Results 1 to 14 of 14
Thread: interrupts on pins 13 & 14 doens't work
    interrupts on pins 13 & 14 doens't work on teensy 3.5. + how to call 2 hat switches?
    I'm using 4 rotary encoders in my project on teensy 3.5, and i managed to get the first 2 encoders work great with interrupts. they are connected on pins 51,52,53,54.
    I copied and pasted the same code to the other two encoders, but nothing happens.
    I don't know how to even check if something happens with the interrupts.
    Checked with a scope and the signals are working great.
    i tried looking for an answer about the specific pins, but couldn't find any answer.
    I know i can only use interrupt on digital pins so there shouldn't be any problem with firing the interrupts...
    (just to mention - reading the pins with digitalread is working but the teensy is missing changes)
    any help would be highly appreciated...
    here is the code:
      pinMode (encoderF9A, INPUT); // pin 11
      pinMode (encoderF9B, INPUT);
      pinMode (encoderF14A, INPUT); // analog pin
      pinMode (encoderF14B, INPUT); // pin 13
       attachInterrupt(digitalPinToInterrupt(13), StateofF14B, RISING);
       attachInterrupt(digitalPinToInterrupt(11), StateofF9A, FALLING);
    void StateofF14B() {
    encF14BstateCurrent = digitalReadFast(encoderF14B); // encoderF14B - pin 13
     if ((encF14Bstatelast == LOW) && (encF14BstateCurrent == HIGH)){
            if (digitalReadFast(encoderF14A) == HIGH){
              Serial.println ("left");
              encF14btnleft = true;
              Serial.println ("right");
              encF14btnright = true;
    encF14Bstatelast = encF14BstateCurrent;
    }// StateofF14A
    //----stateofF9A
    void StateofF9A(){
    Serial.println("ISR F9A");// just to check if its even get into the ISR
    encF9AstateCurrent = digitalReadFast(encoderF9A); // encoderF9A - pin 11
    if ((encF9Astatelast == LOW) && (encF9AstateCurrent == HIGH)){
      if (digitalReadFast(encoderF9B) == HIGH){
        Serial.println("right");
        encF9btnright = true;
        encF9btnleft = true;
        Serial.println("left");
    encF9Astatelast = encF9AstateCurrent;
    }//  Stateof F9
    i would also like to know what is the correct syntax to use with more then 1 hat switch? should i declare something?
    That is when using the many axis joystick code.
    Thanks.
    Last edited by giliep; 01-19-2021 at 08:39 PM. Reason: added hat switch question, but cant edit the title
    23,731
    I copied your code into Arduino, but it doesn't compile. Stuff is missing. See below....
    Quote Originally Posted by giliep View Post
    Since you already have the hardware wired up, try opening File > Examples > Encoder > Basic and just change the pin numbers to 11 and 13. That can at least give you a quick confirmation whether your hardware is working and you should focus on the software side, or if you need to check your wiring.
