Results 1 to 13 of 13
Thread: Setting i2c pins in teensy 4.1
    Dec 2020
    3
    quite new to Teensy. I'm trying to use an OLED display algonside the Audio Shield on a Teensy 4.1.
    I can get them to work separately, using the default SDA and SCL pins. To use them together I need to set the pins for the display elsewhere (16 and 17), but I cannot find a way to do this. The Wire library says that Wire.setSDA(pin) and Wire.setSCL(pin) work only on Teensy LC & 3.x. I tried them anyway and don't work (as expected).
    I found an i2c library for T4, but I really don't know how to replace the Wire calls in Adafruit's SSD1306 functions.
    How could I set the i2c pins to 16 and 17 in Teensy 4?
    Cheers!
    4,088
    Note, I2C is a shared bus. Each I2C device has an address. This means as long as your OLED display does not use the addresses used by the audio shield (0x0a, 0x1a), you can hook the display on to the same bus. There are some gotchas if you are using higher speeds, or longer wires, but generally it should just work. Typically the SSD1306 displays use the addresses 0x3c or 0x3d.
    The Teensy 4.0 and 4.1 has a second I2C bus that you would access by using 'Wire1' instead of 'Wire'. If you are lucky, your library for the display has an option to use a separate I2C bus. If not, you would need to clone the display library, and rename the files and functions. You would manually change 'Wire' references to 'Wire1'.
    Dec 2020
    3
    Thanks a lot for your clear explanation. I was aware that multiple I2C devices can share a bus, but I was wondering if the audio wouldn't be affected since it requires very high speeds. Not sure how the protocol works though, and I guess the high-speed processing takes place in the Audio shiled, so I'll just go this way for now and try the Wire1 solution if it gives problems.
    Cheers!
    Senior Member fdaniels's Avatar
    Oct 2020
    Ostwestfalen, Germany
    111
    Audio to the Audio Shield goes vie I2S, not I2C, I2C is just used to control the Codec, so need to worry your Display interferes with Audio Data.
    Dec 2020
    3
    Great! Thanks!
    I confirm using Wire1 and Wire2 work with Adafruit_SSD1306.
    Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire2, OLED_RESET);
    That's it.
    Thx MichaelMeissner for the hint.
    Mar 2018
    9
    I'm trying to get an OLED screen working with the Adafruit_SSD1306 library and a Teensy 4.1. Since it seems to work for you, would you share your sketch?
      This is an example for our Monochrome OLEDs based on SSD1306 drivers
      Pick one up today in the adafruit shop!
      ------> http://www.adafruit.com/category/63_98
      This example is for a 128x64 pixel display using I2C to communicate
      3 pins are required to interface (two I2C and one reset).
      Adafruit invests time and resources providing this open
      source code, please support Adafruit and open-source
      hardware by purchasing products from Adafruit!
      Written by Limor Fried/Ladyada for Adafruit Industries,
      with contributions from the open source community.
      BSD license, check license.txt for more information
      All text above, and the splash screen below must be
      included in any redistribution.
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #define SCREEN_WIDTH 128 // OLED display width, in pixels
    #define SCREEN_HEIGHT 64 // OLED display height, in pixels
    // Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
    #define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
    #define NUMFLAKES     10 // Number of snowflakes in the animation example
    #define LOGO_HEIGHT   16
    #define LOGO_WIDTH    16
    static const unsigned char PROGMEM logo_bmp[] =
    { B00000000, B11000000,
      B00000001, B11000000,
      B00000011, B11100000,
      B11110011, B11100000,
      B11111110, B11111000,
      B01111110, B11111111,
      B00110011, B10011111,
      B00011111, B11111100,
      B00001101, B01110000,
      B00011011, B10100000,
      B00111111, B11100000,
      B00111111, B11110000,
      B01111100, B11110000,
      B01110000, B01110000,
      B00000000, B00110000
      // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
      if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
        Serial.println(F("SSD1306 allocation failed"));
        for (;;); // Don't proceed, loop forever
      // Show initial display buffer contents on the screen --
      // the library initializes this with an Adafruit splash screen.
      display.display();
      delay(2000); // Pause for 2 seconds
      // Clear the buffer
      display.clearDisplay();
      // Draw a single pixel in white
      display.drawPixel(10, 10, SSD1306_WHITE);
      // Show the display buffer on the screen. You MUST call display() after
      // drawing commands to make them visible on screen!
