Results 1 to 2 of 2
Thread: Help! Tsynth / Audio board problem with lifted VGND pad
    Dec 2020
    1
    I've accidently managed to remove the VGND pad from my audio board. Is there another pad / I can jumper the connection to to achieve the same result?
    Thanks!
    Apr 2019
    132
    Hello, yes probably. If it's the VGND pad where the jack is soldered, used the VGND pad underneath:
    https://www.pjrc.com/store/teensy4_audio_back.jpg
    You can email the TSynth developer directly for help. He's usually in a good mood most days.
