#ifndef Display_h
#define Display_h
#include <array>
#include <ILI9341_t3.h>
#include <font_Arial.h>
class Display
public:
Display();
// int getX();
// int getY();
void fillWaveArray();
void clear();
void init();
void drawButtons();
void start();
void touchButton();
int16_t *getArray();
float loPass(float xInput, float xOutput);
boolean pointInRect(int x, float y, float rectX, float rectY, float rectW, float rectH);
boolean isTouched();
TS_Point getPoint();
void update();
void linearInterpolation(TS_Point pTS);
boolean previousIsTouched;
// float mapper(float x, float in_min, float in_max, float out_min, float out_max);
int X_old;
int X;
int maximumX = 256;
int minimumX = 0;
int maximumY = 32767;
int minimumY = -32767;
void draw(TS_Point pTS);
int _heightSquare = 20;
int _widthSquare = 75;
int _gap = 4;
int _beyondDisplay = 400; // Value to use for the else statement of the getX / getY methods
int _radiusOfRoundCorner = 3;
int16_t initValue;
int16_t wave1Values[257] = {initValue};
int _x;
int _y;
boolean _touched;
private:
XPT2046_Touchscreen ts;
ILI9341_t3 tft;
int pointRadius = 2;
char buttonNames[4][10] = { //First bracket indicates the amount of words
"Clear", // second bracket indicates the amount of maximal letters for one string
"Waves"};
Display.cpp:
#include "Display.h"
// XPT2046_Touchscreen ts(CS_PIN); // Instanziierung eines ts Objekts der Klasse XPT2046_Touchscreen
// ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC);
#define TIRQ_PIN 2
#define CS_PIN 8
#define TFT_DC 9
#define TFT_CS 10
Display::Display() : ts(CS_PIN), tft(TFT_CS, TFT_DC)
// Original raw minimum and maximum values:
// X --> 340 bis 3900
// Y --> 200 bis 3850
boolean Display::isTouched()
return ts.touched();
TS_Point Display::getPoint()
int16_t xScaled{0};
int16_t yScaled{0};
TS_Point pUnscaled = ts.getPoint(); // point getter function
if (map(pUnscaled.x, 340, 3900, maximumX, minimumX) < minimumX)
xScaled = minimumX;
else if (map(pUnscaled.x, 340, 3900, maximumX, minimumX) > maximumX)
xScaled = maximumX;
xScaled = map(pUnscaled.x, 340, 3900, maximumX, minimumX);
if (map(pUnscaled.y, 200, 3850, maximumY, minimumY) < minimumY)
yScaled = minimumY;
else if (map(pUnscaled.y, 200, 3850, maximumY, minimumY) > maximumY)
yScaled = maximumY;
yScaled = map(pUnscaled.y, 200, 3850, maximumY, minimumY);
TS_Point pScaled{xScaled, yScaled, 0};
return pScaled;
int16_t *Display::getArray()
return wave1Values;
void Display::drawButtons()
for (int i{0}; i < 4; ++i)
tft.fillRoundRect(_gap + (_gap + _widthSquare) * i, 220, _widthSquare, _heightSquare, _radiusOfRoundCorner, CL(250, 0, 0));
tft.setCursor(26 + ((_gap + _widthSquare) * i), 227);
tft.print(buttonNames[i]);
tft.drawLine(0, 120, 320, 120, CL(255, 255, 255));
tft.drawLine(0, 121, 320, 121, CL(255, 255, 255));
tft.drawLine(0, 119, 320, 119, CL(255, 255, 255));
void Display::clear()
drawButtons();
void Display::start()
Serial.begin(38600);
tft.begin();
tft.setRotation(1);
ts.begin();
ts.setRotation(1);
while (!Serial && (millis() <= 1000))
; // weiß nicht was das ist
boolean Display::pointInRect(int x, float y, float rectX, float rectY, float rectW, float rectH)
boolean ret = false;
if ((x >= rectX) && (x <= (rectX + rectW)) && (y >= rectY) && (y <= (rectY + rectH)))
ret = true;
return ret;
void Display::touchButton()
if (pointInRect(_x, _y, _gap, (240 - _heightSquare), (_widthSquare), (_heightSquare)))
tft.fillRoundRect(_gap, (240 - _heightSquare), _widthSquare, _heightSquare, _radiusOfRoundCorner, CL(250, 100, 0));
clear();
// clearArray();
void Display::draw(TS_Point pTS)
wave1Values[pTS.x] = pTS.y;
// Serial.println(*getArray());
for (int i{0}; i < 257; ++i)
tft.fillCircle(map(i, 0, 256, 0, 320), map(wave1Values[i], -32767, 32767, 0, 240), pointRadius, CL(255, 0, 0));
/* float Display::mapper(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
void Display::linearInterpolation(TS_Point pTS)
if (X_old <= pTS.x)
for (int i = X_old; i < pTS.x; ++i)
wave1Values[i] = map(i, X_old, pTS.x, wave1Values[X_old], wave1Values[pTS.x]);
for (int i = pTS.x; i < X_old; ++i)
X_old = pTS.x;
void Display::init()
start();
clear();
drawButtons();
void Display::update()
if (isTouched())
TS_Point pTS = getPoint();
if (previousIsTouched)
linearInterpolation(pTS);
touchButton();
clear();
draw(pTS);
previousIsTouched = isTouched();
