Teensy 4.1 and TouchScreenUSB as HID
skyy
I'm trying to get single and multi touch working on a windows 10 machine, but without any luck.:confused:
On an android device single and multi-touch they both seem to work perfectly,
however on Ubuntu 20 only single-touch example is working and on my main target "Windows 10" none of them worked :(
Windows 10 detects the touchscreen as HID device but no inputs
I have a Teensy 4.1, with Arduino 1.8.13 and Teensyduino 1.53.
i have tried to select USB type Keyboard+ touchscreen then tried Keyboard+Mouse+Touchscreen nothing changed.
So to summarize my tests:
Android:
- Single-touch -> OK
- Mulit-touch -> OK
Ubuntu
- Mulit-touch -> the cursor disappear "so i think it moves but no press?"
Windows:
- Single-touch -> Nothing happens
- Mulit-touch -> Nothing happens
The code below i got from the examples modified it so it run without the button for multi-touch,
// Multi-touch example
int yoffset = 8000;
  TouchscreenUSB.begin();
void drawcircle(int x, int y) {
  float arc = 2.0 * PI / 10.0;
  float r = 3000.0;
  for (float angle = 0; angle < arc; angle += 0.01) {
    for (int i = 0; i < 10; i++) {
      float ph = arc * (float)i;
      TouchscreenUSB.press(i, r * cosf(angle + ph) + x, r * sinf(angle + ph) + y);
    delay(10);
    TouchscreenUSB.release(i);
  drawcircle(16000, yoffset);
  yoffset += 4200;
  if (yoffset > 24000) yoffset = 8000;
  delay(5000);
Any ideas or direction?
Quick update, since all usb types that support Touchscreen don't have a Serial option i added
 Keyboard.print("Hello World ");
just before
delay(5000);
i noticed a weird behavior like the Teenssy become non-responsive for couple of seconds and it write something like this
Hello WWWWWWWWWWWWWWWHello WWWWWWWWWWWWWWHeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeello WHello WWWWWWWWWWWWWWWHello WWWWWWWWWWWWWWWH
first thoughts was that the delay might be blocking something so i tried it with millis()
int yoffset = 500;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 5000;
void drawline(int x, int y) {
  lastDebounceTime = millis();
 for (int i=0; i < 1000; i += 10) {
   TouchscreenUSB.press(0, x + i, y + i/13);
   delay(10);
 TouchscreenUSB.release(0);
  if ((millis() - lastDebounceTime) > debounceDelay) {
    drawline(600, yoffset);
    yoffset += 120;
    if (yoffset > 1000) yoffset = 500;
unfortunally that did not change anything, still i'm getting something like:
Hello WWWWWWWWWWWWWWWHello WWWWWWWWWWWWWWWHello WWWWWWWWWWWWWWWHello WWWWWWWWWWWWWWWHello WWWWWWWWWWWWWWWH
Here is a preview on the Android Screenshot_20210106-191330_Touch Screen Test.jpg
