#include <Pixi.h>
#include <math.h>
Pixi pixi;
const boolean toggled = true;
const byte VCF_VCA = 2; // Enveloppe for VCF and VCA
const byte ADSR = 4; // pot control
const byte SW_GTF = 3; // switch control
const byte MIDI_L[VCF_VCA] = { 115, 116};
const byte HR_MIDI[VCF_VCA][ADSR] = {{ 44, 45, 46, 47}, { 48, 49, 50, 51}};
const byte MIDI_GTF [SW_GTF][VCF_VCA] = {{ 103, 108}, { 104, 109}, { 105, 110}};
const int channel = 1; // MIDI channel
const int D_PINS = 13; // number of Digital PINS for swith on/off
const int SW3_1 = 29;
const int SW3_2 = 31;
const int MIDI_SW3 = 102;
const int SW4_1 = 1; // SW4_1/SW4_2 is logic control for VCF (12db/24db/hp/bp)
const int SW4_2 = 2; //Switch on1/on2/on3/on4
const int MIDI_SW4 = 112;
const int DAC = 13;
const int PIXI = 2;
const int LFO_POT = 6;
const int SW2[D_PINS] = {36, 34, 32, 30, 33, 35, 3, 17, 20, 7, 5, 23, 4};
const int MIDI_SW2[D_PINS] = {95, 94, 93, 92, 90, 89, 88, 87, 86, 85, 84, 83 , 82 };
const int MIDI_SW_LFO [PIXI][LFO_POT] = {
{ 97, 98, 96, 100, 99, 101 },// CC control switch on/off LFO
{106, 111, 107, 0, 0, 0 }
const int SW_LFO_A[PIXI][LFO_POT] = {
{ 39, 41, 16, 26, 24, 37},// Switch LFO A (potentiometre panning, centre= fermé, gauche LFO A, droite LFO B)
{ 18, 19, 22, 0, 0, 0 }
const int SW_LFO_B[PIXI][LFO_POT] = {
{ 25, 15, 19, 38, 14, 27},// Switch LFO A (potentiometre panning, centre= fermé, gauche LFO A, droite LFO B)
{ 6, 8, 21, 0, 0, 0 }
const int CC_MIDI[PIXI][DAC] = {
{32, 34, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},// DAC B
{37, 76, 77, 74, 75, 43, 41, 40, 39, 42, 91, 36, 38} // DAC A
const int CC_LFO[PIXI][LFO_POT] = {
{67, 68, 66, 72, 71, 73}, ///DAC B
{79, 81, 80, 0, 0, 0 } ///DAC A
const int CC_WAVE [2] = {33, 35}; // CC des sélecteurs de formes d'onde
float k_timer[VCF_VCA] = {0, 0}; //
unsigned long TimerStartTop[VCF_VCA] = {0, 0}; // instant en microsecondes du dernier evenement start ou stop
unsigned long TimeRefA[VCF_VCA] = {0, 0}; // Duree en microsecondes de l'Attack
unsigned long TimeRefD[VCF_VCA] = {0, 0}; // Duree en microsecondes du Decay
unsigned long TimeRefR[VCF_VCA] = {0, 0}; // Duree en microsecondes du Release
unsigned long tempsreel[VCF_VCA]; // Differentiel du Temps en microseconde entre l'evenement et le temps absolu
unsigned long Offset[VCF_VCA] = {0, 0}; // Amortissement des montees et descente du MCP
byte high_byte[17][33];
byte note1;
byte note2;
byte mode ;
byte klog = 4; // Courbure equivalente à celles des condensateurs
byte Etat_module[VCF_VCA] = {0, 0}; // 0=NOP 1=A 2=D 3=S 4=R
byte Choix_forme[VCF_VCA] = {0, 0}; // 0=LIN 1=LOG 2=EXP
byte Choix_timer[VCF_VCA] = {0, 0}; // 0=x1 1=x0.1 2=x10
byte Choix_gate_in[VCF_VCA] = {0, 0}; // 0=GATE_IN 1=TRIG_IN 2=LOOP
byte DureeRef[3] = {5, 10, 60};
byte Etat_SW [VCF_VCA][SW_GTF];
bool top = false;
bool bot = false;
int out_value;
int SINE[2];
int TRI[2];
int TRIZ[2];
int TRIY[2];
int SAW[2];
int SAWY[2];
int SAWZ[2];
int PULSE[2];
int PWM [2];
int LFOA[2][6];