    Here's the errors I see when I tried to verify your program in Arduino
    sketch_jan19a: In function 'void setup()':
    sketch_jan19a:2: error: 'encoderF9A' was not declared in this scope
    sketch_jan19a:3: error: 'encoderF9B' was not declared in this scope
    sketch_jan19a:6: error: 'encoderF14A' was not declared in this scope
    sketch_jan19a:7: error: 'encoderF14B' was not declared in this scope
    sketch_jan19a: In function 'void StateofF14B()':
    sketch_jan19a:16: error: 'encF14BstateCurrent' was not declared in this scope
    sketch_jan19a:16: error: 'encoderF14B' was not declared in this scope
    sketch_jan19a:18: error: 'encF14Bstatelast' was not declared in this scope
       if ((encF14Bstatelast == LOW) && (encF14BstateCurrent == HIGH)) {
    sketch_jan19a:19: error: 'encoderF14A' was not declared in this scope
         if (digitalReadFast(encoderF14A) == HIGH) {
    sketch_jan19a:21: error: 'encF14btnleft' was not declared in this scope
    sketch_jan19a:24: error: 'encF14btnright' was not declared in this scope
    sketch_jan19a:28: error: 'encF14Bstatelast' was not declared in this scope
    sketch_jan19a: In function 'void StateofF9A()':
    sketch_jan19a:38: error: 'encF9AstateCurrent' was not declared in this scope
    sketch_jan19a:38: error: 'encoderF9A' was not declared in this scope
    sketch_jan19a:40: error: 'encF9Astatelast' was not declared in this scope
       if ((encF9Astatelast == LOW) && (encF9AstateCurrent == HIGH)) {
    sketch_jan19a:41: error: 'encoderF9B' was not declared in this scope
         if (digitalReadFast(encoderF9B) == HIGH) {
    sketch_jan19a:43: error: 'encF9btnright' was not declared in this scope
    sketch_jan19a:45: error: 'encF9btnleft' was not declared in this scope
    sketch_jan19a:49: error: 'encF9Astatelast' was not declared in this scope
    Hi Paul,
    Thanks a lot for the answer!
    the code didn't compile because it is a snippet from a very long code... i didn't want to clutter the post.
    I did found out what the problem was. I would be happy to understand the behavior.
    //encoder 9
      //encoder 14
      //Encoder 17
      pinMode (enc17A, INPUT);
      pinMode (enc17B, INPUT);
      //Encoder 16
      pinMode (enc16A, INPUT);
      pinMode (enc16B, INPUT);
      attachInterrupt(digitalPinToInterrupt(enc16A), Stateof16A, CHANGE);
      attachInterrupt(digitalPinToInterrupt(enc17A), Stateof17A, CHANGE);
      attachInterrupt(digitalPinToInterrupt(encoderF14B), StateofF14B, CHANGE);
      attachInterrupt(digitalPinToInterrupt(encoderF9A), StateofF9A, CHANGE);
      //Fanky SW
      for (uint8_t i1 = 0; i1 <= 14; i1++){
        pinMode(i1, INPUT_PULLUP);
    the problem lies in the for loop, which configure the pins as INPUT_PULLUP. what i didn't notice (or thought of) was that the loop is overwriting the INPUT configuration for the encoder pins.
    Once i understood that,and restricted the loop to go up to pin 9. i managed to get interrupts.
    my questions are?
    1. Why INPUT_PULLUP disable the interrupts?
    2. pin encoderF14A = 14 - is there any way at all to get interrupts on this pin? (or at least mimic the behaivor of the interrupt?
    3. un - related question - to address more then 1 hat switch in the many axis joystick would the syntax be:
    joystick.hat(1,angle);
    joystick.hat (2,angle);
    joystick.hat (3,angle);
    i'm asking becuase i get weird results.
    13,422
    Snippets are usually a distraction - better to have the whole code posted if it can't be cut down to a smaller sketch that effectively shows the problem - that's why this :: Forum Rule: Always post complete source code & details to reproduce any issue!
    Many times the self examination of the code to reduce it will lead to the solution, other times the problem area is in a part not included in the snippet.
    Reading the code in the browser can solve some issues on sight when it is all there - but often as Paul did, the code is copied to see in "viewer's editor of choice" and compiled to see it in action to observe and correct.
    Can you post code showing pinMode( 14, INPUT_PULLUP ) failing to get a call to foo() with attachInterrupt( 14, foo, CHANGE) ? AFAIK on CHANGE to or from low that should be called.
    If that pin 14 is always high or associated with any other library or use that would be a first guess. Also not sure what encoderF14B or the other named values has as a pin number, there can only be a single interrupt handler per pin, a subsequent call to attachInterrupt() with the same pin# will replace any existing func() with the new func2().
    23,731
    Any use of pinMode will do this. It completely reconfigures the pin, overwriting the previously set interrupt config.
    Maybe pinMode should check for this case? I'm also considering adding a pinModeFast function, which would omit some of the pinMode features.