      display.display();
      delay(2000);
      // display.display() is NOT necessary after every single drawing command,
      // unless that's what you want...rather, you can batch up a bunch of
      // drawing operations and then update the screen all at once by calling
      // display.display(). These examples demonstrate both approaches...
      testdrawline();      // Draw many lines
      testdrawrect();      // Draw rectangles (outlines)
      testfillrect();      // Draw rectangles (filled)
      testdrawcircle();    // Draw circles (outlines)
      testfillcircle();    // Draw circles (filled)
      testdrawroundrect(); // Draw rounded rectangles (outlines)
      testfillroundrect(); // Draw rounded rectangles (filled)
      testdrawtriangle();  // Draw triangles (outlines)
      testfilltriangle();  // Draw triangles (filled)
      testdrawchar();      // Draw characters of the default font
      testdrawstyles();    // Draw 'stylized' characters
      testscrolltext();    // Draw scrolling text
      testdrawbitmap();    // Draw a small bitmap image
      // Invert and restore display, pausing in-between
      display.invertDisplay(true);
      display.invertDisplay(false);
      testanimate(logo_bmp, LOGO_WIDTH, LOGO_HEIGHT); // Animate bitmaps
    void testdrawline() {
      int16_t i;
      display.clearDisplay(); // Clear display buffer
      for (i = 0; i < display.width(); i += 4) {
        display.drawLine(0, 0, i, display.height() - 1, SSD1306_WHITE);
        display.display(); // Update screen with each newly-drawn line
        delay(1);
      for (i = 0; i < display.height(); i += 4) {
        display.drawLine(0, 0, display.width() - 1, i, SSD1306_WHITE);
        display.display();
        delay(1);
      delay(250);
        display.drawLine(0, display.height() - 1, i, 0, SSD1306_WHITE);
        display.display();
        delay(1);
      for (i = display.height() - 1; i >= 0; i -= 4) {
        display.drawLine(0, display.height() - 1, display.width() - 1, i, SSD1306_WHITE);
        display.display();
        delay(1);
      delay(250);
      for (i = display.width() - 1; i >= 0; i -= 4) {
        display.drawLine(display.width() - 1, display.height() - 1, i, 0, SSD1306_WHITE);
        display.display();
        delay(1);
        display.drawLine(display.width() - 1, display.height() - 1, 0, i, SSD1306_WHITE);
        display.display();
        delay(1);
      delay(250);
        display.drawLine(display.width() - 1, 0, 0, i, SSD1306_WHITE);
        display.display();
        delay(1);
        display.drawLine(display.width() - 1, 0, i, display.height() - 1, SSD1306_WHITE);
        display.display();
        delay(1);
    void testdrawrect(void) {
      for (int16_t i = 0; i < display.height() / 2; i += 2) {
        display.drawRect(i, i, display.width() - 2 * i, display.height() - 2 * i, SSD1306_WHITE);
        display.display(); // Update screen with each newly-drawn rectangle
        delay(1);
      delay(2000);
    void testfillrect(void) {
      for (int16_t i = 0; i < display.height() / 2; i += 3) {
        // The INVERSE color is used so rectangles alternate white/black
        display.fillRect(i, i, display.width() - i * 2, display.height() - i * 2, SSD1306_INVERSE);
        delay(1);
      delay(2000);
    void testdrawcircle(void) {
      for (int16_t i = 0; i < max(display.width(), display.height()) / 2; i += 2) {
        display.drawCircle(display.width() / 2, display.height() / 2, i, SSD1306_WHITE);
        display.display();
        delay(1);
      delay(2000);
    void testfillcircle(void) {
      for (int16_t i = max(display.width(), display.height()) / 2; i > 0; i -= 3) {
        // The INVERSE color is used so circles alternate white/black
        display.fillCircle(display.width() / 2, display.height() / 2, i, SSD1306_INVERSE);
        display.display(); // Update screen with each newly-drawn circle
        delay(1);
      delay(2000);
    void testdrawroundrect(void) {
      for (int16_t i = 0; i < display.height() / 2 - 2; i += 2) {
        display.drawRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i,
                              display.height() / 4, SSD1306_WHITE);
        display.display();
        delay(1);
      delay(2000);
    void testfillroundrect(void) {
        // The INVERSE color is used so round-rects alternate white/black
        display.fillRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i,
                              display.height() / 4, SSD1306_INVERSE);
        display.display();
        delay(1);
      delay(2000);
    void testdrawtriangle(void) {
      for (int16_t i = 0; i < max(display.width(), display.height()) / 2; i += 5) {
        display.drawTriangle(
          display.width() / 2  , display.height() / 2 - i,
          display.width() / 2 - i, display.height() / 2 + i,
          display.width() / 2 + i, display.height() / 2 + i, SSD1306_WHITE);
        display.display();
        delay(1);
      delay(2000);
    void testfilltriangle(void) {
      for (int16_t i = max(display.width(), display.height()) / 2; i > 0; i -= 5) {
        // The INVERSE color is used so triangles alternate white/black
        display.fillTriangle(
          display.width() / 2 + i, display.height() / 2 + i, SSD1306_INVERSE);
        display.display();
        delay(1);
      delay(2000);
    void testdrawchar(void) {
      display.setTextSize(1);      // Normal 1:1 pixel scale
      display.setTextColor(SSD1306_WHITE); // Draw white text
      display.setCursor(0, 0);     // Start at top-left corner
      display.cp437(true);         // Use full 256 char 'Code Page 437' font
      // Not all the characters will fit on the display. This is normal.
