Page 1 of 2 1 2 LastLast
Results 1 to 25 of 38
Thread: Read .txt file sent from PC
    Nov 2020
    19
    Hi everyone!
    I'm trying to send and read a text file from PC to the teensy. I already created a software on the PC with VS and I managed to send the file to the teensy.
    The file is like this:
    aaaaaaaaaaaaaaaaa
    ddddddddddddddddd
    aaaaaaaaaaaaaaaaa
    void scenario ()
      line[16];
      for (int y = scen_min; y < scen_max; y++)
        if(buffer[y] != ' ')
          line[y] = buffer[y];
      /*for(int y = scen_min; y < scen_max; y++)
        TIME += line[y];
      Serial.print(TIME);*/
      Serial.print(line);
      /*Serial2.println("SCENOK");
      Serial.println("SCENOK");*/
    With this piece of code I managed to print all the lines from the file.
    But when I try in the loop to show one line at a time, I can't make it show one line at a time, it only shows the last line all the time.
    I'm new in coding, so if anyone could help me it would be very nice.
    Thanks,
    Jonathan
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    264
    If you post the whole code it would be much easier to find the problem.
    Nov 2020
    19
    You're right, sorry
    char buffer[1000];  //buffer for serial data recive from PC
    bool scenario1 = false;
    char line[17];
    int scen_min = 0;
    int scen_max = 18;
      /*--get module gsm wake up-----*/
      pinMode(FONA_KEY, OUTPUT);
      digitalWrite(FONA_KEY, PIN_ON);  //
      delay(200); //POUR REVEILLER LE GSM FAUT FAIRE UN HIGH DE 200MS SUR LE PIN FONA_KEY
      digitalWrite(FONA_KEY, PIN_OFF);    //
      /*-------CONFIG SERIAL PORT FOR GSM-------*/
      fonaSerial->begin(4800);
      /*-------CONFIG SERIAL PORT FOR GPS-------*/
      Serial4.begin(4800);
      /*-------CONFIG SERIAL PORT FOR PC--------*/
      Serial2.begin(9600);
    }/* FIN  setup */
     while (Serial2.available () > 0)
        ReadDataPC (Serial2.read ());
     if (scenario1)
        scenario1 = false;
        //Serial.println("SCENOK");
    while (Serial4.available () > 0) {
        ReadTimeGPS(Serial4.read ());  //mise a jour des heures minutes et secondes temps reel gps
    void DataPC()
      Serial.println(buffer[0]);
      switch (buffer[0])  // premier case de data recu determine dans quelle cas de config on se trouve
        case '0':   //reception des trame configuration
          configuration();
        case '1': // cas ou l'operateur n'a pas recu le premier sms on renvoye a nouveau
          Send_msg(_message);
        case '2': // cas ou le congig gsm a echué on refait une tentative
          config_gsm ();
        case '3': // cas ou le congig gps a echué on refait une tentative
          config_gps ();
        case '4': // cas ou le congig gps a echué on refait une tentative
          config_servo ();
        case '5': // reception scenario1
          scenario1 = true;
          scenario();
        case '6': //reception scenario2
          scenario2 = true;
        case '7': // reception scenario3
          scenario3 = true;
        case '8': // start
          Serial2.println( "STARTOK");
          startOK = true;
          Serial.println( "STARTOK");
          start_enrg = true;
        case '9': // stop
          Serial2.println( "STOP");
          Serial.println( "STOP");
          startOK = false;
          compteur10 = 0;
        case 'A': // SI LE PC REPOND PRESENT IL PEUX ENVOYER LES ENREGISTREMENTS
          send_enrg = true;
          Serial.println("RECU A");
    void configuration()
      config_servo();
      config_gps();
      config_gsm();
      Serial2.println( "GSM_OK");
      Serial2.println("MSG_SEND");
      Serial2.println("SERVO_OK");
    void scenario ()
      line[16];
        TIME += line[y];
      Serial.print(line);
    void config_gps ()
      Serial2.println("GPS_OK");
      Serial.println("GPS_OK");
    void config_gsm ()
      if (!fona.begin(*fonaSerial))
        Serial2.println( "GSM_FAIL");
        Serial.println( "GSM_FAIL");
        Serial.println( "GSM_OK");
        Send_msg( _message );
    void config_servo ()
      XreSmdr = buffer[46];
      Serial.println(buffer);
      for (int x = indexservo_min; x < indexservo_max; x++)
        if (buffer[x] == '1')
          Serial.print(   "modex_resmdr= " + XreSmdr + buffer[x]);  //FAUT RAMPLCER SERIAL PRINT PAR LA COMMANDE SEND SUR BUS CAN
    void Send_msg(char *  message )
      char  nu_telefone[14];
      for (int i = 1; i < 15; i++)
        if (buffer[i] != ' ')
          nu_telefone[i - 1] =  buffer[i];
      fona.sendSMS(nu_telefone, message);
      Serial.println("MSG_SEND");
    What's the next step to make the the teensy read the lines on the loop?
