#include <DMAChannel.h>
#define SAMPLES 128
__attribute__((aligned(32))) static uint32_t fm_tx_buffer[SAMPLES];
DMAChannel dma(false);
volatile uint32_t target;
#define TEST 0 // or 1 for variable
target = 0;
for (int i = 0; i < SAMPLES; i++)
fm_tx_buffer[i] = i | (i<<8) | (i<< 16) | (i<<24);
dma.begin(true);
dma.TCD->SADDR = fm_tx_buffer;
dma.TCD->SOFF = 4;
dma.TCD->ATTR = DMA_TCD_ATTR_SSIZE(2) | DMA_TCD_ATTR_DSIZE(2);
dma.TCD->NBYTES_MLNO = 4;
dma.TCD->SLAST = -sizeof(fm_tx_buffer);
dma.TCD->DOFF = 0;
dma.TCD->CITER_ELINKNO = sizeof(fm_tx_buffer) / 4;
dma.TCD->DLASTSGA = 0;
dma.TCD->BITER_ELINKNO = sizeof(fm_tx_buffer) / 4;
#if TEST
dma.TCD->DADDR = ⌖
#else
dma.TCD->DADDR = (void *)((uint32_t)&CCM_ANALOG_PLL_VIDEO_NUM);
dma.enable();
dma.clearError();
int z = 0;
Serial.printf("%x %0x %0x",z, dma.TCD->SADDR, dma.TCD->DADDR);
dma.triggerManual(); z++;
Serial.printf(": %0x\n", target);
if (dma.error()) Serial.println("ERROR");
#define SAMPLES 128
#define TEST 0 // or 0 for PLL
#if TEST != 0
// don't even create this variable when using TEST is 0
// so it can't be accidentally used by mistake from leftover code
volatile uint32_t target = 0;
dma.begin(true);
dma.TCD->SOFF = 4;
dma.TCD->DOFF = 0;
#if TEST
dma.TCD->DADDR = ⌖
#else
dma.enable();
int z = 0;
#if TEST
#else
Serial.printf(": %0x\n", CCM_ANALOG_PLL_VIDEO_NUM);
