Results 1 to 5 of 5
Thread: Teensy 5.0 ?
    Teensy 5.0 ?
    Paul, I bet you are already looking into this.
    1GHz. Multi-core. The DAC would be back.
    https://www.nxp.com/products/process...es:i.MX-RT1170
    3,317
    com'on, there are multiple posts and threads about this!
    Thank you for the pointer, @mjs513! It will be useful to others when searching for Teensy 5.0
    25,028
    Like Teensy 3.5 & 3.6, which were about a 2X step up from Teensy 3.1 & 3.2 but still essentially the same chip architecture, any Teensy using the IMXRT1170 chip will be a 4.x model number. Even though it's a higher clock speed and includes a 2nd M4 processor, the M7 and peripherals are essentially the same as Teensy 4.0. It will NOT be called 5.0.
    When/if we use something like the upcoming Cortex M55, that would be a major change worthy of being called version 5.x.
    Again, this will not be "Teensy 5.0". Please discuss RT1170 the other thread. Closing this one now.
