SimonWakley
Anyone know if it is possible to have 2 of the Wiz820io units on a teensy.
I have tried and I can get one or the other to work but not both at the same time. If I enable both only one works.
Possible to do with the chip select line. (Or a code error?)
Dual EtherNET
C0nnect up 2 wiznet chips and use the same MISO MOSI CLK lines and even the same reset, but
use a different chip select and maybe we can poll them?
Simon Wakley Jan 2021
This code is in the public domain.
#define WIZ1 1
#define WIZ2 1
#include <Ethernet.h>
#include <EthernetUdp.h>
#define GREEN_LED 20 // Just a green LED on Pin 20 to ground
#define WIZNET_RESET 6 // Wired to both Resets
#define WIZNET1_CS 17 // Wiznet1 Chip Select nSS
#define WIZNET2_CS 18 // Wiznet2
#ifdef WIZ1
byte mac1[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip1(192, 168, 1, 179);
unsigned int localPort1 = 8899; // local port to listen on
#ifdef WIZ2
byte mac2[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEC };
IPAddress ip2(192, 168, 1, 177);
unsigned int localPort2 = 8877; // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; // buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
#ifdef WIZ1
EthernetUDP Udp1;
#ifdef WIZ2
EthernetUDP Udp2;
void EthSelect(int id)
if (id == WIZNET1_CS)
digitalWrite(WIZNET2_CS, HIGH); // Turn it off
Ethernet.init(WIZNET1_CS);
digitalWrite(WIZNET1_CS, HIGH); // Turn it off
Ethernet.init(WIZNET2_CS);
pinMode(GREEN_LED, OUTPUT);
// This is to disable the Wiz until ready to go
pinMode(WIZNET_RESET, OUTPUT);
digitalWrite(WIZNET_RESET, LOW);
delay(10);
digitalWrite(WIZNET_RESET, HIGH);
pinMode(WIZNET1_CS, OUTPUT);
pinMode(WIZNET2_CS, OUTPUT);
#ifdef WIZ1
// Wiznet Chip Select Line
//Ethernet.init(WIZNET1_CS); // Most Arduino shields
EthSelect(WIZNET1_CS);
// start the Ethernet
Ethernet.begin(mac1, ip1);
#ifdef WIZ2
// start the second Ethernet
Ethernet.begin(mac2, ip2);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
#ifdef WIZ1
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware)
Serial.println("Ethernet shield 1 was not found. Sorry, can't run without hardware. ");
if (Ethernet.linkStatus() == LinkOFF)
Serial.println("Ethernet cable 1 is not connected.");
#ifdef WIZ2
EthSelect(WIZNET2_CS);
//Ethernet.init(WIZNET2_CS); // Most Arduino shields
Serial.println("Ethernet shield 2 was not found. Sorry, can't run without hardware. ");
Serial.println("Ethernet cable 2 is not connected.");
// start UDP
#ifdef WIZ1
Udp1.begin(localPort1);
#ifdef WIZ2
Udp2.begin(localPort2);
int count = 0;
// if there's data available, read a packet
int packetSize;
#ifdef WIZ1
//Ethernet.init(WIZNET1_CS); // Device 1
packetSize= Udp1.parsePacket();
if (packetSize)
Serial.print("Received packet from 1 of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp1.remoteIP();
for (int i=0; i < 4; i++) {
Serial.print(remote, DEC);
if (i < 3) {
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp1.remotePort());
// read the packet into packetBufffer
Udp1.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.println("Contents:");
Serial.println(packetBuffer);
// send a reply to the IP address and port that sent us the packet we received
Udp1.beginPacket(Udp1.remoteIP(), Udp1.remotePort());
Udp1.write(ReplyBuffer);
Udp1.endPacket();
#ifdef WIZ2
//Ethernet.init(WIZNET2_CS); // Device 2
packetSize= Udp2.parsePacket();
if (packetSize)
Serial.print("Received packet from 2 of size ");
IPAddress remote = Udp2.remoteIP();
if (i < 3) {
Serial.print(".");
Serial.println(Udp2.remotePort());
Udp2.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Udp2.beginPacket(Udp2.remoteIP(), Udp2.remotePort());
Udp2.write(ReplyBuffer);
Udp2.endPacket();
delay(10);
count++;
// Always nice to see a flickering light to know it's running
if ((count % 10) < 5)
digitalWrite(GREEN_LED, HIGH);
digitalWrite(GREEN_LED, LOW);
Dual EtherNET
#define WIZ1 1
#define WIZ2 1
#ifdef WIZ1
#ifdef WIZ2
#ifdef WIZ1
EthernetUDP Udp1;
#ifdef WIZ2
EthernetUDP Udp2;
delay(10);
#ifdef WIZ1
#ifdef WIZ2
while (!Serial) {
#ifdef WIZ1
#ifdef WIZ2
// start UDP
#ifdef WIZ1
#ifdef WIZ2
int count = 0;
int packetSize;
#ifdef WIZ1
if (packetSize)
if (i < 3) {
Serial.print(".");
Udp1.endPacket();
#ifdef WIZ2
if (packetSize)
if (i < 3) {
Serial.print(".");
Udp2.endPacket();
delay(10);
count++;