    Jun 2020
    Sweden
    264
    that cannot be the whole code
    as the function calls
    is missing the functions in the code
    if it is DataPC then you are missing to fill the buffer before call
    ex in loop
    it should be something like this (with rxPointer as a global int):
        byte rxByte = Serial2.read();
        buffer[rxPointer++] = rxByte;
        if (rxByte == '\n') {
            DataPC();
            rxPointer=0; // reset pointer to make it ready for the next data line
    there is the
    Serial.readBytesUntil(character, buffer, length)
    but that blocks the main "thread" until it have read all characters
    so it should be avoided.
    Nov 2020
    19
    Sorry, you right. I forgot the ReadDataPc()
    void ReadDataPC (const byte inByte)
      static char input_line [MAX_INPUT];
      static unsigned int input_pos = 0;
      switch (inByte)
        case '\n':   // end of text
          buffer [input_pos] = '\n';
          DataPC();
          // reset buffer  next time
          input_pos = 0;
        case '\r':   // discard carriage return
        default:
          if (input_pos < (MAX_INPUT - 1))
            buffer [input_pos++] = inByte;
    Nov 2020
    19
    Oh.... I forgot to mention an important point, I send the entire file at once to the teensy
    Jun 2020
    Sweden
    264
    I think you are missing to compare with if(buffer[y] != '\n') in:
    (corrected with \n)
    void scenario ()
      line[16];
        if(buffer[y] != '\n')  // <--- corrected here
        TIME += line[y];
      Serial.print(line);
    Nov 2020
    19
    I already tried that, but like that it doesn't even print anything
    Jun 2020
    Sweden
    264
    sending the whole file should not be a problem
    unless the file is very big
    and the input buffer of the Serial port gets overflowed by incoming data.
    Nov 2020
    19
    No, the file is not that big. I can see that the file is well received when i print it on the serial. I get this:
    5aaaaaaaaaaaaaaaaa5
    5ddddddddddddddddd5
    5aaaaaaaaaaaaaaaab
    The "5" is "case" number on teensy. But when I print it on the loop, I only get this:
    aaaaaaaaaaaaaaaab
    Can't manage to show the other lines
    Jun 2020
    Sweden
    264
    void scenario ()
      //line[16]; // don't know what this should be doing so I comment it out
             line[y] = 0x00; // null character is needed for the Serial.print
             break; // end the for loop
        TIME += line[y];
      Serial.print(line);
    Nov 2020
    19
    It didn't work...
    Damn... I'm completely out of ideas
    Jun 2020
    Sweden
    264
    was thinking the serial print was smarter but:
    the Serial.print don't take byte array as input (only String)
    so the proper print of array buffer would be:
    for (int i = 0; buffer[i] != '\n'; i++) Serial.print(buffer[i]);
    Serial.print('\n'); // or Serial.println();
    but maybe just do it directly in the first loop:
    void scenario ()
          line[y] = buffer[y]; // use for other things?
