Teensy 3.5 Use of A10 as digital write.
mikeleslie
Perhaps I'm an idiot, but I can't seem to do a basic digital write when using A10. It works fine on the other 20 pins I'm using. Is there something special I need to do? I even tried the blink sketch and just changed 13 to A10...and nada..
const int ledPin =  13;      // the number of the LED pin
const int ledPin2 =  A10;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
long interval = 5000;           // interval at which to blink (milliseconds)
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    previousMillis = currentMillis;
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(ledPin, ledState);
    digitalWrite(ledPin2, ledState);
which is why I also tried it as an analog write, with the same results. I thought this should be able to light a 3v LED...
  pinMode(A10, OUTPUT);
      analogWrite(A10, 255);
The only thing I can think of is that somehow I "broke" my A10 port
On the Teensy 3.2, 3.5 and 3.6, the following pins are only for analog input (i.e. you can't do digital read, digital write or analog write, you can only do analog read):
  • A10, A11
On the Teensy 3.5 and 3.6, the following pins are only for analog input or real analog output (i.e. the voltage varies, it doesn't flash the pin with PWM, like analog write does with digital pins):
  • A21, A22
