grease_lighting
I'm working on a new project that uses an RA8875 display and am having problems with the display not functioning. It is a 5-inch Buydisplay.com ER-TFTM050 that uses the GSL1680 touch screen which is working. The display is all white, the RESET pin is tied high. I've used this display in a previous project that uses a Teensy 3.5, the Teensy 3.6 also functions in that project. I tried installing the Teensy 3.2 in that project as it uses pins common to the T3.5 for the display and it does not work. The display is still white screen, but the touch panel functions.
Today I made some socket extenders so the SD Card end of the T3.5 clears components on my (new project) PCB and tried it with the TFTM050 display and it is working.
I'm using whatever drivers are in the IDE package ARDUINO 1.8.5 running with Teensyduino 1.40. Any ideas?
Thank You for your help.