int LFOB[2][6];
int LFO [2][6];
int LFO_state[PIXI][LFO_POT];
int LFO_level[PIXI][LFO_POT];
int POT[VCF_VCA][ADSR];
int AMT[VCF_VCA];
int LEVEL [VCF_VCA];
int OUT[VCF_VCA];
int tension[VCF_VCA] = {0, 0}; // Tension courante en millivolts
int tensionlin[VCF_VCA] = {0, 0}; // Tension courante en millivolts
int tensionlog[VCF_VCA] = {0, 0}; // Tension courante en millivolts
int memo_tension[VCF_VCA] = {0, 0}; // Tension boucle-1 en millivolts
unsigned int TensionRefS[VCF_VCA] = {0, 0}; // Tension (mV) de reference du SUSTAIN
unsigned int TensionStartTop[VCF_VCA] = {0, 0}; // Tension (mV) du dernier evenement start ou stop
float bend;
float pitch_value;
float divider = 120; //diviseur 1V/octave
boolean reset_ADSR ; // Redémarage des envellopes en mode DUO
boolean Etat_gate_in = 0; // Copie de l'etat de l'entree gate (1=on 0=off)
boolean StartTop = 0; // Flag fugitif sur l'Etat_gate_in (1=actif 0=deactive)
boolean state[D_PINS];
/////////////// Les DAC utilisé sont des MAX11300, il en a 2, PIXI A et PIXI B/////////////////////////
char CH_LFO[PIXI][LFO_POT] = {
{ CHANNEL_2, CHANNEL_3, CHANNEL_8, CHANNEL_13, CHANNEL_15, CHANNEL_18 }, /////DAC B
{ CHANNEL_12, CHANNEL_13, CHANNEL_14, 0, 0, 0 } /////DAC A
char CH_X[PIXI][DAC] = {
{CHANNEL_0, CHANNEL_11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},/////DAC B
{CHANNEL_19, CHANNEL_0, CHANNEL_1, CHANNEL_2, CHANNEL_3, CHANNEL_5, CHANNEL_6, CHANNEL_7, CHANNEL_8, CHANNEL_9, CHANNEL_16, CHANNEL_17, CHANNEL_18} /////DAC A
/// VCO1 ------ VCO2 ///
char CH_Si[2] = {CHANNEL_10, CHANNEL_19 };
char CH_Tr[2] = {CHANNEL_9, CHANNEL_17 };
char CH_Sa[2] = {CHANNEL_7, CHANNEL_16 };
char CH_Pu[2] = {CHANNEL_5, CHANNEL_14 };
char CH_Pw[2] = {CHANNEL_6, CHANNEL_4 };
word Pixi_ID = 0;
float Temp = 0;
word test = 0;
Pixi_ID = pixi.configA();
if (Pixi_ID == 0x0424 ) {
Serial.print("Found PIXI module ID: 0x");
Serial.println(Pixi_ID, HEX);
pixi.configChannelA ( CHANNEL_19, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_0, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_1, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_2, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_3, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_5, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_6, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_7, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_8, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_9, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_10, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_11, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_12, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_13, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_14, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_16, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_17, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelA ( CHANNEL_18, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
