Results 1 to 15 of 15
Thread: invert phase audio signal
    Jan 2021
    France
    44
    I would like to reverse the phase of the audio signal (180 ) to experiment around the cancellation of sounds.
    I tried with a mixer to set the gain to -1 (i tried too with the amp), but the signals are not inverted as shown in the oscillogram.
    (sine signal 2K700hz 1vp-p, red : input, blue : ouptut).
    if i change the frequency, the offset between input and output changes, but is never 180 degrees
    my code :
    #include <SerialFlash.h>
    AudioInputI2S            i2s2;           //xy=214,235
    AudioMixer4              mixer1;         //xy=547,366
    AudioOutputI2S           i2s1;           //xy=879,224
    AudioConnection          patchCord1(i2s2, 0, mixer1, 0);
    AudioConnection          patchCord2(mixer1, 0, i2s1, 0);
    AudioControlSGTL5000     sgtl5000_1;     //xy=857,517
    //const int myInput = AUDIO_INPUT_MIC;
      AudioMemory(50);
      // Enable the audio shield. select input. and enable output
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.4); //
      mixer1.gain(0,-1);
      mixer1.gain(1,0);
      mixer1.gain(2,0);
      mixer1.gain(2,0);
    Do you know if there is another way?
    thanks in advance
    Fred (Teensy v4.0+ audio Adapter)
    3,117
    if you insert an audio object then you have to consider a 128 sample delay.
    So, insert two mixers in parallel one with +1 and the other with -1, then you should get the desired effect
    Jan 2021
    France
    44
    if I understand correctly, I put an audio object (microphone), connected to a delay object, then then two mixers?
    3,117
    no, I was suggesting
    i2s ->mixer (+1) -> I2S left
    |-> mixer (-1) -> I2S right
    so left and right path have same internal delays
    Jan 2021
    France
    44
    I understand the 1st line connection, but Im not sure for the 2nd : what is *I* on the 2nd line ?
    (Sorry Im a newbie).
    I only have one audio source (microphone or low frequency generator)
    3,117
    sorry about formating
    here is the audio code
    AudioInputI2S            i2s1;           //xy=182.0023956298828,239.00240325927734
    AudioAmplifier           amp1;           //xy=375.0023880004883,195.00239181518555
    AudioAmplifier           amp2;           //xy=377.002384185791,256.0023946762085
    AudioOutputI2S           i2s2;           //xy=573.0023956298828,217.00240325927734
    AudioConnection          patchCord1(i2s1, 0, amp1, 0);
    AudioConnection          patchCord2(i2s1, 1, amp2, 0);
    AudioConnection          patchCord3(amp1, 0, i2s2, 0);
    AudioConnection          patchCord4(amp2, 0, i2s2, 1);
    I use amp instead of mixer; amp1 is to be set gain +1, and amp2 is gain -1
    you can copy and import the above lines into audio gui to see what I mean.
    Jan 2021
    France
    44
    ok, now can you tell me :
    - where i connect my audio signal (sinusoidale 1khz with an external generator) : left or right or both line in ?
    - where i connect my oscilloscope : left or right line out ?
    thanks
    3,117
    Quote Originally Posted by fred_france View Post
    thanks
    the way it is wired now, connect audio signal to both line in and oscilloscope channel 1 to ,say, left and channel 2 to right
    you could simplify, by connecting both amp inputs to same i2s input channel (left or right)
    Jan 2021
    France
    44
    By connecting the two channels of the oscilloscope on L and R of line Out, it works well, the signals are well opposite at 180 (see the image below)
    But if I plug in the oscilloscope like this:
    - oscillo channel 1: on the input (on the sine generator)
    - oscillo channel 2: on one of the LineOut outputs
    > the signals are out of phase but not at 180 (same as what i show in my post #1)
    I think there is a processing time which makes it impossible to reverse the input signal in real time
    Am I clear in my explanation?
    3,117
    They cannot be 180 deg out of phase. there is a fixed travel time through the audio library
    Output is NEVER without delay to input.
    AFAIK
    I2S-input: data are buffered for 128 samples (2.9 ms @44.1 kHz)
    Amp: process data block-wise (another 2.9 ms)
    I2S-output: buffered data are output (no further delay)
    But you can mesure with oscilloscope
    The way your picture is made, both data streams are delayed the same amount of time but one is flipped, so you get the desired result.
    Cheltenham, UK
    164
    He is trying to experiment with NOISE CANCELLING. Broadcasting an inverted signal in an attempt to cancel out ambient noise.
    Due to the inevitable processing delay, will not work by playing output through a speaker to cancel ambient noise.
    Lotus played round with this about 10 years ago. Not sure how successful they were.
    Will work if used for a headphone where ambient and cancel signal are both delayed by the same or similar amount.
    Of course the headphones need to be isolated from ambient noise otherwise a sort of echo might ensue.
    On the other hand just isolate the headphones from the environment (over ear headphones) and play whatever you want to through headphones.
    Jan 2021
    France
    44
    Thank you for your answers
    is it not possible to reduce the processing time of 2.9 ms by reducing for example the bandwidth? (for example: 200hz- 2khz instead of 20hz-20khz)?
    3,117
    The 2.9 ms is result of acquisition buffer (128 samples) and sampling rate (44.1 kHz) so you must change one of the two values to change the delay.
    This requires changing some basic parameters. It can be done, but not sure if it brings you forward.
    What ever you do in synchron parallel audio processing (one channel straight, other channel phase shifted), you must make sure that parallel paths have same delay.
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    518
    If your *only* goal is to create an inverted audio signal [and no other processing], then I would go for opamps.
    See here for basic circuits. One inverting opamp and one non-inverting opamp and feed them both with the same input signal.
    With a high-speed opamp you end up with an input-to-output delay in the sub-microsecond range.
    Paul
    Jan 2021
    France
    44
    yes I saw that there is a lot of electronic diagram with the op amps, I will look at that.
    thank you all very much for your help and your time
