API
    Dec 2020
    10
    Comparing the memory maps between 388 and 390:
    1. reserved register at 0x1F position 0, while 390 has a read/write "short_in" there but only using bit 3..1
    2. reserved register at 0x19 position 6, while 390 has a read/write "int_ds" there but only using bit 4..0
    3. reserved register at 0x13 position 7..1, while 390 has a read only "fifo_byte_counter_11_8" there
    4. read only register at 0x13 position 0, while 390 has a read only "fifo_byte_counter_11_8" there but description in chapter 4.3.10 points out positon 0 is like in register 0x12!
    5. 390 has a reseverd register at 0x0F
    6. reserved register at 0x01, while 390 has a read only 7bit Revision ID (minor 3..0, major 7..4) there
    7. 388: reserved register at 0x10 "Event" position 7..1 and position 0 read only "por_detected"
    while on 390: position 1 read only "itf_act_pt"
    Dec 2020
    10
    For the 388 on a Teensy 3.6 the results are:
    Adafruit BMP388 test
    	I2CWRITE @ 0x77 :: 0x3,
    	I2CREAD  @ 0x77 :: 0x70,
    	I2CWRITE @ 0x77 :: 0x7E, 0xB6,
    	I2CWRITE @ 0x77 :: 0x2,
    	I2CREAD  @ 0x77 :: 0x0,
    Reset result: 0
    	I2CWRITE @ 0x77 :: 0x0,
    	I2CREAD  @ 0x77 :: 0x50,
    	I2CREAD  @ 0x77 :: 0x10,
    	I2CWRITE @ 0x77 :: 0x31,
    	I2CREAD  @ 0x77 :: 0x2A, 0x6B, 0x8, 0x49, 0xF6, 0x7, 0x0, 0xB4, 0xF5, 0x23, 0x0, 0x12, 0x64, 0x45, 0x7A, 0xF3, 0xF6, 0x2B, 0x40, 0x12, 0xC4,
    Init result: 0
    	I2CWRITE @ 0x77 :: 0x30,
    	I2CREAD  @ 0x77 :: 0xD4,
    Valtrim result: 0
    T1 = 27434
    T2 = 18696
    T3 = -10
    P1 = 7
    P2 = -2636
    P3 = 35
    P4 = 0
    P5 = 25618
    P6 = 31301
    P7 = -13
    P8 = -10
    P9 = 16427
    P10 = 18
    P11 = -60
    	I2CWRITE @ 0x77 :: 0x1B,
    	I2CWRITE @ 0x77 :: 0x1B, 0x3,
    	I2CWRITE @ 0x77 :: 0x1C,
    	I2CREAD  @ 0x77 :: 0x0, 0x0, 0x0, 0x0,
    	I2CWRITE @ 0x77 :: 0x1C, 0x1A, 0x1D, 0x2, 0x1F, 0x4, 0x11,
    Setting power mode
    	I2CWRITE @ 0x77 :: 0x1B, 0x13,
    Getting sensor data
    	I2CREAD  @ 0x77 :: 0x0, 0x0, 0x80, 0x0, 0x0, 0x80,
    Temperature = 23.71 *C
    Pressure = 817.37 hPa
    Approx. Altitude =
    	I2CREAD  @ 0x77 :: 0x1A, 0x2, 0x0, 0x4,
    Setting power mode
    Getting sensor data
    	I2CREAD  @ 0x77 :: 0xC0, 0x27, 0x71, 0x20, 0xAC, 0x80,
    341.00 m
    Setting power mode
    Getting sensor data
    Temperature = 24.47 *C
    Pressure = 972.96 hPa
    Approx. Altitude =
    Setting power mode
    Getting sensor data
    	I2CREAD  @ 0x77 :: 0x60, 0x27, 0x71, 0xD8, 0xAB, 0x80,
    340.90 m
    New York
    7,209
    First you are not crazy. Received my BMP390 from Adafruit today and hooked it up to a Teensy 4.0 and got the same results that you showed in your post #13. Tried a couple of things but was failing but then I went to the Issues page of the Github library and ran across this Issue: Limited reading performance due to strange `delay(40)` in code there response was anything less than helpful - basically go ask Bosch.
    Ran across this before so I went ahead and comment the delay(40) out and lo and behold started getting data:
    Temperature = 22.46 *C
    Pressure = 1014.60 hPa
    Approx. Altitude = -11.21 m
    Temperature = 22.45 *C
    Approx. Altitude = -11.20 m
    Temperature = 22.42 *C
    Pressure = 1014.64 hPa
    Approx. Altitude = -11.59 m
    I believe we ran across something like this before but will have to do some research to figure out the final fix.
    EDIT: Going through the manual and the code see no reason for the 40ms delay.
    New York
    7,209
    Just as a quick follow up to yesterday's post I just tested the sketch on the Uno, Due, Mega and a Teensy 3.5 with the delay(40) removed and it seemed to work with an issue.
    Jul 2020
    15
    I have been laughing at the solution to this, i spent a reasonable amount of time altering and changing the delay40; and looking for any changes.............
    I just never thought to comment it out !!
    Thank you and much appreciated, i will follow up on my Adafruit post with the answer for others.
