Results 1 to 11 of 11
Thread: GPS reception blocked by RFI
    Nov 2018
    Netherlands
    152
    Hi there,
    I am using a Teensy 3.6 audio project using the audioboard getting samples on a high rate and a displaying waterfall or spectrum on an Ili9341 3.2" display. (Teensy bat detector thread).
    Since I wanted to store location information in the waf file metadata I added a GPS receiver.
    I chose a tiny board using an ATGM336H and mini antenna.
    The GPS testcode works fine (TinyGPS) but when the bat detector code is running the GPS reception is lost. Looking at my spectrumanalyzer I can see the whole RF spectrum lifting up when I change from the testcode to the batdetector code. (Can't measure above 1024mHz)
    I can't get a GPS fix indoor and outdoor it takes a very long time to get a fix if I mount the antenna and GPS receiver outside the box. (when running the testcode I can get a GPS fix indoor) Of course I'd like to have all in the small plastic enclosure.
    Do any of you have similar experiences, do you have suggestions for alternative GPS receivers or ideas to improve reception? I am a HAM Radio amateur and already tried some ferrite beads around wires and coaxial cable of the antenna but that does not seem to help. (or at least does not help enough)
    Kind regards,
    Edwin
    13,747
    Any chance it is running short of power? No doubt you are seeing the RF Noise - just wondering ... Also - What is the satellite transmission freq?
    Years back running GPS and IMU I could power the GPS from Teensy but IIRC @mjs513 with similar setup - maybe then on T_3.5 had to power GPS another way. I never saw his setup - but was never clear why it was different.
    In use here was an adafruit ultimate with antenna on the same PCB and I could get indoor ( in a window ) locks - and I just powered the GPS up the other week and got locks on two diff GPS units - but one took a long time after being off a year or two with a dead battery - then adjusting window position.
    Nov 2018
    Netherlands
    152
    I tried several power sources, and planned it to be running from the "powerbank" that also powers the Teensy via a small RC filter. It already proved to be hard to keep all the data signals and pulsed power users like SD-card writing out of the recordings.
    Internally it uses 3.3v I guess but it is claimed to work between 3.3 and 5V giving 3.3v serial ttl output
    The frequency used is about 1575mHz and usually there is an amplifier in the antenna which makes it hard to filter out any rf signals that are picked up by the antenna.
    The adafruit GPS is quite large, and for building it into a detector a unit with a separate antenna would probably be better.
    The when I run the testcode in the detector is can see a quick satellite fix via de serial monitor. As soon as the Teensy is busy running the detector code the signal gets lost.
    23,989
    My guess is the SPI signals. Maybe add resistors between Teensy and the wires going to that display.
    2,620
    I had problems loosing GPS lock when powering up T4.1+ethernet and using an Adafruit ultimate GPS. I finally bought an external antenna and placed the antenna on windowsill. see thread
    https://forum.pjrc.com/threads/61581...4-1-NTP-server
    I haven't tried it, but sparkfun has an antenna eval board https://www.sparkfun.com/products/15247
    Nov 2018
    Netherlands
    152
    Thanks Paul, I have a resistor in every dataline (150 ohms). The TeensyBat detector already needed them to keep the the noise out of the bat sound recordings.
    I'm afraid an external antenne in the windowstill is not an option for a small portable device.... The sparkfun board is a nice one to test out some external antennae. A lot of boards use external antennas with built-in amplifiers (LNA) maybe it is beter to use a passive antenna, a good bandfilter and amplify afterwards.
    I guess the Adafruit Ultimate uses a passive external antenna....
    Jul 2020
    913
    EMI absorbing sheets might be another approach, such as Kemet FX5. Place behind the GPD antenna...
    May 2015
    USA
    845
    Note that a GPS requires far less noise during acquisition. So in some cases, you can power up the GPS, acquire a lock and then power up the noisy circuitry.
    Distance (even say from 1" to 3") makes a difference. So does a better antenna and a small ground plane. Using a phone + bluetooth is another option.
    Aug 2019
    southwest USA
    127
    i have a drone w gps - very small antenna. outdoors lock 3-4+ sat usually takes 1-2 minits.
    indoors (tile roof) often takes 5-6 minits
    and as jonr says, once it has aquired, i can carry it inside no problem
    Nov 2018
    Netherlands
    152
    Thank you for your replies, materials like fx5 are new to me I will look into that.
    My detector is portable only about 3x5x1.5 inches the Teensy is just about in the middle and the display is covering most of the front. It is hard to find a place away from noisy circuits.
    In the meantime I have tried two other GPS units to see if they are performing better tan the ATGM336H. I tried a Beitian BN-180 and a similar style and size Sunsun gps module Both have the antenna mounted directly to the gps unit.
    It seems that the Beitian has much better immunity to the noise the detector creates. The Sunsun has the same problems as the ATGM336H. I liked the ATGM336H better because it seemed to find a solid fix faster and current drawn was less.
    I guess I will keep the Beitian for now and might try some other gps units because there seems to be quite a bit of difference between the ones I tried now.
    It might also be interesting to try and add a tin shield around the hart of the unit.
    Edwin
    Nov 2018
    Netherlands
    152
    I tried several gps units, my test were all indoor under a thin flat roof with thin board and thick polystyrene insulation, old bitumen and layer of EPDM rubber.
    Over the Teensy I mounted a small tinned metal sheet, over the full lenght of the Teeny, keeping theends open. Hovering over the audioboard, attached to the ground pin and soldered to the ground plane of the mainboard of my project.
    The ATGM336H, Ublox NEO8/7/6 I tested were all with an external antenne and I lost GPS reception the moment the Teensy 3.6 was running the bat detector code. Ferrite cores on the coaxial cable seemed to help a little but indoors the reception was gone.
    After this I tied several units with 18x18mm antenna directly on the GPS module.
    A Sunsun? SR1818U8 and A Cirocomm? OP/NZ/N32 (in translucent plastic housing) also lost GPS reception when I used the bat detector code.
    All those mentioned above did work fine just running the GPS testcode.
    The only two left are a Beitian BN180 and a ublox Neo8 which also had the antenna mounted directly on the GPS board. The Beitian has a slightly smaller size pcb and the antenna is a little thinner making it easier to put it in the housing. This one performed quite well indoors. I had the best reception however with the Ubox NEO8 variant.
    The logo shows HGLTECH and the description: High Quality 8M M8N GPS Module. I could however not properly mount this, the unit was too thick, board to long and connector to bulky (ony talking millimeters here) After taking off the connector and soldering the VCC wire and TXD wire to the board It could fit in the housing.
    This last one was the best unit I tested, all came from Chinese sellers and were under 10 euro's.
    I only tested units that were small enough to fit in my detector. I am sure there are many others that I could have tested but but the 18x18 with the antenna on the PCB helped me to the the GPS module a few more centimeters from the Teensy and have the least wires to pick up the noise.
    By now I can start building some GPS projects I have 8 different models eft over after my experiments....
    I hope this helps other people so they dont have to try that many GPS units.....
    I am sure many more of them will work oudoors but I just wanted to be sure to find the best working ones so even in the woods or between houses I still have the best chance of GPS reception.
    Kind regards,
    Edwin