    So pinMode (pin#, INPUT) doesn't interfere with the interrupt config? it would be best practice to set the interrupt at the end of the setup?
    I have problem which relates to the hat switches (which is why is asked about the hat switch command).
    for some reason, the computer/joystick, thinks that the UP & RIGHT buttons on the hat switch are always on.
    I couldn't understand how that's possible since i checked the pin status with the serial monitor and everything is in order.
    I also found a post stating that there is a bug on the hat switch API. https://forum.pjrc.com/threads/60620...ght=hat+switch
    Could it be a bug?
    I've also checked on my Mac (not trusting windows 10) and sure enough both buttons are turned on....
    Here's the code (i've shortened the code to the relevant section).
    Am i doing anything wrong?
    #include <Arduino.h>
    int Hat14Down = 0; // F14A
    int Hat14Right = 1; // F14B
    int Hat14Up = 2; // F14C
    int Hat14Left = 3; // F14D
    int Hat9Up = 5; // F9A
    int Hat9Left = 6; // F9B
    int Hat9Down = 7; // F9C
    int Hat9Right = 8; // F9D
    int hat14Switch = 0;
    int hat9Switch = 0;
    int angle = -1;
    int angle2 = -1;
    /*-------------setup-----------------*/
      //rotary encoder
      //Fanky9
      //Fanky14
      //Encoder 17
      //Encoder 16
      //Fanky SW
      for (uint8_t i1 = 0; i1 <= 9; i1++){
     Hat14Down = HIGH; // F14A
     Hat14Right = HIGH; // F14B
     Hat14Up = HIGH; // F14C
     Hat14Left = HIGH; // F14D
     Hat9Up = HIGH; // F9A
     Hat9Left = HIGH; // F9B
     Hat9Down = HIGH; // F9C
     Hat9Right = HIGH; // F9D
    /*-----------------------------------------loop---------------------------------------*/
      // ---------------hat switch F14
      // pin 0 - A - Up
      // pin 1 - B - Left
      // pin 2 - C - Down
      // pin 3 - D - Right
      // pin PB - [4]
      // Read pin values
         Hat14Up = !digitalRead(0); // A
         Hat14Left = !digitalRead(1); // B
         Hat14Down = !digitalRead(2); // C
         Hat14Right = !digitalRead(3); // D
         hat14Switch = digitalRead(4); // switch.
              if ((Hat14Down == 0)
                && (Hat14Right == 0)
                && (Hat14Up == 0)
                && (Hat14Left == 0)) {
                  Joystick.hat(1,-1);
                  if (hat14Switch )
                        Joystick.button(25, LOW);
                        Serial.println( "Button No No NO No :");
                        Serial.print ("14 up  ");Serial.print ("14 Left  ");Serial.print ("14 Down  ");Serial.print ("14 Right  "); Serial.print ("14 Switch  "); Serial.println ("");
                        /*Serial.print("\t");*/Serial.print ("  ");Serial.print (Hat14Up);Serial.print("\t"); Serial.print(" ");Serial.print (Hat14Left);Serial.print("\t"); Serial.print("  ");Serial.print (Hat14Down);Serial.print("\t"); Serial.print("   ");Serial.print (Hat14Right);Serial.print("\t\t"); /*Serial.print("  "); */Serial.print (hat14Switch); Serial.println ("");
                        Serial.println("");
                      else {
                        Joystick.button(25, HIGH);
                        Serial.println( "Button Pressed:");
                        Serial.println("");
          if (Hat14Up == 1 && Hat14Right == 0 && Hat14Left == 0 && Hat14Down == 0) {
            Joystick.hat(1,0);
            Serial.println( "Up Dir:");
            Serial.println("");
          //   if (Hat14Right == 1 && Hat14Up == 1 ) {
          //  Joystick.hat(1,45);
          if (Hat14Right == 1 && Hat14Down == 0 && Hat14Up == 0 && Hat14Left == 0) {
            Joystick.hat(1,90);
           Serial.println( "Right Dir:");
