Results 1 to 13 of 13
Thread: Strange error in complilig sketch for Simplewavetable
    Hello.
    I have a strange error in this sketch at instrucion:
    wavetable.setInstrument(ChurhOrgan),
    No matching funcion for call to "AudioSynthWavetable::setInstrument(const instrument_data&)'
    I have decoded ChurchOrgan with utility Soundfontdecoder from a sf2 files.
    Can anyone help me?
    Thanks you.
    Attached Files Attached Files
    1,876
    In your Churchorgan_samples.h change this line:
    #include <AudioSynthWavetable.h>
    to this:
    #include <synth_wavetable.h>
    It still won't compile but it'll get further along.
    Pete
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    607
    can you post the compile error output
    it can be because you are using a old version of Soundfontdecoder
    Jun 2020
    Sweden
    607
    By the way i did a compile myself
    There is some reference errors.
    As I also had problems the first time
    and the problem is in the soundfontdecoder.
    Have you a Soundfontdecoder.exe updated?
    I am not able to use python bat.
    Thanks you.
    Jun 2020
    Sweden
    607
    I had little time when I did the last post
    there has been some changes to the synth_wavetable.h and the soundFontDecoder provided at PaulStoffregen:s github is not updated
    I have attached the new version of soundFontDecoder which also includes new options for both teensy 4.0 and teensy 4.1
    there is a nice library here (extracted from the GM by wrightflyer using a updated version of the soundFontDecoder)
    https://github.com/wrightflyer/Synth...c/GMinstrument
    you can read this post by wrightflyer how to use them all
    https://forum.pjrc.com/threads/65740...l=1#post266172
    or else if you want to you can change the header yourself (but that will only solve the problem for your current converted soundfont)
    this is the right "header" this is just an example and you need to do the changes yourself to match
    static const AudioSynthWavetable::sample_data MmmmHumSynth_samples[1] = {
    		(int16_t*)sample_0_MmmmHumSynth_MMMMM, // sample
    		true, // LOOP
    		15, // LENGTH_BITS
    		(1 << (32 - 15)) * WAVETABLE_CENTS_SHIFT(-73) * 44100.0 / WAVETABLE_NOTE_TO_FREQUENCY(72) / AUDIO_SAMPLE_RATE_EXACT + 0.5, // PER_HERTZ_PHASE_INCREMENT
    		((uint32_t)21844 - 1) << (32 - 15), // MAX_PHASE
    		((uint32_t)21843 - 1) << (32 - 15), // LOOP_PHASE_END
    		(((uint32_t)21843 - 1) << (32 - 15)) - (((uint32_t)4817 - 1) << (32 - 15)), // LOOP_PHASE_LENGTH
    		uint16_t(UINT16_MAX * WAVETABLE_DECIBEL_SHIFT(-0.0)), // INITIAL_ATTENUATION_SCALAR
    		uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // DELAY_COUNT
    		uint32_t(1.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // ATTACK_COUNT
    		uint32_t(0.98 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // HOLD_COUNT
    		uint32_t(1.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // DECAY_COUNT
    		uint32_t(2500.99 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // RELEASE_COUNT
    		int32_t((1.0 - WAVETABLE_DECIBEL_SHIFT(-0.0)) * AudioSynthWavetable::UNITY_GAIN), // SUSTAIN_MULT
    		uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / (2 * AudioSynthWavetable::LFO_PERIOD)), // VIBRATO_DELAY
    		uint32_t(0.1 * AudioSynthWavetable::LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // VIBRATO_INCREMENT
    		(WAVETABLE_CENTS_SHIFT(0) - 1.0) * 4, // VIBRATO_PITCH_COEFFICIENT_INITIAL
    		(1.0 - WAVETABLE_CENTS_SHIFT(0)) * 4, // VIBRATO_COEFFICIENT_SECONDARY
    		uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / (2 * AudioSynthWavetable::LFO_PERIOD)), // MODULATION_DELAY
