Results 1 to 4 of 4
Thread: Teensy 4.1 I2S Pins - Map to different pins?
    Dec 2020
    7
    I'm working with an OCTO2811 and an I2S MEMS Microphone. I have a conflict using the I2S2 IN2 (pin 5). Is it possible to remap to a different pin, such as PIN 41?
    23,727
    Yes, on Teensy 4.0 & 4.1, you can remap to any digital pins, even less than or more than 8 pins if you like.
    In Arduino, click File > Examples > OctoWS2811 > Teensy4_PinList to see how.
    On Teensy LC & 3.x, OctoWS2811 always uses the fixed set of 8 pins.
    Dec 2020
    7
    Thanks for the info. I'm trying to use Teensy 4.1 pins (I2S external microphone) 3-LRCKL, 4-BCLK, 5-RX. I assumed pin 5 was the problem when using the I2S AudioInputI2S2, maybe it's really a pin 4 problem. I remapped pin 5 for the OctoWS2811 and still seem have a conflict when using the I2S Microphone and the LEDs at the same time.
    Iím not using the Audio Shield for this project. I am using the OctoWS2811 Adaptor.
    I'm open to any suggestions on how to use both the OctoWS2811 and either AudioInputI2S or AudioInputI2S2 at the same time.
    Dec 2020
    7
    I almost have this figured out. The conflict is the physical connection on pin 5 between the Teensy 4.1 and the OctoWW2811 Adapter. Still digging...