Pixi_ID = pixi.configB();
pixi.configChannelB ( CHANNEL_0, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_1, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_2, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_3, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_4, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_5, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_6, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_7, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_8, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_9, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_10, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_11, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_12, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_13, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_14, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_15, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_16, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_17, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_18, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
pixi.configChannelB ( CHANNEL_19, CH_MODE_DAC, 5, CH_0_TO_10P, 0 );
for (int i = 0; i < D_PINS; i++) {
pinMode(SW2[i], OUTPUT);
digitalWrite(SW2[i], LOW); // Toutes les pins out ont pour valeur LOW
pinMode(SW3_1, OUTPUT);
digitalWrite(SW3_1, LOW); // Toutes les pins out ont pour valeur LOW
pinMode(SW3_2, OUTPUT);
digitalWrite(SW3_2, LOW);
pinMode(SW4_1, OUTPUT);
pinMode(SW4_2, OUTPUT);
digitalWrite(SW4_1, LOW);
digitalWrite(SW4_2, LOW);
for (int i = 0; i < PIXI; i++) {
for ( int k = 0 ; k < LFO_POT ; k++ ) {
pinMode(SW_LFO_A[i][k], OUTPUT);
pinMode(SW_LFO_B[i][k], OUTPUT);
digitalWrite(SW_LFO_A[i][k], LOW);
digitalWrite(SW_LFO_B[i][k], LOW); // Toutes les pins out ont pour valeur LOW
usbMIDI.setHandleNoteOn(OnNoteOn);
usbMIDI.setHandleNoteOff(OnNoteOff);
usbMIDI.setHandlePitchChange(OnPitchChange);
usbMIDI.setHandleControlChange (OnControlChange);
usbMIDI.read();
AUTOMATE(); // GESTION DE L'ENCHAINEMENT DES TACHES
CALCUL(); // DETERMINATION DE LA TENSION DE SORTIE
ECRIREDAC(); // ENVOIE DE LA TENSION DE SORTIE SUR LE DAC
IHM(); // GESTION DES INVERSEURS ET POTENTIOMETRES
void OnControlChange (byte channel, byte control, byte value) {
if ( control == 116) {
mode = map(value, 0, 127, 0, 1); //monophonic ou duophonic
if ( control == 117 ) {
reset_ADSR = map(value, 0, 127, 0, 1); //Reset ADSR DUO-MODE
for (int i = 0; i < PIXI ; i++) {
for ( int k = 0 ; k < DAC ; k++ ) {
if (control >= 64 && control <= 127) {
out_value = map(value, 0, 127, 0, 4095) ; //Gestion des CC en 7bits
if (control == MIDI_L[i])
{ LEVEL[i] = map(value, 0, 127, 0, 4092) ;
if (control >= 0 && control <= 31) {
high_byte[channel][control] = value;
else if (control >= 32 && control <= 63) {
out_value = (high_byte[channel][control - 32] << 7) + value; //Gestion des CC en 14bits
out_value = map(out_value, 0, 16383, 0, 4095);
if (control == CC_MIDI[0][k]) {
