Results 1 to 2 of 2
Thread: MIDI controlled analog synthesizer
    Hello everyone,
    It's been a while since I worked on the manufacture of an analog synthesizer totally controlled at midday.
    Thanks to your help and support, I realize this project a little more every day.
    Hello everyone,
    I just finished the Teensy code that drives the synthesizer. I want to share it with you for your opinion and your advice to improve it.
    The code works perfectly!
    The Teensy 4.1 receives MIDI data by USB, depending on the data received, it controls two MAX11300 (chip which has 20 DACs in 0 / 10v) in SPI on the same port with two slaveselect. For that I used the Pixi_demo library from wolfgangfriedrich (available on Github), however I had to modify the code of this one to be able to implement a second Max11300.
    The MAX11300 are used to generate the 2 envelopes (VCF / VCA), the notes for the VC01 and the VC02, and more particularly, the CVs which in turn control the VCAs (VCAs which replace the analog potentiometers,
    The 36 pins of the teensy are used to activate digital switches (DG333, DG419).
    Sincerely ANOAT
    #include <Pixi.h>
    #include <math.h>
    Pixi pixi;
    const boolean toggled = true;
    const byte VCF_VCA = 2; // Enveloppe for VCF and VCA
    const byte ADSR = 4; // pot control
    const byte SW_GTF = 3; // switch control
    const byte MIDI_L[VCF_VCA]    = {  115,    116};
    const byte HR_MIDI[VCF_VCA][ADSR] = {{ 44, 45, 46, 47}, { 48, 49, 50, 51}};
    const byte MIDI_GTF [SW_GTF][VCF_VCA] = {{ 103,    108}, { 104,    109}, { 105,    110}};
    const int channel = 1; // MIDI channel
    const int D_PINS = 13; // number of Digital PINS for swith on/off
    const int SW3_1 =  29;
    const int SW3_2 =  31;
    const int MIDI_SW3 =  102;
    const int SW4_1 = 1;        // SW4_1/SW4_2 is logic control for VCF (12db/24db/hp/bp)
    const int SW4_2 = 2;        //Switch on1/on2/on3/on4
    const int MIDI_SW4 = 112;
    const int DAC = 13;
    const int PIXI = 2;
    const int LFO_POT = 6;
    const int SW2[D_PINS] =      {36, 34, 32, 30, 33, 35,  3, 17, 20, 7,   5,  23, 4};
    const int MIDI_SW2[D_PINS] = {95, 94, 93, 92, 90, 89, 88, 87, 86, 85, 84, 83 , 82 };
    const int MIDI_SW_LFO [PIXI][LFO_POT] = {
      { 97,  98,  96, 100, 99, 101 },//  CC control switch on/off LFO
      {106, 111, 107,   0,  0,   0 }
    const int SW_LFO_A[PIXI][LFO_POT] =     {
      { 39,  41,  16,  26,  24,  37},//  Switch LFO A (potentiometre panning, centre= fermé, gauche LFO A, droite LFO B)
      { 18,  19,  22,   0,  0,   0 }
    const int SW_LFO_B[PIXI][LFO_POT] =     {
      { 25,  15,  19,  38,  14,  27},//  Switch LFO A (potentiometre panning, centre= fermé, gauche LFO A, droite LFO B)
      {  6,   8,  21,   0,  0,   0 }
    const int CC_MIDI[PIXI][DAC] = {
      {32, 34,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0},//  DAC B
      {37, 76, 77, 74, 75, 43, 41, 40, 39, 42, 91, 36, 38} //  DAC A
    const int CC_LFO[PIXI][LFO_POT] = {
      {67, 68, 66, 72, 71, 73},       ///DAC B
      {79, 81, 80,  0,  0,  0 }       ///DAC A
    const int CC_WAVE [2] = {33, 35};               // CC des sélecteurs de formes d'onde
    float         k_timer[VCF_VCA]         = {0, 0};  //
    unsigned long TimerStartTop[VCF_VCA]   = {0, 0};  // instant en microsecondes du dernier evenement start ou stop
    unsigned long TimeRefA[VCF_VCA]        = {0, 0};  // Duree en microsecondes de l'Attack
    unsigned long TimeRefD[VCF_VCA]        = {0, 0};  // Duree en microsecondes du Decay
    unsigned long TimeRefR[VCF_VCA]        = {0, 0};  // Duree en microsecondes du Release
    unsigned long tempsreel[VCF_VCA];                 // Differentiel du Temps en microseconde entre l'evenement et le temps absolu
