I had little time when I did the last post
there has been some changes to the synth_wavetable.h and the soundFontDecoder provided at PaulStoffregen:s github is not updated
I have attached the new version of soundFontDecoder which also includes new options for both teensy 4.0 and teensy 4.1
there is a nice library here (extracted from the GM by wrightflyer using a updated version of the soundFontDecoder)
https://github.com/wrightflyer/Synth...c/GMinstrument
you can read this post by wrightflyer how to use them all
https://forum.pjrc.com/threads/65740...l=1#post266172
or else if you want to you can change the header yourself (but that will only solve the problem for your current converted soundfont)
this is the right "header" this is just an example and you need to do the changes yourself to match
static const AudioSynthWavetable::sample_data MmmmHumSynth_samples[1] = {
(int16_t*)sample_0_MmmmHumSynth_MMMMM, // sample
true, // LOOP
15, // LENGTH_BITS
(1 << (32 - 15)) * WAVETABLE_CENTS_SHIFT(-73) * 44100.0 / WAVETABLE_NOTE_TO_FREQUENCY(72) / AUDIO_SAMPLE_RATE_EXACT + 0.5, // PER_HERTZ_PHASE_INCREMENT
((uint32_t)21844 - 1) << (32 - 15), // MAX_PHASE
((uint32_t)21843 - 1) << (32 - 15), // LOOP_PHASE_END
(((uint32_t)21843 - 1) << (32 - 15)) - (((uint32_t)4817 - 1) << (32 - 15)), // LOOP_PHASE_LENGTH
uint16_t(UINT16_MAX * WAVETABLE_DECIBEL_SHIFT(-0.0)), // INITIAL_ATTENUATION_SCALAR
uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // DELAY_COUNT
uint32_t(1.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // ATTACK_COUNT
uint32_t(0.98 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // HOLD_COUNT
uint32_t(1.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // DECAY_COUNT
uint32_t(2500.99 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // RELEASE_COUNT
int32_t((1.0 - WAVETABLE_DECIBEL_SHIFT(-0.0)) * AudioSynthWavetable::UNITY_GAIN), // SUSTAIN_MULT
uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / (2 * AudioSynthWavetable::LFO_PERIOD)), // VIBRATO_DELAY
uint32_t(0.1 * AudioSynthWavetable::LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // VIBRATO_INCREMENT
(WAVETABLE_CENTS_SHIFT(0) - 1.0) * 4, // VIBRATO_PITCH_COEFFICIENT_INITIAL
(1.0 - WAVETABLE_CENTS_SHIFT(0)) * 4, // VIBRATO_COEFFICIENT_SECONDARY
uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / (2 * AudioSynthWavetable::LFO_PERIOD)), // MODULATION_DELAY
uint32_t(5.4 * AudioSynthWavetable::LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // MODULATION_INCREMENT
(WAVETABLE_CENTS_SHIFT(0) - 1.0) * 4, // MODULATION_PITCH_COEFFICIENT_INITIAL
(1.0 - WAVETABLE_CENTS_SHIFT(0)) * 4, // MODULATION_PITCH_COEFFICIENT_SECOND
int32_t(UINT16_MAX * (WAVETABLE_DECIBEL_SHIFT(0) - 1.0)) * 4, // MODULATION_AMPLITUDE_INITIAL_GAIN
int32_t(UINT16_MAX * (1.0 - WAVETABLE_DECIBEL_SHIFT(0))) * 4, // MODULATION_AMPLITUDE_FINAL_GAIN
this is the "header" from ChurchOrgan_samples.cpp which is incorrect
const sample_data ChurchOrgan_samples[1] = {
(int16_t*)sample_0_ChurchOrgan_ChurchOrgC3, //16-bit PCM encoded audio sample
true, //Whether or not to loop this sample
12, //Number of bits needed to hold length
(1048576*0.9885140203528962*(44100.0 / AUDIO_SAMPLE_RATE_EXACT)) / 391.99543598174927 + 0.5, //((0x80000000 >> (index_bits - 1)) * cents_offset * sampling_rate / AUDIO_SAME_RATE_EXACT) / sample_freq + 0.5
((uint32_t)3966-1) << (32 - 12), //(sample_length-1) << (32 - sample_length_bits)
((uint32_t)3958-1) << (32 - 12), //(loop_end-1) << (32 - sample_length_bits) == LOOP_PHASE_END
(((uint32_t)3958-1) << (32 - 12)) - (((uint32_t)3736-1) << (32 - 12)), //LOOP_PHASE_END - (loop_start-1) << (32 - sample_length_bits) == LOOP_PHASE_END - LOOP_PHASE_START == LOOP_PHASE_LENGTH
uint16_t(UINT16_MAX * DECIBEL_SHIFT(-1500/100.0)), //INITIAL_ATTENUATION_SCALAR
uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5), //DELAY_COUNT
uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5), //ATTACK_COUNT
uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5), //HOLD_COUNT
uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5), //DECAY_COUNT
uint32_t(654*SAMPLES_PER_MSEC/8.0+0.5), //RELEASE_COUNT
int32_t(0*UNITY_GAIN), //SUSTAIN_MULT
uint32_t(0 * SAMPLES_PER_MSEC / (2 * LFO_PERIOD)), // VIBRATO_DELAY
uint32_t(672/1000.0 * LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // VIBRATO_INCREMENT
(CENTS_SHIFT(-0/1000.0) - 1.0)*4, // VIBRATO_PITCH_COEFFICIENT_INITIAL
(1.0 - CENTS_SHIFT(0/1000.0))*4, // VIBRATO_COEFFICIENT_SECONDARY
uint32_t(0 * SAMPLES_PER_MSEC / (2 * LFO_PERIOD)), // MODULATION_DELAY
uint32_t(672/1000.0 * LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // MODULATION_INCREMENT
(CENTS_SHIFT(-0/1000.0) - 1.0)*4, // MODULATION_PITCH_COEFFICIENT_INITIAL
(1.0 - CENTS_SHIFT(0/1000.0))*4, // MODULATION_PITCH_COEFFICIENT_SECOND
int32_t(UINT16_MAX * (DECIBEL_SHIFT(-0.1) - 1.0)) *4, // MODULATION_AMPLITUDE_INITIAL_GAIN
int32_t(UINT16_MAX * (1.0 - DECIBEL_SHIFT(0.1))) *4, // MODULATION_AMPLITUDE_FINAL_GAIN