pixi.writeAnalogB ( CH_X[0][k], out_value);
if (control == CC_MIDI[1][k]) {
pixi.writeAnalogA ( CH_X[1][k], out_value);
for ( int j = 0 ; j < ADSR ; j++ ) {
if (control == HR_MIDI[i][j]) { //copie de l'etat des CC pour gestion des envellopes
POT[i][j] = map(out_value, 0, 4095, 0, 1023) ;
for ( int j = 0 ; j < SW_GTF ; j++ ) {
if (control == MIDI_GTF[i][j])
{ Etat_SW[i][j] = map(value, 0, 127, 0, 2) ;
Choix_gate_in[i] = Etat_SW[0][i]; //Switch des envellopes
Choix_timer[i] = Etat_SW[1][i];
Choix_forme[i] = Etat_SW[2][i];
//GESTION DES FORMES (un CC permet de choisir l'onde entre sinus/triangle/saw/pulse/PWM)
//le changement se fait à l'aide de CV qui contrôle des VCA, de tel sorte que l'on évolue petit à petit d'une forme à l'autre//
for (int j = 0; j < 2 ; j++) {
if (control == CC_WAVE[j]) {
SINE[j] = TRIZ[j] = constrain(out_value, 0, 1023);
SINE[j] = map( SINE[j], 0, 1023, 4095, 0);
TRIZ[j] = map(TRIZ[j], 0, 1023, 0, 4095);
TRIY[j] = SAWZ[j] = constrain(out_value, 1023, 2047);
TRIY[j] = map(TRIY[j], 1023, 2047, 0, 4095);
TRI[j] = TRIZ[j] - TRIY[j];
SAWZ[j] = map(SAWZ[j], 1023, 2047, 0, 4095);
SAWY[j] = PULSE[j] = constrain(out_value, 2047, 3071);
SAWY[j] = map( SAWY[j], 2047, 3071, 0, 4095);
SAW[j] = SAWZ[j] - SAWY[j];
PULSE[j] = map(PULSE[j], 2047, 3071, 0, 4095);
PWM[j] = constrain(out_value, 3071, 4095);
PWM[j] = map(PWM[j], 3071, 4095, 0, 4095);
pixi.writeAnalogB ( CH_Si[j], SINE[j]);
pixi.writeAnalogB ( CH_Tr[j], TRI[j]);
pixi.writeAnalogB ( CH_Sa[j], SAW[j]);
pixi.writeAnalogB ( CH_Pu[j], PULSE[j]);
pixi.writeAnalogB ( CH_Pw[j], PWM[j]);
//GESTION DU PANNING DES LFO PAR CV
if (control == CC_LFO[i][k]) {
LFOA[i][k] = constrain(value, 0, 63);
LFOA[i][k] = map( LFOA[i][k], 0, 63, 4095, 0);
LFOB[i][k] = constrain(value, 64, 127);
LFOB[i][k] = map( LFOB[i][k], 64, 127, 0, -4095);
LFO [i][k] = LFOA[i][k] - LFOB[i][k];
if ( CH_LFO[i][k] == CH_LFO[0][k]) {
pixi.writeAnalogB ( CH_LFO[i][k], LFO[i][k]);
if ( CH_LFO[i][k] == CH_LFO[1][k]) {
pixi.writeAnalogA ( CH_LFO[i][k], LFO[i][k]);
if (MIDI_SW_LFO[i][k] == control )
LFO_state [i][k] = map(value, 0, 127, 0, 1);
if (CC_LFO[i][k] == control )
LFO_level [i][k] = value ;
if (LFO_level [i][k] <= 62 && LFO_state [i][k] == 1 )
{ digitalWrite( SW_LFO_A [i][k], HIGH);
digitalWrite( SW_LFO_B [i][k], LOW);
else {
digitalWrite( SW_LFO_A [i][k], LOW);
if (LFO_level [i][k] >= 65 && LFO_state [i][k] == 0 )
{ digitalWrite( SW_LFO_B [i][k], HIGH);
else {
//// GESTION DES SWITCH ON/OFF////
for (int i = 0; i < D_PINS ; i++)
{ if (MIDI_SW2[i] == control)
{ if (value >= 64)
{ digitalWrite(SW2[i], HIGH);
state[i] = true;
state[i] = false;
//GESTION DU SWITCH GLIDE
if (MIDI_SW3 == control)
{ if (value >= 84)
{ digitalWrite(SW3_1, HIGH);
else if (value < 84 && value > 42)
{ digitalWrite(SW3_1, LOW);
else if (value < 42)
digitalWrite(SW3_2, HIGH);
// GESTION DU SWITCH SELECTEUR DE PENTE DU VCF
{ if (MIDI_SW4 == control)
{ if (value >= 96)
{ digitalWrite(SW4_1, HIGH);