    unsigned long  Offset[VCF_VCA]         = {0, 0};  // Amortissement des montees et descente du MCP
    byte high_byte[17][33];
    byte note1;
    byte note2;
    byte mode ;
    byte          klog                     = 4;       // Courbure equivalente à celles des condensateurs
    byte          Etat_module[VCF_VCA]     = {0, 0};  // 0=NOP      1=A       2=D     3=S     4=R
    byte          Choix_forme[VCF_VCA]     = {0, 0};  // 0=LIN      1=LOG     2=EXP
    byte          Choix_timer[VCF_VCA]     = {0, 0};  // 0=x1       1=x0.1    2=x10
    byte          Choix_gate_in[VCF_VCA]   = {0, 0};  // 0=GATE_IN  1=TRIG_IN 2=LOOP
    byte          DureeRef[3] = {5, 10, 60};
    byte          Etat_SW [VCF_VCA][SW_GTF];
    bool top = false;
    bool bot = false;
    int out_value;
    int SINE[2];
    int TRI[2];
    int TRIZ[2];
    int TRIY[2];
    int SAW[2];
    int SAWY[2];
    int SAWZ[2];
    int PULSE[2];
    int PWM [2];
    int LFOA[2][6];
    int LFOB[2][6];
    int LFO [2][6];
    int LFO_state[PIXI][LFO_POT];
    int LFO_level[PIXI][LFO_POT];
    int POT[VCF_VCA][ADSR];
    int AMT[VCF_VCA];
    int LEVEL [VCF_VCA];
    int OUT[VCF_VCA];
    int  tension[VCF_VCA]                   = {0, 0};  // Tension courante en millivolts
    int  tensionlin[VCF_VCA]                = {0, 0};  // Tension courante en millivolts
    int  tensionlog[VCF_VCA]                = {0, 0};  // Tension courante en millivolts
    int  memo_tension[VCF_VCA]              = {0, 0};  // Tension boucle-1 en millivolts
    unsigned int  TensionRefS[VCF_VCA]      = {0, 0};  // Tension (mV) de reference du SUSTAIN
    unsigned int  TensionStartTop[VCF_VCA]  = {0, 0};  // Tension (mV) du dernier evenement start ou stop
    float bend;
    float pitch_value;
    float divider = 120;                    //diviseur 1V/octave
    boolean       reset_ADSR  ;          // Redémarage des envellopes en mode DUO
    boolean       Etat_gate_in    = 0;   // Copie de l'etat de l'entree gate  (1=on  0=off)
    boolean       StartTop        = 0;   // Flag fugitif sur l'Etat_gate_in  (1=actif  0=deactive)
    boolean state[D_PINS];
    /////////////// Les DAC utilisé sont des MAX11300, il en a 2, PIXI A et PIXI B/////////////////////////
    char CH_LFO[PIXI][LFO_POT]  = {
      { CHANNEL_2,  CHANNEL_3,  CHANNEL_8, CHANNEL_13, CHANNEL_15, CHANNEL_18 }, /////DAC B
      { CHANNEL_12, CHANNEL_13, CHANNEL_14,     0,         0,           0     }  /////DAC A
    char CH_X[PIXI][DAC]  =  {
      {CHANNEL_0, CHANNEL_11,         0,         0,         0,          0,          0,          0,          0,         0,          0,          0,           0},/////DAC B
      {CHANNEL_19, CHANNEL_0, CHANNEL_1, CHANNEL_2,  CHANNEL_3,  CHANNEL_5,  CHANNEL_6,  CHANNEL_7, CHANNEL_8, CHANNEL_9, CHANNEL_16, CHANNEL_17,  CHANNEL_18} /////DAC A
                      /// VCO1 ------ VCO2 ///
    char CH_Si[2]  = {CHANNEL_10, CHANNEL_19 };
    char CH_Tr[2]  = {CHANNEL_9,  CHANNEL_17 };
    char CH_Sa[2]  = {CHANNEL_7,  CHANNEL_16 };
    char CH_Pu[2]  = {CHANNEL_5,  CHANNEL_14 };
    char CH_Pw[2]  = {CHANNEL_6,  CHANNEL_4 };
      word Pixi_ID = 0;
      float Temp = 0;
      word test = 0;
      Pixi_ID = pixi.configA();
      if (Pixi_ID == 0x0424 ) {
        Serial.print("Found PIXI module ID: 0x");
        Serial.println(Pixi_ID, HEX);
