Results 1 to 8 of 8
Thread: Problem with INPUT_PULLUP on pins 3 and 9
    Jan 2021
    3
    Hello to all of you, I'm Luca, electrical and electronic technician 53 years old and this is my first post.
    After Arduino UNO, i recently started with Teensy 4.1 and unfortunately I already have a problem trying to use the QuadEncoder library.
    When I set pins 2 and 3 as channels A and B with the PULLUP option active, the encoder on that channel does not work correctly.
    Below I have verified that the problem exists even without the library. I wrote this simple program:
    enc_teensy.ino
    where I simply set all pins as pullUp inputs on setup(). Loop() is empty.
    All pins of Teensy are left unconnected. I connect only microUSB cable.
    With the tester I read that the voltage on all pins is 3.21 Volt. On pins 3 and 9 it is 0.3 Volt and on pin 13 it is 1.69 Volt.
    With teensy not powered and unconnected from all... Measuring with ohmmeter beetwin gnd and pins, I have value arround 56KOhm for all pins. For pin 3 i have 3.9KOhm for pin 9 I have 16 Ohm
    Now I can understand the voltage on pin 13, since there is the LED, but those on 3 and 9 are strange to me.
    Do I already have to think that my Teensy 4.1 was born badly? Or there are reasons that explain this. Note that if I program pin 3 or 9 for are Output they work correctly when i set I have 3.21 Volt and if reset I have 0 Volt.
    Germany
    8,007
    I've tested your sketch.. can't confirm this.
    Not good.
    Your ohmmeter.. which voltage does it use for measuring Ohm?
    Jan 2021
    3
    Under 3Volt. Is a common multimeter model HT25N tester from firma HT.
    I never connect my teensy with nothing before today and I only try to test with simple wire connected to pin GND and pins, but i buy them on Amazon and i begin to tink that is not a good idea!
    Germany
    8,007
    At least, Amazon makes it easy to return parts...
    8,528
    Works on the T4.1 I just tried... Pin 3 and 9 are fine.
    Jan 2021
    3
    Thanks.
    Now I arrange to have him replaced.
    Jul 2020
    743
    Quote Originally Posted by tecno67 View Post
    3V is possibly not safe on low voltage CMOS chips. Many standard multimeters use 0.2V full-scale except on diode mode.
    The 56k you see on the powered down chip is because you are back-driving the power through the protection diodes from that 3V
    source.
    Germany
    8,007
    I measured mine (cheap but good) - it uses 0.13V
    In "diode measure" mode it uses 3.8V
    Note, the i.mx.rt uses much less than 3.3V internally. I *think* absolute max is 1.6V (only when overclocking)
