Results 1 to 3 of 3
Thread: Midi to logic controls
    Hello everybody,
    I am currently making a USB MIDI controlled synthesizer. The microcontroller is a teensy 4.1. This should drive 2 dac Max11300 and 7 switch DG333.
    I specify, I am new to programming, I learn a little more every day thanks to you
    To drive the DG333 switches I use the teensy outputs. Each output is linked to a midi control, at the value 0 the output is at 0, at 127 the output is at 3.3v.
    In the order the outputs are linked to the following midi controls:
    outputs ( digital pins) : 11, 4, 23, 5, 7, 20, 17, 3, 35, 16, 30, 32, 34, 36
    midi controls: 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95
    The easiest (at my level) is to create a condition like:
    void OnControlChange (byte channel, byte control, byte value) {
    if (control == 82)
    pinout = 11
    else if (control == 83)
    pinout = 4
    else if ......... so on ....
    the problem is, it's tedious and I'm sure there must be some other solution.
    Jul 2020
    913
    Like switch-case?
    Its good !!! I found the solution !!
    While searching on the forum I found a member who wanted to light leds with midi messages.
    I took its code and I modified it to match the project (I have on / off switches, on / off / on switches, and an on / on / on / on switch.
      const int channel = 1; // MIDI channel
      const int D_PINS = 13; // number of Digital PINS for swith on/off
      const int L_PINS = 10; // number of Digital PINS for swith on1/off/on2
      // define the pins and notes
      const int SW2[D_PINS] = {36, 34, 32, 30, 33, 35, 3, 17, 20, 7, 5, 23, 4};
      const int MIDI_SW2[D_PINS] = {95, 94, 93, 92, 90, 89, 88, 87, 86, 85, 84, 83 ,82 };
      const int SW3_1[L_PINS] = {16, 39, 41, 24, 26, 37, 18, 22, 19, 29};
      const int SW3_2[L_PINS] = {9, 25, 15, 14, 38, 27, 6, 21, 8, 31};
      const int MIDI_SW3[L_PINS] = {96, 97, 98, 99, 100, 101, 106, 107, 111, 102};
      const int SW4_1 = 1;        // SW4_1/SW4_2 is logic control for VCF (12db/24db/hp/bp)
      const int SW4_2 = 2;        //Switch on1/on2/on3/on4
      const int MIDI_SW4 = 112;   //note for Switch (12db/24db/hp/bp)
      const boolean toggled = true;
      boolean state[D_PINS];
          usbMIDI.setHandleControlChange(OnControlChange);
          for (int i=0;i<D_PINS;i++){
            pinMode(SW2[i], OUTPUT);
            digitalWrite(SW2[i], LOW); // Toutes les pins out ont pour valeur LOW
          for (int j=0;j<L_PINS;j++){
            pinMode(SW3_1[j], OUTPUT);
            digitalWrite(SW3_1[j], LOW); // Toutes les pins out ont pour valeur LOW
            pinMode(SW3_2[j], OUTPUT);
            digitalWrite(SW3_2[j], LOW);
            pinMode(SW4_1, OUTPUT);
            pinMode(SW4_2, OUTPUT);
            digitalWrite(SW4_1, LOW);
            digitalWrite(SW4_2, LOW);
        usbMIDI.read();
        void OnControlChange(byte channel, byte controller, byte value)
    {     for (int i = 0; i < D_PINS ; i++)
      {       if (MIDI_SW2[i] == controller)
        {          if (value >= 64)
          {               digitalWrite(SW2[i], HIGH);
                          state[i] = true;
          }        else {
                          state[i] = false;
         for (int j = 0; j < L_PINS ; j++)
      {       if (MIDI_SW3[j] == controller)
        {          if (value >= 84)
          {               digitalWrite(SW3_1[j], HIGH);
                          state[j] = true;
                      else if (value < 84 && value > 42)
              {           digitalWrite(SW3_1[j], LOW);
                          state[j] = false;
                      else if (value < 42)
                          digitalWrite(SW3_2[j], HIGH);
                          state[j] = true;
      {       if (MIDI_SW4 == controller)
        {          if (value >= 96)
          {               digitalWrite(SW4_1, HIGH);
                      else if (value < 96 && value > 64)
               {          digitalWrite(SW4_1, LOW);
                       else if (value < 64 && value > 32)
                          digitalWrite(SW4_2, HIGH);
                      else if (value < 32)
               {           digitalWrite(SW4_1,HIGH);