            Serial.println("");
          //  if (Hat14Down == 1 && Hat14Right == 1) {
          //   Joystick.hat(1,135);
          if (Hat14Down == 1 && Hat14Left == 0 && Hat14Right == 0 && Hat14Up ==0)  {
            Joystick.hat(1,180);
            Serial.println( "Down Dir:");
            Serial.println("");
          // if (Hat14Down == 1 && Hat14Left == 1) {
          //   Joystick.hat(1,225);
          if (Hat14Left == 1 && Hat14Down == 0 && Hat14Up == 0 && Hat14Right == 0) {
            Joystick.hat(1,270);
            Serial.println( "Left Dir:");
            Serial.println("");
          // if (Hat14Left == 1 && Hat14Up == 1) {
          //   Joystick.hat(1,315);
    // ---------------hat switch F9
      // pin 0 - A - [5] Up
      // pin 1 - B - [6] Left
      // pin 2 - C - [7] Down
      // pin 3 - D - [8] Right
      // pin PB - [9]
      // Read pin values
        Hat9Up = !digitalRead(5); // A
        Hat9Right = !digitalRead(6); // B
        Hat9Down = !digitalRead(7); // C
        Hat9Left = !digitalRead(8); // D
              if ((Hat9Up == 0)
                && (Hat9Left == 0)
                && (Hat9Down == 0)
                && (Hat9Right == 0)) {
                  Joystick.hat(2,-1);
                  if (digitalRead(9) )
                        Joystick.button(26, LOW);
                      else Joystick.button(26, HIGH);
          if (Hat9Up == 1 && Hat9Left == 0 && Hat9Right == 0) {
            Joystick.hat(2,0);
          //   if (Hat9Left == 1 && Hat9Up == 1 ) {
          //  Joystick.hat(2,45);
          if (Hat9Left == 1 && Hat9Up == 0 && Hat9Down == 0) {
            Joystick.hat(2,90);
          //  if (Hat9Down == 1 && Hat9Left == 1) {
          //   Joystick.hat(2,135);
          if (Hat9Down == 1 && Hat9Right == 0 && Hat9Left == 0)  {
            Joystick.hat(2,180);
          // if (Hat9Down == 1 && Hat9Right == 1) {
          //   Joystick.hat(2,225);
          if (Hat9Right == 1 && Hat9Up == 0 && Hat9Down == 0) {
            Joystick.hat(2,270);
          // if (Hat9Right == 1 && Hat9Up == 1) {
          //   Joystick.hat(2,315);
    }// loop
    @defragster
    i'm not actually using interrupt on pin 14 since it an analog pin (A0 or PTD1).
    7,921
    Paul said, pinMode completely reconfigures the pin.
    This includes interrupts.
    I understand that, I'm not sure why INPUT allows interrupts while INPUT_PULLUP isn't, so i wanted to understand that better
    If i was more familiar with the ARM architecture i would go with direct pin/register method, but it is more complicated then the AVR 8 bit...
    anyway, learned something new, so that's good!.
    Now i want to solve the 2 hat switches problem
    13,422
    Started to write ... that but the p#6 SNIPPET showed attachInterrupt() after pinMode()'s there - yes - that is how it should be done
    7,921
    Tim, got my email?
    13,422
    Tim, got my email?
    Yes, just back to desk and I see email arrived. Will be a couple hours and I'll give it a look. 107 is free here ...
    BTW. this is what i mean by wrong Hat...
    The red one is Windows default i guess and the green one is my Hat Switch, when nothing is pressed
Name:	Hat Switchs .png
    It Looks like this post did solve the problem...
    @pual - Can you confirm ?
    I dont really understand the issue or the solution to be honest...
    I will check on my Mac and update.
    Update: the controller test program on the mac showed the hat switches correctly. So i guess there was a bug in the joystick hat...
    I would be happy if someone more knowledgeable then me can confirm this.
    Also, is there any chance to get read of the red arrow in the hat joy.cpl window?
    Thankss
