Ethernet (TCP) problems with Teensy 4.1
MichaelS
Hey guys!
I have some problems with my Teensy 4.1...
I use Teensyduino 1.53, Arduino 1.8.13, Teensy 4.1, the latest Putty version, the latest verisons of NativEthernet and Fnet.
I tried to use it as a telnet server (https://forum.pjrc.com/threads/65833-Using-Teensy-4-1-as-a-Telnet-Server). But there was the problem that I did not got the clients IP back.
So I tried to fix it but didn't find an answer. I also tried to run the example sketch for the chat server.
 Chat Server
 A simple server that distributes any incoming messages to all
 connected clients.  To use, telnet to your device's IP address and type.
 You can see the client's input in the serial monitor as well.
 Using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
#include <NativeEthernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(169, 254, 239, 179);
//IPAddress myDns(192, 168, 1, 1);
//IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
  // You can use Ethernet.init(pin) to configure the CS pin
  //Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
  // initialize the ethernet device
  Ethernet.begin(mac, ip, subnet);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  // start listening for clients
  server.begin();
  Serial.print("Chat server address:");
  Serial.println(Ethernet.localIP());
  // wait for a new client:
  EthernetClient client = server.available();
  // when the client sends the first byte, say hello:
  if (client) {
    if (!alreadyConnected) {
      // clear out the input buffer:
      client.flush();
      Serial.println("We have a new client");
      client.println("Hello, client!");
      alreadyConnected = true;
    if (client.available() > 0) {
      // read the bytes incoming from the client:
      char thisChar = client.read();
      // echo the bytes back to the client:
      server.write(thisChar);
      // echo the bytes to the server as well:
      Serial.write(thisChar);
Short: it doesn't work.
Ping is working.
Then I tried to analyse the communication between my laptop and the Teensy 4.1. I compared it to the Arduino Uno. The difference is/was that TCP works great with the Arduino, but somehow it doesn't want to work with the Teensy. Here is a small cutout out of wireshark : I tried to get the connection with PuTTy. And this is the result
After this wasn't working, I tried to figure out where the problem is.
So I decided to try if the WebServer example works, because I use port 80 here and HTTP.
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 modified 02 Sept 2015
 by Arturo Guadalupi
// The IP address will be dependent on your local network:
byte mac[] = {
IPAddress ip(169,254, 239, 188);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  while (!Serial) {
  Serial.println("Ethernet WebServer Example");
  pinMode(A1, OUTPUT);
  digitalWrite(A1, HIGH);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
    while (true) {
  // start the server
  server.begin();
  Serial.print("server is at ");
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
This worked well.
Here another picture of the analysis of ping:
The configuration of my ethernet part of the PCB:
Could anybody help me out? I appreciate every hint!
Could there be a bug in the NativeEthernet library? Or is there anyone where this sketch or anything with TCP works?
Thank you!
Regards
MichaelS