        pixi.configChannelA ( CHANNEL_19, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_0, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_1, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_2, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_3, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_5, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_6, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_7, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_8, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_9, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_10, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_11, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_12, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_13, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_14, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_16, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_17, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelA ( CHANNEL_18, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
      Pixi_ID = pixi.configB();
        pixi.configChannelB ( CHANNEL_0, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_1, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_2, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_3, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_4, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_5, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_6, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_7, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_8, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_9, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_10, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_11, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_12, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_13, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_14, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_15, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_16, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_17, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_18, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
        pixi.configChannelB ( CHANNEL_19, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
      for (int i = 0; i < D_PINS; i++) {
        pinMode(SW2[i], OUTPUT);
        digitalWrite(SW2[i], LOW); // Toutes les pins out ont pour valeur LOW
      pinMode(SW3_1, OUTPUT);
      digitalWrite(SW3_1, LOW); // Toutes les pins out ont pour valeur LOW
      pinMode(SW3_2, OUTPUT);
      digitalWrite(SW3_2, LOW);
      pinMode(SW4_1, OUTPUT);
      pinMode(SW4_2, OUTPUT);
      digitalWrite(SW4_1, LOW);
      digitalWrite(SW4_2, LOW);
      for (int i = 0; i < PIXI; i++) {
        for ( int k = 0 ; k < LFO_POT ; k++ ) {
          pinMode(SW_LFO_A[i][k], OUTPUT);
          pinMode(SW_LFO_B[i][k], OUTPUT);
          digitalWrite(SW_LFO_A[i][k], LOW);
          digitalWrite(SW_LFO_B[i][k], LOW); // Toutes les pins out ont pour valeur LOW
      usbMIDI.setHandleNoteOn(OnNoteOn);
      usbMIDI.setHandleNoteOff(OnNoteOff);
      usbMIDI.setHandlePitchChange(OnPitchChange);
      usbMIDI.setHandleControlChange (OnControlChange);
      usbMIDI.read();
      AUTOMATE();           // GESTION DE L'ENCHAINEMENT DES TACHES
      CALCUL();             // DETERMINATION DE LA TENSION DE SORTIE
      ECRIREDAC();          // ENVOIE DE LA TENSION DE SORTIE SUR LE DAC
      IHM();                // GESTION DES INVERSEURS ET POTENTIOMETRES
    void OnControlChange (byte channel, byte control, byte value) {
      if ( control == 116) {
        mode = map(value, 0, 127, 0, 1);      //monophonic ou duophonic
      if ( control == 117 ) {
        reset_ADSR = map(value, 0, 127, 0, 1);      //Reset ADSR DUO-MODE
      for (int i = 0; i < PIXI ; i++) {
        for ( int k = 0 ; k < DAC ; k++ ) {
          if (control >= 64 && control <= 127) {
            out_value =  map(value, 0, 127, 0, 4095) ;  //Gestion des CC en 7bits
          if (control == MIDI_L[i])
          { LEVEL[i] =  map(value, 0, 127, 0, 4092) ;
          if (control >= 0 && control <= 31) {
            high_byte[channel][control] = value;
          else if (control >= 32 && control <= 63) {
