Hello!
Currently, I am trying to use Encoders inside my code. I am using VSC. For some reason though, the only output I get is -1 and sometimes it jumps to -2 if I twist the knob fast enough.. I would be happy about any help, thank you!
my platform.ini:
main.cpp:
#include <Arduino.h>
#include <SerialFlash.h>
#include <Encoder.h>
#include "Display.h"
#include "Sequencer.h"
Display display;
Sequencer sequencer;
int b1 = 0;
int b2 = 0;
int b3 = 0;
int b4 = 0;
void ADSR(float att, float dec, float sus, float rel)
// b1 = digitalRead(20);
b2 = digitalRead(2);
b3 = digitalRead(3);
b4 = digitalRead(4);
display.init();
display.update();
sequencer.update();
sequencer.h:
#ifndef Sequencer_h
#define Sequencer_h
#include <array>
#include <MegunoLink.h>
#include <Filter.h>
#include "Encoder.h"
class Sequencer
public:
Sequencer();
void start();
void stop();
unsigned int counter(float interval);
void stepButtons();
void buttonsAbfragen(int zaehler, int digitalPin);
void stepLED();
void update();
float getBPMInterval();
void muxUpdate();
long encoder();
float mapper(float x, float in_min, float in_max, float out_min, float out_max);
int _deflectionRate;
int frequency1 = {160};
int frequency2 = {200};
int frequency3 = {140};
int frequency4 = (110);
ExponentialFilter<long> ADCFilter;
std::array<float, 4> attack;
std::array<float, 4> decay;
std::array<float, 4> sustain;
std::array<float, 4> release;
std::array<float, 4> amplitude;
std::array<int, 4> frequency{{frequency1, frequency2, frequency3, frequency4}};
std::array<int, 4> m_stepLEDPin{{3, 4, 5, 6}};
std::array<int, 4> m_stepButtonPin{{0, 1, 14, 15}};
std::array<boolean, 4> m_stepState{{true, true, true, true}};
std::array<boolean, 4> digitalReadValues;
int16_t *wave1Values;
float defaultAttackValue = {50};
float defaultDecayValue = {200};
float defaultSustainValue = {200};
float defaultReleaseValue = {200};
float defaultVolume = {0.3};
unsigned long m_lastMillis;
float m_interval = (60.0 / average_bpm) * 1000.0;
unsigned long m_stepStateInterval = 20;
unsigned int m_STEPNUM = 4;
unsigned int m_step = 0;
const int numReadings = 5; // Anzahl der Readings
int readings[5]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
float average = 0; // the average
int inputPin = A3; // Analog input
int average_bpm = 120;
int average_bpm_alt = 120;
unsigned long m_BPMInterval = 400;
int m_AnalogThreshold = 3;
int ADCFilterBefore;
float interval;
float minBPM = 40.0;
float maxBPM = 800.0;
int pin_Out_S0 = 0;
int pin_Out_S1 = 1;
int pin_Out_S2 = 2;
int buttonState[48];
int bit1 = 0;
int bit2 = 0;
int bit3 = 0;
long positionEnc1 = -999;
Encoder Enc1;
AudioSynthWaveform *waveform = new AudioSynthWaveform[4];
AudioEffectEnvelope *envelope = new AudioEffectEnvelope[4];
AudioMixer4 mixer1;
AudioOutputI2S i2s1;
AudioConnection patchCord1;
AudioConnection patchCord2;
AudioConnection patchCord3;
AudioConnection patchCord4;
AudioConnection patchCord5;
AudioConnection patchCord6;
AudioConnection patchCord7;
AudioConnection patchCord8;
AudioConnection patchCord9;
AudioConnection patchCord10;
Display _display;
private:
sequencer.cpp:
Sequencer::Sequencer() : patchCord1(waveform[1], envelope[1]),
patchCord2(waveform[2], envelope[2]),
patchCord3(waveform[3], envelope[3]),
patchCord4(waveform[0], envelope[0]),
patchCord5(envelope[3], 0, mixer1, 3),
patchCord6(envelope[2], 0, mixer1, 2),
patchCord7(envelope[0], 0, mixer1, 0),
patchCord8(envelope[1], 0, mixer1, 1),
patchCord9(mixer1, 0, i2s1, 0),
patchCord10(mixer1, 0, i2s1, 1),
_display(),
ADCFilter(60, 0),
Enc1(21, 22)
for (int i{0}; i < 4; ++i)
envelope[i].attack(attack[i]);
envelope[i].decay(decay[i]);
envelope[i].sustain(sustain[i]);