      // Library will draw what it can and the rest will be clipped.
      for (int16_t i = 0; i < 256; i++) {
        if (i == '\n') display.write(' ');
        else          display.write(i);
      display.display();
      delay(2000);
    void testdrawstyles(void) {
      display.println(F("Hello, world!"));
      display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
      display.println(3.141592);
      display.setTextSize(2);             // Draw 2X-scale text
      display.print(F("0x")); display.println(0xDEADBEEF, HEX);
      display.display();
      delay(2000);
    void testscrolltext(void) {
      display.setCursor(10, 0);
      display.println(F("scroll"));
      display.display();      // Show initial text
      // Scroll in various directions, pausing in-between:
      display.startscrollright(0x00, 0x0F);
      delay(2000);
      display.stopscroll();
      display.startscrollleft(0x00, 0x0F);
      delay(2000);
      display.startscrolldiagright(0x00, 0x07);
      delay(2000);
      display.startscrolldiagleft(0x00, 0x07);
      delay(2000);
    void testdrawbitmap(void) {
      display.drawBitmap(
        (display.width()  - LOGO_WIDTH ) / 2,
        (display.height() - LOGO_HEIGHT) / 2,
        logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
      display.display();
    #define XPOS   0 // Indexes into the 'icons' array in function below
    #define YPOS   1
    #define DELTAY 2
    void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h) {
      int8_t f, icons[NUMFLAKES][3];
      // Initialize 'snowflake' positions
      for (f = 0; f < NUMFLAKES; f++) {
        icons[f][XPOS]   = random(1 - LOGO_WIDTH, display.width());
        icons[f][YPOS]   = -LOGO_HEIGHT;
        icons[f][DELTAY] = random(1, 6);
        Serial.print(F("x: "));
        Serial.print(icons[f][XPOS], DEC);
        Serial.print(F(" y: "));
        Serial.print(icons[f][YPOS], DEC);
        Serial.print(F(" dy: "));
        Serial.println(icons[f][DELTAY], DEC);
      for (;;) { // Loop forever...
        display.clearDisplay(); // Clear the display buffer
        // Draw each snowflake:
          display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SSD1306_WHITE);
        display.display(); // Show the display buffer on the screen
        delay(200);        // Pause for 1/10 second
        // Then update coordinates of each flake...
          icons[f][YPOS] += icons[f][DELTAY];
          // If snowflake is off the bottom of the screen...
          if (icons[f][YPOS] >= display.height()) {
            // Reinitialize to a random position, just off the top
    The only things I changed from the example is:
    and the i2c address of the display 0x3C
    Mar 2018
    9
    Thanks for the quick reply! Then it must be related to my hardware setup... could you also share your wiring?
    Gnd -> gnd
    vdd -> 3.3
    sck -> 24
    sda -> 25
    Mar 2018
    9
    Thank you so much! It turned out to be a faulty unit, my other two displays are working
    24,777
    Was the bad display from Adafruit, or someone else well known, a no-name Chinese product?
    Mar 2018
    9
    I bought it from a german ebay shop couldn't find any further information about the manufacturer