            out_value = (high_byte[channel][control - 32] << 7) + value;        //Gestion des CC en 14bits
            out_value = map(out_value, 0, 16383, 0, 4095);
          if (control == CC_MIDI[0][k]) {
            pixi.writeAnalogB ( CH_X[0][k], out_value);
          if (control == CC_MIDI[1][k]) {
            pixi.writeAnalogA ( CH_X[1][k], out_value);
          for ( int j = 0 ; j < ADSR ; j++ ) {
            if (control == HR_MIDI[i][j]) {                                 //copie de l'etat des CC pour gestion des envellopes
              POT[i][j] =  map(out_value, 0, 4095, 0, 1023) ;
        for ( int j = 0 ; j < SW_GTF ; j++ ) {
          if (control == MIDI_GTF[i][j])
          { Etat_SW[i][j] =  map(value, 0, 127, 0, 2) ;
            Choix_gate_in[i] = Etat_SW[0][i];                           //Switch des envellopes
            Choix_timer[i] = Etat_SW[1][i];
            Choix_forme[i] = Etat_SW[2][i];
    //GESTION DES FORMES  (un CC permet de choisir l'onde entre sinus/triangle/saw/pulse/PWM)
     //le changement se fait à l'aide de CV qui contrôle des VCA, de tel sorte que l'on évolue petit à petit d'une forme à l'autre//
        for (int j = 0; j < 2 ; j++) {
          if (control == CC_WAVE[j]) {
            SINE[j] = TRIZ[j] = constrain(out_value, 0, 1023);
            SINE[j] = map( SINE[j], 0, 1023, 4095, 0);
            TRIZ[j] = map(TRIZ[j], 0, 1023, 0, 4095);
            TRIY[j] = SAWZ[j] = constrain(out_value, 1023, 2047);
            TRIY[j] = map(TRIY[j], 1023, 2047, 0, 4095);
            TRI[j] = TRIZ[j] - TRIY[j];
            SAWZ[j] = map(SAWZ[j], 1023, 2047, 0, 4095);
            SAWY[j] = PULSE[j] = constrain(out_value, 2047, 3071);
            SAWY[j] = map( SAWY[j], 2047, 3071, 0, 4095);
            SAW[j] =  SAWZ[j] - SAWY[j];
            PULSE[j] = map(PULSE[j], 2047, 3071, 0, 4095);
            PWM[j] = constrain(out_value, 3071, 4095);
            PWM[j] = map(PWM[j], 3071, 4095, 0, 4095);
            pixi.writeAnalogB ( CH_Si[j], SINE[j]);
            pixi.writeAnalogB ( CH_Tr[j], TRI[j]);
            pixi.writeAnalogB ( CH_Sa[j], SAW[j]);
            pixi.writeAnalogB ( CH_Pu[j], PULSE[j]);
            pixi.writeAnalogB ( CH_Pw[j], PWM[j]);
    //GESTION DU PANNING DES LFO PAR CV
          if (control == CC_LFO[i][k]) {
            LFOA[i][k] = constrain(value, 0, 63);
            LFOA[i][k] = map(  LFOA[i][k], 0, 63, 4095, 0);
            LFOB[i][k] = constrain(value, 64, 127);
            LFOB[i][k] = map(  LFOB[i][k], 64, 127, 0, -4095);
            LFO [i][k] = LFOA[i][k] - LFOB[i][k];
            if ( CH_LFO[i][k] == CH_LFO[0][k]) {
              pixi.writeAnalogB ( CH_LFO[i][k], LFO[i][k]);
            if ( CH_LFO[i][k] == CH_LFO[1][k]) {
              pixi.writeAnalogA ( CH_LFO[i][k], LFO[i][k]);
            if (MIDI_SW_LFO[i][k] == control )
              LFO_state [i][k] = map(value, 0, 127, 0, 1);
            if (CC_LFO[i][k] == control )
              LFO_level [i][k] = value ;
            if (LFO_level [i][k] <= 62 && LFO_state [i][k] == 1  )
            { digitalWrite( SW_LFO_A [i][k], HIGH);
              digitalWrite( SW_LFO_B [i][k], LOW);
            else {
              digitalWrite( SW_LFO_A [i][k], LOW);
            if (LFO_level [i][k] >= 65 && LFO_state [i][k]  == 0 )
            { digitalWrite( SW_LFO_B [i][k], HIGH);
            else {
      //// GESTION DES SWITCH ON/OFF////
      for (int i = 0; i < D_PINS ; i++)
      { if (MIDI_SW2[i] == control)
        { if (value >= 64)
          { digitalWrite(SW2[i], HIGH);
            state[i] = true;
          }        else {
            state[i] = false;
    //GESTION DU SWITCH GLIDE
      if (MIDI_SW3 == control)
      { if (value >= 84)
        { digitalWrite(SW3_1, HIGH);
        else if (value < 84 && value > 42)