    		uint32_t(5.4 * AudioSynthWavetable::LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // MODULATION_INCREMENT
    		(WAVETABLE_CENTS_SHIFT(0) - 1.0) * 4, // MODULATION_PITCH_COEFFICIENT_INITIAL
    		(1.0 - WAVETABLE_CENTS_SHIFT(0)) * 4, // MODULATION_PITCH_COEFFICIENT_SECOND
    		int32_t(UINT16_MAX * (WAVETABLE_DECIBEL_SHIFT(0) - 1.0)) * 4, // MODULATION_AMPLITUDE_INITIAL_GAIN
    		int32_t(UINT16_MAX * (1.0 - WAVETABLE_DECIBEL_SHIFT(0))) * 4, // MODULATION_AMPLITUDE_FINAL_GAIN
    this is the "header" from ChurchOrgan_samples.cpp which is incorrect
    const sample_data ChurchOrgan_samples[1] = {
    		(int16_t*)sample_0_ChurchOrgan_ChurchOrgC3,	//16-bit PCM encoded audio sample
    		true,	//Whether or not to loop this sample
    		12,	//Number of bits needed to hold length
    		(1048576*0.9885140203528962*(44100.0 / AUDIO_SAMPLE_RATE_EXACT)) / 391.99543598174927 + 0.5,	//((0x80000000 >> (index_bits - 1)) * cents_offset * sampling_rate / AUDIO_SAME_RATE_EXACT) / sample_freq + 0.5
    		((uint32_t)3966-1) << (32 - 12),	//(sample_length-1) << (32 - sample_length_bits)
    		((uint32_t)3958-1) << (32 - 12),	//(loop_end-1) << (32 - sample_length_bits) == LOOP_PHASE_END
    		(((uint32_t)3958-1) << (32 - 12)) - (((uint32_t)3736-1) << (32 - 12)),	//LOOP_PHASE_END - (loop_start-1) << (32 - sample_length_bits) == LOOP_PHASE_END - LOOP_PHASE_START == LOOP_PHASE_LENGTH
    		uint16_t(UINT16_MAX * DECIBEL_SHIFT(-1500/100.0)), //INITIAL_ATTENUATION_SCALAR
    		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//DELAY_COUNT
    		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//ATTACK_COUNT
    		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//HOLD_COUNT
    		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//DECAY_COUNT
    		uint32_t(654*SAMPLES_PER_MSEC/8.0+0.5),	//RELEASE_COUNT
    		int32_t(0*UNITY_GAIN),	//SUSTAIN_MULT
    		uint32_t(0 * SAMPLES_PER_MSEC / (2 * LFO_PERIOD)), 	// VIBRATO_DELAY
    		uint32_t(672/1000.0 * LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // VIBRATO_INCREMENT
    		(CENTS_SHIFT(-0/1000.0) - 1.0)*4, // VIBRATO_PITCH_COEFFICIENT_INITIAL
    		(1.0 - CENTS_SHIFT(0/1000.0))*4, // VIBRATO_COEFFICIENT_SECONDARY
    		uint32_t(0 * SAMPLES_PER_MSEC / (2 * LFO_PERIOD)), // MODULATION_DELAY
    		uint32_t(672/1000.0 * LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // MODULATION_INCREMENT
    		(CENTS_SHIFT(-0/1000.0) - 1.0)*4, // MODULATION_PITCH_COEFFICIENT_INITIAL
    		(1.0 - CENTS_SHIFT(0/1000.0))*4, // MODULATION_PITCH_COEFFICIENT_SECOND
    		int32_t(UINT16_MAX * (DECIBEL_SHIFT(-0.1) - 1.0)) *4, // MODULATION_AMPLITUDE_INITIAL_GAIN
    		int32_t(UINT16_MAX * (1.0 - DECIBEL_SHIFT(0.1))) *4, // MODULATION_AMPLITUDE_FINAL_GAIN
    Jun 2020
    Sweden
    607
    a note about the attached SoundfontDecoder
    it only contains the changed files and must be extracted in your current SoundfontDecoder folder
    1,876
    The attached version compiles. I mangled the code until it looked like the example in Files/Examples/Audio/Synthesis/WaveTable/Simpletable.
    SimpleWavetable_ver004_1.zip
    Pete
    Pete
    Thanks you for reply.
    But now I have this error:
    Scuse me: It works very well!!!!!!!
    Thanks you
    Quote Originally Posted by Gennaro Pirozzi View Post
    Thanks you
    Now I am searching for Soundfontdecoder.exe update. Have this .exe?
    Thanks you.
    Pete
    have you a sounfontdecoder.exe update?
    I am non able to use python.
    Thanks you.
    the attached version compiles. I mangled the code until it looked like the example in files/examples/audio/synthesis/wavetable/simpletable.
    pete
    thanks you: I resolved error and now it works very well.