else if (value < 96 && value > 64)
{ digitalWrite(SW4_1, LOW);
else if (value < 64 && value > 32)
digitalWrite(SW4_2, HIGH);
else if (value < 32)
// CLAVIER EN MODE MONOPHONIC
void OnNoteOn(byte channel, byte pitch, byte velocity) {
if (mode == 0 && channel == 1 && velocity > 0) {
pitch_value = constrain(pitch, 0, 120);
pixi.writeAnalogB ( CHANNEL_1, ((pitch_value + bend) / divider) * 4095.0);
pixi.writeAnalogB ( CHANNEL_12, ((pitch_value + bend) / divider) * 4095.0);
Etat_gate_in = 1;
StartTop = 1;
AMT[0] = map(velocity, 0, 127, 0, LEVEL[0]);
AMT[1] = map(velocity, 0, 127, 0, LEVEL[1]);
else {
Etat_gate_in = 0;
// CLAVIER EN MODE DUOPHONIC
if (mode == 1 && top == false && channel == 1 && velocity > 0) {
top = true;
note1 = pitch ;
Etat_gate_in = 1;
StartTop = 1;
else if (mode == 1 && top == true && bot == false && channel == 1 && velocity > 0) {
bot = true;
note2 = pitch ;
if (reset_ADSR = 1) {
Etat_gate_in = 1;
StartTop = 1;
void OnNoteOff(byte channel, byte pitch, byte velocity) {
if (pitch == note1 && channel == 1) {
top = false;
Etat_gate_in = 0;
else if (pitch == note2 && channel == 1) {
bot = false;
Etat_gate_in = 0;
void OnPitchChange (byte channel, int pitch_change) {
if (channel == 1) {
bend = map(pitch_change, 8191 , -8192, 0, 24);
// ENVOI DE LA TENSION DE SORTIE AU DAC
void ECRIREDAC() {
for (int i = 0; i < VCF_VCA ; i++) {
if (memo_tension[i] != tension[i]) {
memo_tension[i] = tension[i];
OUT[i] = map(tension[i], 0, 4095, 0, AMT[i]);
pixi.writeAnalogA ( CHANNEL_10, OUT[0]);
pixi.writeAnalogA ( CHANNEL_11, OUT[1]);
// CALCUL DE LA TENSION DE SORTIE (0->4095mV)
void CALCUL() {
//----------------------------------------------------------------------ATTACK--
if (Etat_module[i] == 1) {
tempsreel[i] = (micros() - TimerStartTop[i]);
tension[i] = 4095 - TensionStartTop[i];
tension[i] *= float(tempsreel[i] * k_timer[i] / (TimeRefA[i] * (4095.00 - TensionStartTop[i]) / 4095.00));
tension[i] += TensionStartTop[i];
if (Choix_forme[i] == 1) {
tension[i] += 512;
float k = (4095 - TensionStartTop[i]) / 3.61;
tension[i] = (log10(tension[i] - TensionStartTop[i]) * k * klog) + (4095 - (log10(4095 - TensionStartTop[i]) * k * klog));
if (Choix_forme[i] == 2) {
tensionlin[i] = tension[i];
float k = tension[i] / 3.61;
tension[i] *= float((TimeRefA[i] - (tempsreel[i] * k_timer[i])) / (TimeRefA[i] * (4095.00 - TensionStartTop[i]) / 4095.00));
tensionlog[i] = (log10(tension[i] - TensionStartTop[i]) * k * klog) + (4095 - (log10(4095 - TensionStartTop[i]) * k * klog));
tension[i] = tensionlin[i] - tensionlog[i] + tension[i];
tension[i] = constrain(tension[i], TensionStartTop[i], 4095);
//----------------------------------------------------------------------DECAY--
else if (Etat_module[i] == 2) {
tension[i] = TensionStartTop[i] - ((TensionStartTop[i] - TensionRefS[i]) * (k_timer[i] * tempsreel[i] / TimeRefD[i] * 2));
if (Choix_forme[i] == 1) { //LOG => EXP en descente
float k = log(TensionStartTop[i] - TensionRefS[i]) * (1 - (k_timer[i] * tempsreel[i] / TimeRefD[i]));
