Hi folks!
After many years of Arduino- and ESP-tinkering the Teensy found its way in my cave.
Now i have my first project which will have as heart the Teensy 4.0. Especially the possibility to emulate a touchpad with this one appealed to me.
Rough key data on what I intend to do:
PC send graphical data to a RaspberryPi on which Python will analyze them with OpenCV.
Based on the analyzed data the Python-Script will send data through Serial to the Teensy.
This Teensy is connected via Serial to the RasPi and via USB to the PC.
The data comming from RasPi-Serial will evaluated by the Teensy and then it send some Keyboard/Mouse-commands to the PC.
The part with analyzing the graphical data from PC on RasPi is mostly done, as well the sending data through Serial to [a microcontroller].
Now I would like to use python (in whatever form, Micro- or Circuit) to program the Teensy, but i don't know if i can access the function there to send mouse inputs absolutely based on the resolution of the PC-Monitor. (FYI: PC is running Windows 10)
Under Teensyduino this is possible without any problems, as Paul shows in this video.
For CircuitPython i only could find libraries for working _with_ touchscreens not acting _as_ a touchscreen.
Or did I search the wrong haystack?
Maybe someone knows a library that can be used under python to emulate a touchscreen with the Teensy and could point me in the right direction.
Thanks in advance and stay save!
