Hi there,
I've reduced the audio block size to reduce the latency and looks like there are only 2 things that are having a different behaviour in my project,
one is the spectrum analyzer, which needs some adjust in the scale and also in the 'peak hold', which is not a problem,
the other one in the bitcrusher when a hard quantization of the sample rate is applied (bit depth quantization seems not be affected, which makes sense for being a 'vertical' operation)
any suggestion about how to fix that?
