Results 1 to 5 of 5
Thread: Teensy 3.5 Use of A10 as digital write.
    Seattle, WA
    30
    Perhaps I'm an idiot, but I can't seem to do a basic digital write when using A10. It works fine on the other 20 pins I'm using. Is there something special I need to do? I even tried the blink sketch and just changed 13 to A10...and nada..
    const int ledPin =  13;      // the number of the LED pin
    const int ledPin2 =  A10;      // the number of the LED pin
    // Variables will change:
    int ledState = LOW;             // ledState used to set the LED
    long previousMillis = 0;        // will store last time LED was updated
    long interval = 5000;           // interval at which to blink (milliseconds)
      pinMode(ledPin, OUTPUT);
      pinMode(ledPin2, OUTPUT);
      unsigned long currentMillis = millis();
      if(currentMillis - previousMillis > interval) {
        previousMillis = currentMillis;
        if (ledState == LOW)
          ledState = HIGH;
          ledState = LOW;
        digitalWrite(ledPin, ledState);
        digitalWrite(ledPin2, ledState);
    May 2017
    238
    A10 is an analog only pin. It does not have digital drivers.
    https://www.pjrc.com/store/teensy35.html
    Seattle, WA
    30
    which is why I also tried it as an analog write, with the same results. I thought this should be able to light a 3v LED...
      pinMode(A10, OUTPUT);
          analogWrite(A10, 255);
    The only thing I can think of is that somehow I "broke" my A10 port
    4,015
    On the Teensy 3.2, 3.5 and 3.6, the following pins are only for analog input (i.e. you can't do digital read, digital write or analog write, you can only do analog read):
    • A10, A11
    On the Teensy 3.5 and 3.6, the following pins are only for analog input or real analog output (i.e. the voltage varies, it doesn't flash the pin with PWM, like analog write does with digital pins):
    • A21, A22
    Seattle, WA
    30
    Thanks! I was thinking that might be the case but like I said, I'm not always the sharpest tool in the shed.