          Serial.print(buffer[y]);
             line[y] = 0x00; // null character is good to have in end of string
             Serial.print('\n');
        TIME += line[y];
      //Serial.print(line);
    1,424
    Serial.write() takes byte arrays...
    And Serial.printf takes char arrays...
    Nov 2020
    19
    It doesn't work... when I use '\n' it doesn't even print on the loop, when I use ' ', well it prints but only the last line.
    Isn't there a function to send it read the first line again?
    Sorry, but I'm really new to this...... this is a university project, complex one...
    Jun 2020
    Sweden
    264
    @ luni Yes they do,
    But the Serial.print function don't take array as the input (have checked the Print.cpp source)
    which is really dumb as you are forced to use the formatted printf which is little overkill in this situation
    and using Serial.write also is overkill as it need the size parameter
    why just not have a simple Serial.print that takes array as input and the only requirement is that the array ends with null char.
    this is why I always did my libraries from scratch.
    Jun 2020
    Sweden
    264
    maybe it's safer to use
    println()
    instead of
    print('\n')
    as your terminal program maybe listens for \r\n
    and the println includes \r\n
    1,424
    Quote Originally Posted by manicksan View Post
    @ luni Yes they do,
    I'm probably missing something but
        while(!Serial);
        char test[] = "Hello World\n";
        Serial.print(test);
    prints "Hello World" here.
    Jun 2020
    Sweden
    264
    but then when I'm looking at Print.h file
    there is this
    size_t print(const char s[])
    which seems to take a array buffer
    Nov 2020
    19
    Still not working, still only printing the last line... and yes probably my program uses \r\n, because it's a windows forms...
    Any other idea?
    Jun 2020
    Sweden
    264
    I find this unexplained (with the first only working):
      Serial1.begin(9600);
      while (Serial.available () > 0)
        Serial.write('0');
        Serial.write(Serial.read());
      while (Serial1.available () > 0)
        Serial1.write('1');
        Serial1.write(Serial1.read());
        Serial2.write('2');
        Serial2.write(Serial2.read());
    I am using triple usb serial,
    can anyone verify what the different Serial Serial1 Serial3 and so on is used for
    Jun 2020
    Sweden
    264
    ok found it
    https://www.pjrc.com/teensy/td_uart.html
    but then how do you use the dual or triple usb serial
    Jun 2020
    Sweden
    264
    this simplified example works for me
    char buff[1000];  //buffer for serial data recive from PC
    char line[17];
    int scen_min = 0;
    int scen_max = 18;
    }/* FIN  setup */
      ReadDataPCTask();
    void ReadDataPCTask()
      while (Serial.available() > 0)
        char inByte = Serial.read();
        //static char input_line[scen_max];
        switch (inByte)
            buff[input_pos] = '\n';
            DataPC();
            input_pos = 0;
          default:
            if (input_pos < (scen_max - 1))
              buff[input_pos++] = inByte;
    void DataPC()
      //Serial.println(buffer[0]);
      switch (buff[0])  // premier case de data recu determine dans quelle cas de config on se trouve
          //scenario1 = true;
          scenario();
    void scenario ()
        if(buff[y] != '\n')
          line[y] = buff[y]; // use for other things?
          //Serial.print(buffer[y]);
             line[y] = '\r';
             line[y+1] = '\n';
             line[y+2] = 0x00; // null character is good to have in end of string
             //Serial.println();
      Serial.print(line);
  24. #24
    Jun 2020
    Sweden
    264
    i can send this line without any problem ($0a is the \n in the terminal program that I use)
    5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaasbaaaa$0a5aaabaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a5aaaaaaaaaa$0a
    which returns
  25. #25
    May 2017
    238
    char line[17];
    int scen_min = 0;
    int scen_max = 18;
    void scenario ()
      line[16];
    line holds 17 characters, but putting in 18. Buffer overflow as well as no space for the terminating zero that is needed.
