sinf() on Teensy 4.0
alexisW
New member
Running some simple benchmarks on the Teensy 4.0 (quite impressive BTW) showed that the standard sinf() function is surprisingly (and inappropriately) slow for large arguments (>> 2 pi). Note the results are correct, just slow.
My tests generated the table below; note the top right value in the table compared to the other sine implementations. Note that sinf() does not behave this way in other environments, e.g on the (Linux) development computer.
Small ArgumentsLarge Arguments
sinf()0.083 usec3.090 usec
sin()0.181 usec0.374 usec
arm_sin_f32()0.080 usec0.082 usec
(If this should just be directed elsewhere, what-version / who-is-the-author of the libm.a being used on the Teensy 4.0?)
Many thanks!
Details:
Board: Teensy 4.0
Arduino 1.8.13
Teensyduino 1.53
Dev environment: Linux 64
Code used (set bigValues flag to toggle between big/small values and/or change which sine function at line 35)
#include <arm_math.h>  // only needed for the arm_sin_f32() comparison case
    const int NIter = 10000;       // test length
    const bool bigValues = true;   // true for "big" values, false for small
    float sum = 0;                 // dummy summation (thwart optimization)
    // time of just the loop (without sine call)
    uint32_t baseStartT = micros();
    for (int i=0; i<NIter; i++) {
        float t = i * 0.00001;
        if (bigValues) t += 1000;
        sum += t;
    uint32_t baseDur = micros() - baseStartT;
    // timing of loop with a sine evaluation
    uint32_t sinStartT = micros();
        // using only one of the following cases
        sum += sinf(t);            // float
        //sum += sin(t);           // double
        //sum += arm_sin_f32(t);   // float, arm optimized
    uint32_t sinDur  = micros() - sinStartT;
    // average time for loop without sine evaluation
    double loopPer =sinDur / double(NIter);
    // average time just the sine evaluation
    double sinPer  = (sinDur - baseDur) / double(NIter);
    // print the results
    Serial.print("raw time per iter=");
    Serial.print(loopPer, 3);
    Serial.print(" usec, time per sin eval=");
    Serial.print(sinPer, 3);
    Serial.print(" usec, sum=");
    Serial.println(sum);  // make sure it's not optimized out
Teensy uses the GNU Arm Embedded Toolchain which uses Red Hat / Newlib.
In "our" version is a sinf() bug that leads to the slow calculation. It was fixed in Newlib some time ago.
Workaround for us: Don't use large arguments.
Or try a newer toolchain (Don't try 10.x - does not work good)
Range reduction of large arguments in trigonometric functions is always problematic because PI constant used is inherently inaccurate. There is infamous bug in Intel x87 FPU hardware that causes sin to be inaccurate for large arguments https://randomascii.wordpress.com/2014/10/09/intel-underestimates-error-bounds-by-1-3-quintillion/
ARM of course does not have hardware instructions for sinf, so you have to rely on software implementation that of course may vary.
For this reason, not to be at the mercy of library code, I would advise not to use large arguments at all (use range reduction early so arguments are within -PI..+PI or even better -PI/2 ..+PI/2). Alternatively use tabulated sin values + linear interpolation (that is precisely what arm_sin_f32() uses).
You do need sin to work reasonably on largish arguments though, a classic example being in implementing sinc().
First, in almost all practical cases you use windowed sinc.
Second, as I wrote, its better to do range reduction yourself.