if (k > 16) {
tension[i] = 4095;
tension[i] = exp(k) + TensionRefS[i] - 1;
else if (Choix_forme[i] == 2) { // EXP => LOG en descente
tension[i] = TensionRefS[i] + ((log10((TensionStartTop[i] - (TensionStartTop[i] * (k_timer[i] * tempsreel[i] / TimeRefD[i] * 2))) / (klog * 100))) * ((TensionStartTop[i] - TensionRefS[i]) / log10(TensionStartTop[i] / (klog * 100))));
tension[i] = constrain(tension[i], TensionRefS[i] - 1, 4095);
//----------------------------------------------------------------------SUSTAIN--
else if (Etat_module[i] == 3) {
tension[i] = TensionRefS[i];
//----------------------------------------------------------------------RELEASE--
else if (Etat_module[i] == 4) {
tension[i] = TensionStartTop[i] - (k_timer[i] * tempsreel[i] * float(4095.00 / TimeRefR[i] * 2)); // LIN
if (Choix_forme[i] == 1) { // LOG
float k = log(TensionStartTop[i]) * (1 - (k_timer[i] * tempsreel[i] / TimeRefR[i]));
if (k > 16) {
tension[i] = 4095;
tension[i] = exp(k);
tension[i] -= 50;
tension[i] = (log10((TensionStartTop[i] - (TensionStartTop[i] * (k_timer[i] * tempsreel[i] / TimeRefR[i] * 2))) / (klog * 50))) * ((TensionStartTop[i]) / log10(TensionStartTop[i] / (klog * 50)));
tension[i] = constrain(tension[i], 0, TensionRefS[i]);
// ENCHAINEMENT DES PHASES ENTRE ELLES
void AUTOMATE() {
byte mem1 = Etat_module[i];
float mem2 = k_timer[i];
byte k = 1; // V3.01
k = 2; // V3.01
if (Etat_module[i] == 0 && ((Etat_gate_in == 1) + (Choix_gate_in[i] == 1) > 0) ) {
Etat_module[i] = 1;
else if (Etat_module[i] == 1 && Etat_gate_in == 0 && Choix_gate_in[i] == 0 ) {
if (tension[i] > TensionRefS[i]) {
Etat_module[i] = 2;
Etat_module[i] = 4;
else if (Etat_module[i] == 1 && tension[i] >= 4095) {
Etat_module[i] = 2;
else if (Etat_module[i] == 2 && (tension[i] <= TensionRefS[i] || k_timer[i]*tempsreel[i] > TimeRefD[i] / k )) {
if (Etat_gate_in == 1) {
Etat_module[i] = 3;
Etat_module[i] = 4;
else if (Etat_module[i] == 2 && StartTop == 1) {
Etat_module[i] = 1;
StartTop = 0;
else if (Etat_module[i] == 3 && Etat_gate_in == 0) {
Etat_module[i] = 4;
else if (Etat_module[i] == 4 && Etat_gate_in == 1 ) {
Etat_module[i] = 1;
StartTop = 0;
if (Etat_module[i] != mem1 || k_timer[i] != mem2) { // INITIALISATION DE L'INSTANT DE BASCULE ENTRE PHASE
TimerStartTop[i] = micros();
TensionStartTop[i] = constrain(tension[i], 0, 4095);
// CALCUL DE LA DUREE DE LA PHASE (ADR) ASSOCIEE AU POTENTIOMETRE
unsigned long RefTime(unsigned int potar) {
unsigned long k = int(potar * (DureeRef[Choix_timer[i]]));;
k *= float(100000.00 / 1023.00);
k += Offset[i] + 100;
return k;
// LECTURE PERIODIQUE DES INVERSEURS ET POTENTIOMETRES
void IHM()
{ for (int i = 0; i < VCF_VCA ; i++) {
if (Choix_timer[i] == 1) {
k_timer[i] = 1.00;
else {
k_timer[i] = 0.05;
Offset[i] = int(DureeRef[Choix_timer[i]] * 500);
TimeRefA[i] = RefTime(POT[i][0]); TimeRefA[i] /= 2;
TimeRefD[i] = RefTime(POT[i][1]);
TensionRefS[i] = POT[i][2] * 4 ;
TimeRefR[i] = RefTime(POT[i][3]);
