Results 1 to 5 of 5
Thread: Correct Teensy Board for simple Midi project
    Feb 2021
    4
    I have recently completed a proto type of a project using a teensy 4.0 board. The purpose of the project is to allow me to take a midi signal from a computer and turn on a light.
    The Teensy 4.0 board worked perfectly for this. However I need to make several more and in the interest of keeping costs as low as possible I wondered if I really needed a 4.0
    I have a concern that I'm swatting a mosquito with a canon since all I'm doing is turning a pin on when I see a note go on, and visa versa.
    Anyone have an experience with one of the lower cost Teensy boards for a midi interface?
    -Nathan
    8,625
    Teensy LC. But is has not much RAM and Flash.
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    582
    You can compile your code by selecting the LC in the IDE and see whether RAM and Flash is sufficient.
    Performance-wise, the LC should indeed be OK for your purpose as you describe it.
    Paul
    Feb 2021
    4
    My code used less than a percent of the 4.0 so it sounds like you have both answered my question, thank you very much I didn't feel confident just assuming I'd be OK with that board.
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    290
    surely it have enough memory for that application
    even a pic18f4550 have 32KB flash and 2KB ram
    and that worked super as a midi2uart
    until I did buy a teensy 4 that could also have the synth part