        { digitalWrite(SW3_1, LOW);
        else if (value < 42)
          digitalWrite(SW3_2, HIGH);
    // GESTION DU SWITCH SELECTEUR DE PENTE DU VCF
      { if (MIDI_SW4 == control)
        { if (value >= 96)
          { digitalWrite(SW4_1, HIGH);
          else if (value < 96 && value > 64)
          { digitalWrite(SW4_1, LOW);
          else if (value < 64 && value > 32)
            digitalWrite(SW4_2, HIGH);
          else if (value < 32)
    // CLAVIER EN MODE MONOPHONIC
    void OnNoteOn(byte channel, byte pitch, byte velocity) {
      if (mode == 0 && channel == 1 && velocity > 0) {
        pitch_value = constrain(pitch, 0, 120);
        pixi.writeAnalogB ( CHANNEL_1, ((pitch_value + bend) / divider) * 4095.0);
        pixi.writeAnalogB ( CHANNEL_12, ((pitch_value + bend) / divider) * 4095.0);
        Etat_gate_in = 1;
        StartTop = 1;
        AMT[0] = map(velocity, 0, 127, 0, LEVEL[0]);
        AMT[1] = map(velocity, 0, 127, 0, LEVEL[1]);
      else {
        Etat_gate_in = 0;
    // CLAVIER EN MODE DUOPHONIC
      if  (mode == 1 && top == false && channel == 1 && velocity > 0) {
        top = true;
        note1 = pitch ;
        Etat_gate_in = 1;
        StartTop = 1;
      else if (mode == 1 && top == true && bot == false && channel == 1 && velocity > 0) {
        bot = true;
        note2 = pitch ;
        if (reset_ADSR = 1) {
          Etat_gate_in = 1;
          StartTop = 1;
    void OnNoteOff(byte channel, byte pitch, byte velocity) {
      if (pitch == note1 && channel == 1) {
        top = false;
        Etat_gate_in = 0;
      else if (pitch == note2 && channel == 1) {
        bot = false;
        Etat_gate_in = 0;
    void OnPitchChange (byte channel, int pitch_change) {
      if (channel == 1) {
        bend = map(pitch_change, 8191 , -8192, 0, 24);
    // ENVOI DE LA TENSION DE SORTIE AU DAC
    void ECRIREDAC() {
      for (int i = 0; i < VCF_VCA ; i++) {
        if (memo_tension[i] != tension[i]) {
          memo_tension[i] = tension[i];
          OUT[i] = map(tension[i], 0, 4095, 0, AMT[i]);
          pixi.writeAnalogA ( CHANNEL_10, OUT[0]);
          pixi.writeAnalogA ( CHANNEL_11, OUT[1]);
    // CALCUL DE LA TENSION DE SORTIE (0->4095mV)
    void CALCUL() {
        //----------------------------------------------------------------------ATTACK--
        if (Etat_module[i] == 1) {
          tempsreel[i] = (micros() - TimerStartTop[i]);
          tension[i] = 4095 - TensionStartTop[i];
          tension[i] *= float(tempsreel[i] * k_timer[i] / (TimeRefA[i] * (4095.00 - TensionStartTop[i]) / 4095.00));
          tension[i] += TensionStartTop[i];
          if      (Choix_forme[i] == 1) {
            tension[i] += 512;
            float k = (4095 - TensionStartTop[i]) / 3.61;
            tension[i] = (log10(tension[i] - TensionStartTop[i]) * k * klog) + (4095 - (log10(4095 - TensionStartTop[i]) * k * klog));
          if      (Choix_forme[i] == 2) {
            tensionlin[i] = tension[i];
            float k = tension[i] / 3.61;
            tension[i] *= float((TimeRefA[i] - (tempsreel[i] * k_timer[i])) / (TimeRefA[i] * (4095.00 - TensionStartTop[i]) / 4095.00));
            tensionlog[i] = (log10(tension[i] - TensionStartTop[i]) * k * klog) + (4095 - (log10(4095 - TensionStartTop[i]) * k * klog));
            tension[i] = tensionlin[i] - tensionlog[i] + tension[i];
          tension[i] = constrain(tension[i], TensionStartTop[i], 4095);
      //----------------------------------------------------------------------DECAY--
        else if (Etat_module[i] == 2) {
          tension[i] = TensionStartTop[i] - ((TensionStartTop[i] - TensionRefS[i]) * (k_timer[i] * tempsreel[i] / TimeRefD[i] * 2));
          if      (Choix_forme[i] == 1) { //LOG => EXP en descente
            float k = log(TensionStartTop[i] - TensionRefS[i]) * (1 - (k_timer[i] * tempsreel[i] / TimeRefD[i]));
