For my FM Stereo / RDS transmitter I want to change the behavior of println.
It should only output \r instead of \r\n.
\n is "Clear Screen" in the RDS protocol - and this is, let's call it "suboptimal".
(I curse the descendants of the inventor to the 3rd generation)
I can override println(void) - but then i need need to change all other println variants with parameters, too.
Is there a better way?
I have:
So..are the green lines really needed? They are just copy&paste from Print.h ....
I have:
class rds : public Print
virtual size_t write(uint8_t);
virtual size_t write(const uint8_t *buffer, size_t size);
[COLOR=#ff0000] size_t println(void) { return write('\r'); }[/COLOR]
[COLOR=#00ff00] size_t println(const String &s) { return print(s) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(char c) { return print(c) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(const char s[]) { return print(s) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(const __FlashStringHelper *f) { return print(f) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(uint8_t b) { return print(b) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(int n) { return print(n) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(unsigned int n) { return print(n) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(long n) { return print(n) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(unsigned long n) { return print(n) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(int64_t n) { return print(n) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(uint64_t n) { return print(n) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(unsigned char n, int base) { return print(n, base) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(int n, int base) { return print(n, base) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(unsigned int n, int base) { return print(n, base) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(long n, int base) { return print(n, base) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(unsigned long n, int base) { return print(n, base) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(int64_t n, int base) { return print(n, base) + println(); }[/COLOR]
[COLOR=#00ff00] size_t println(uint64_t n, int base) { return print(n, base) + println(); } [/COLOR]
