Results 1 to 5 of 5
Thread: Teensy LC DAC only outputting 0-1.5V?
    I'm have a strange issue with using the DAC on a Teensy LC. This code works fine on a Teensy 3.2, so I'm a bit confused.. maybe I'm missing something obvious?
    The code basically reads the ADC value at A9 (at 16 bits) and then outputs the reading as 12 bits to the DAC pin. It works fine from 0 to 1.5V and then just holds 1.5V as the readings from A9 continue to increase.
    #include <ResponsiveAnalogRead.h>
    ResponsiveAnalogRead ring(A9, false);
    uint8_t dacpin = A12; // pin for DAC (A14 on Teensy 3.2, A12 on Teensy LC)
        Serial.begin(115200);      // start Serial connection for debug console
        delay(2000);               // chill for a bit
        analogWriteResolution(12); // DAC
        pinMode(dacpin, OUTPUT);   // DAC
        analogWrite(dacpin, 0);    // set DAC to 0V.
        ring.setAnalogResolution(65536);
        analogReadAveraging(16); // set analog read averaging (1 - 32) 16 tested really good here.
        analogReadRes(16);       // 0 - 65535
        ring.update();
        dopitchfreeze();
    void dopitchfreeze(void)
        analogWrite(dacpin, ring.getValue() >> 4);
        Serial.print("Dac to ");
        Serial.print(ring.getValue() >> 4);
        Serial.print("\n");
    I'm getting:
    Dac to 625 (.5V)
    Dac to 1254 (.995V)
    Dac to 1634 (1.3V)
    Dac to 1906 (1.475V)
    Dac to 2360 (1.480V)
    Dac to 3193 (1.480V)
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    518
    The issue is this line:
    Just delete that line and the DAC outputs the full voltage range. See this post for details.
    Regards,
    Paul
    13,737
    Not sure this line is needed or helping :: pinMode(dacpin, OUTPUT); // DAC
    Try adding this line in setup() : analogReference(EXTERNAL);
    Regards,
    Paul
    That worked thanks Paul. Should this line ever be used to configure a DAC on any teensy or should it be removed even when a Teensy 3.2 is the target?
    13,737
    AFAIK :: Setting pinMode() is needed for DIGITAL usage. When used as an ANALOG the I/O functions prepare the pin as needed to function, and doing pinMode() on them only interferes.
    PaulS got the answer faster because it seemed it might be an analogReference() issue - and went looking for that (reading the thread title) before reading the code more closely and seeing pinMode()