envelope[i].release(release[i]);
AudioMemory(20);
sgtl5000_1.enable();
sgtl5000_1.volume(defaultVolume);
attack.fill(defaultDecayValue);
decay.fill(defaultDecayValue);
sustain.fill(defaultSustainValue);
release.fill(defaultSustainValue);
amplitude.fill(defaultVolume);
for (unsigned int i{0}; i < 4; ++i)
mixer1.gain(i, defaultVolume);
waveform[i].begin(WAVEFORM_SINE); // WAVEFORM_SINE expands to 0 WAVEFORM_ARBITRARY expands to 4
waveform[i].amplitude(amplitude[i]);
waveform[i].frequency(frequency[i]);
pinMode(m_stepLEDPin[i], OUTPUT);
pinMode(m_stepButtonPin[i], INPUT_PULLUP);
float Sequencer::getBPMInterval()
int RawValue = analogRead(A2);
ADCFilter.Filter(RawValue);
if ((millis() - m_lastMillis) > m_BPMInterval && ADCFilterBefore != ADCFilter.Current() && (ADCFilterBefore - ADCFilter.Current() > m_AnalogThreshold))
m_lastMillis = millis();
ADCFilterBefore = ADCFilter.Current();
// subtract the last reading:
total = total - readings[readIndex]; // Alle analoge Inputwerte zusammenaddiert, wobei der Wert der neuen Loop abgezogen wird (zieht den nullten Wert ab)
// read from the sensor:
readings[readIndex] = RawValue;
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
if (readIndex >= numReadings)
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
average_bpm = mapper(average, 1.0, 1023.0, minBPM, maxBPM);
if (average_bpm != average_bpm_alt)
average_bpm_alt = average_bpm;
return m_interval;
unsigned int Sequencer::counter(float interval) // Returns the current position
if ((millis() - m_lastMillis) > getBPMInterval()) // m_interval = 1000 ---> 60 bpm , m_interval = 500 ---> 120bpm
m_step++;
if (m_step == m_STEPNUM)
m_step = 0;
return m_step;
void Sequencer::stepButtons()
std::array<boolean, 4> digitalReadValues = {digitalRead(0), digitalRead(1), digitalRead(14), digitalRead(15)};
for (unsigned int i{0}; i < digitalReadValues.size(); ++i)
if ((millis() - m_lastMillis) > m_stepStateInterval)
if (digitalReadValues[i] == LOW) // LOW = GEDRÜCKT
m_stepState[i] = !m_stepState[i];
void Sequencer::stepLED()
if (_display.isTouched())
wave1Values = _display.getArray();
waveform[0].arbitraryWaveform(wave1Values, 20000);
counter(getBPMInterval()); //No constructor needed because you already wrote Sequencer::stepLED()
for (unsigned int i{0}; i < m_stepLEDPin.size(); ++i)
if (counter(getBPMInterval()) == 0)
digitalWrite(m_stepLEDPin[0], m_stepState[0]);
digitalWrite(m_stepLEDPin[3], LOW);
envelope[0].noteOn();
waveform[0].amplitude(m_stepState[0]);
waveform[0].frequency(frequency[0]);
else if (counter(getBPMInterval()) == i)
digitalWrite(m_stepLEDPin[i], m_stepState[i]);
digitalWrite(m_stepLEDPin[i] - 1, LOW);
envelope[i].noteOn();
waveform[i].amplitude(m_stepState[i]);
float Sequencer::mapper(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
void Sequencer::buttonsAbfragen(int zaehler, int digitalPin)
buttonState[zaehler] = digitalRead(digitalPin);
// delayMicroseconds(50);
// Serial.print(buttonState[zaehler]);
// Serial.print(",");
long Sequencer::encoder()
long newEnc1;
newEnc1 = Enc1.read();
Serial.println(newEnc1);
if (newEnc1 != positionEnc1)
positionEnc1 = newEnc1;
return newEnc1;
void Sequencer::muxUpdate()
for (int i = 0; i <= 7; i++)
bit1 = bitRead(i, 0);
bit2 = bitRead(i, 1);
bit3 = bitRead(i, 2);
digitalWrite(pin_Out_S0, bit1);
digitalWrite(pin_Out_S1, bit2);
digitalWrite(pin_Out_S2, bit3);
buttonsAbfragen(i, 14); // Mux 1
buttonsAbfragen(i + 8, 15); // Mux 2
buttonsAbfragen(i + 16, 16); // Mux 3
buttonsAbfragen(i + 24, 17); // Mux 4
buttonsAbfragen(i + 32, 18); // Mux 5
buttonsAbfragen(i + 40, 19); // Mux 6
void Sequencer::update()
encoder();
stepButtons();
stepLED();
muxUpdate();