            if (k > 16) {
              tension[i] = 4095;
              tension[i] = exp(k) + TensionRefS[i] - 1;
          else if (Choix_forme[i] == 2) { // EXP => LOG en descente
            tension[i] = TensionRefS[i] + ((log10((TensionStartTop[i] - (TensionStartTop[i] * (k_timer[i] * tempsreel[i] / TimeRefD[i] * 2))) / (klog * 100))) * ((TensionStartTop[i] - TensionRefS[i]) / log10(TensionStartTop[i] / (klog * 100))));
          tension[i] = constrain(tension[i], TensionRefS[i] - 1, 4095);
      //----------------------------------------------------------------------SUSTAIN--
        else if (Etat_module[i] == 3) {
          tension[i] = TensionRefS[i];
      //----------------------------------------------------------------------RELEASE--
        else if (Etat_module[i] == 4) {
          tension[i] = TensionStartTop[i] - (k_timer[i] * tempsreel[i] * float(4095.00 / TimeRefR[i] * 2)); //  LIN
          if      (Choix_forme[i] == 1) {                                     //  LOG
            float k = log(TensionStartTop[i]) * (1 - (k_timer[i] * tempsreel[i] / TimeRefR[i]));
            if (k > 16) {
              tension[i] = 4095;
              tension[i] = exp(k);
              tension[i] -= 50;
            tension[i] = (log10((TensionStartTop[i] - (TensionStartTop[i] * (k_timer[i] * tempsreel[i] / TimeRefR[i] * 2))) / (klog * 50))) * ((TensionStartTop[i]) / log10(TensionStartTop[i] / (klog * 50)));
          tension[i] = constrain(tension[i], 0, TensionRefS[i]);
    // ENCHAINEMENT DES PHASES ENTRE ELLES
    void AUTOMATE() {
        byte  mem1 = Etat_module[i];
        float mem2 = k_timer[i];
        byte  k = 1; // V3.01
          k = 2; // V3.01
        if (Etat_module[i] == 0 && ((Etat_gate_in == 1) + (Choix_gate_in[i] == 1) > 0) ) {
          Etat_module[i] = 1;
        else if (Etat_module[i] == 1 && Etat_gate_in == 0 && Choix_gate_in[i] == 0 ) {
          if (tension[i] > TensionRefS[i]) {
            Etat_module[i] = 2;
            Etat_module[i] = 4;
        else if (Etat_module[i] == 1 && tension[i] >= 4095) {
          Etat_module[i] = 2;
        else if (Etat_module[i] == 2 && (tension[i] <= TensionRefS[i] || k_timer[i]*tempsreel[i] > TimeRefD[i] / k )) {
          if (Etat_gate_in == 1) {
            Etat_module[i] = 3;
            Etat_module[i] = 4;
        else if (Etat_module[i] == 2 && StartTop == 1) {
          Etat_module[i] = 1;
          StartTop = 0;
        else if (Etat_module[i] == 3 && Etat_gate_in == 0) {
          Etat_module[i] = 4;
        else if (Etat_module[i] == 4 && Etat_gate_in == 1 ) {
          Etat_module[i] = 1;
        StartTop = 0;
        if (Etat_module[i] != mem1 || k_timer[i] != mem2) { // INITIALISATION DE L'INSTANT DE BASCULE ENTRE PHASE
          TimerStartTop[i] = micros();
          TensionStartTop[i] = constrain(tension[i], 0, 4095);
    // CALCUL DE LA DUREE DE LA PHASE (ADR) ASSOCIEE AU POTENTIOMETRE
    unsigned long RefTime(unsigned int potar) {
        unsigned long k = int(potar * (DureeRef[Choix_timer[i]]));;
        k *= float(100000.00 / 1023.00);
        k += Offset[i] + 100;
        return k;
    // LECTURE PERIODIQUE DES INVERSEURS ET POTENTIOMETRES
    void IHM()
    { for (int i = 0; i < VCF_VCA ; i++) {
        if (Choix_timer[i] == 1) {
          k_timer[i] = 1.00;
        else {
          k_timer[i] = 0.05;
        Offset[i] = int(DureeRef[Choix_timer[i]] * 500);
        TimeRefA[i]     = RefTime(POT[i][0]); TimeRefA[i] /= 2;
        TimeRefD[i]     = RefTime(POT[i][1]);
        TensionRefS[i]  = POT[i][2] * 4 ;
        TimeRefR[i]     = RefTime(POT[i][3]);
    Sep 2020
    Massachusetts
    115
    Thanks for sharing this.
    I have the MAX11300 evaluation board.
    I would love to try pixi library.
