Results 1 to 3 of 3
Thread: recieve Sysex messages
    Dec 2020
    4
    Hello!
    Hope you can help me, probably is easy the answer but I am totally struggling with Sysex.
    I am sending via Webmidi, SysEx message to Teensy
    for example
    WebMidi.getOutputByName('Teensy MIDI').sendSysex(66, [10, 23, 31, 48, 52, 100]);
    I am trying to get in Teensy the array [10, 23, 31, 48, 52, 100] to assign these values to different variables.
    I know that this function receives Sysex, but how can I get this array?
    void mySystemExclusive(byte *data, unsigned int length) {
    Thanks so much in advance!
    Feb 2020
    Dublin, Ireland
    75
    Take a look at the example
    EXAMPLES|TEENSY|USB_MIDI|InputFunctionsComplete
    It should help you,
    All the best,
    Alan
    Dec 2020
    4
    Hello AlanK,
    thanks for the reply.
    yes, I started with this example. I think it is used a function calls "printBytes" to transform the income values to HEX (hexadecimal) values.
    I wondering if there is a simple way without this conversion. But now I found another example calls "InputRead" that uses usbMIDI.getSysExArray(). I think that is what I am looking for.
    Thanks!
