Results 1 to 6 of 6
Thread: SGTL5000 line-out sometimes doesn't work?
    Jul 2020
    10
    Hey all. I'm using a teensy 4.1 on a custom PCB with the audio shield replicated on it, and I'm facing an issue where I'm sometimes getting little to no signal on the SGTL5000's line-output, which I have hooked up to my audio interface.
    When I upload the PlaySynthMusic example sketch that comes with the Audio library, the line-out and the headphone out both work fine. However, when I upload my own code, the headphone output works fine, but I'm getting only a very small signal on line-out(checked it with scope) which is not really useable. What's weird is that in my code, I setup and enable the codec in the exact same way as the example sketch, yet, for some reason, the line output just doesn't work.
    So I know it's some issue with the code and not the hardware, but I haven't been able to track it down. I even tried explicitly setting lineOutLevel and unmuteLineout to no effect. Does anyone know what might be causing this? I'm stumped.
    I've attached my entire code as a zip, but the following are the only places where I address the codec directly in my code:
    //audio network
    AudioControlSGTL5000     codec;
      codec.enable();
      codec.volume(0.45);
      //other stuff
      int n = analogRead(15);
      if (n != vol) {
        vol = n;
        codec.volume((float)n / 1023);
      //other stuff
    1_CombinedSystem.zip
    Jul 2020
    667
    You should be calling codec.lineOutLevel (). the volume method is for headphones only I'm pretty sure.
    Jul 2020
    10
    Oh yeah, I only intended for the headphone volume to be controlled. I want the line-out level to stay at its default (29) all the time.
    I tried adding codec.lineOutLevel (29) in the loop() to see if that would help anything, but I'm still getting the same results, i.e. a very tiny/no signal on line-out. And like I said, changing it to lineOutLevel (13) doesn't help either.
    Jul 2020
    667
    Hmm, that's odd - perhaps this PCB has some hardware issue?
    Jul 2020
    10
    I'm not ruling it out, but I do think that a hardware issue is unlikely. Its pretty much a direct connection to the SGTL5000's line-out pins (through dc blocking caps ofc) and more importantly, line-out works fine when I run the PlaySynthMusic example sketch
    Jul 2020
    10
    I stand corrected. I put the audio ground loop noise isolator thing between my board (which was being powered via usb) and my interface, and now line-out is working as expected. I guess it some kind of a hardware issue. I have no idea why this changed anything but I'm glad it's working now. If anyone has any insight about why this fixed the problem, I would love to know.
