Results 1 to 2 of 2
Thread: Serial problem while using SD card
    Jan 2021
    5
    Hello again,
    We are trying to read 320kb txt file to a Micro SD card using an Teensy 3.6. I divided my file into 512 byte buffers in C# and every 65 milliseconds write it to SerialPort. But in Teensy same code goes infinity loop while starting serial (while(!Serial){}).When we replace Serial with Serial1 problem has solved but we could not write buffers to SD card now. Here is the code:
    char gelen[512];
    File myFile;
    // change this to match your SD shield or module;
    // Arduino Ethernet shield: pin 4
    // Adafruit SD shields and modules: pin 10
    // Sparkfun SD shield: pin 8
    // Teensy audio board: pin 10
    // Teensy 3.5 & 3.6 & 4.1 on-board: BUILTIN_SDCARD
    // Wiz820+SD board: pin 4
    // Teensy 2.0: pin 0
    // Teensy++ 2.0: pin 20
    const int chipSelect = BUILTIN_SDCARD;
    const int ledPin = 13;
      pinMode(ledPin, OUTPUT);
     //UNCOMMENT THESE TWO LINES FOR TEENSY AUDIO BOARD:
     //SPI.setMOSI(7);  // Audio shield has MOSI on pin 7
     //SPI.setSCK(14);  // Audio shield has SCK on pin 14
       while (!Serial) {
        digitalWrite(ledPin, HIGH);
        ; // wait for serial port to connect.
      while (!SD.begin(chipSelect)) {
      // open the file.
      myFile = SD.open("test.txt", FILE_WRITE );
    void loop(){
      if(Serial.available()>0)
        Serial.readBytes(gelen,512);
        myFile.println(gelen);
        myFile.flush();
    Thank you.
    May 2017
    256
    println expects a zero terminated char array which you don't have. Also do you really want to put a return/line_feed every 512 characters into your file ?
    I think you will be better served with file.write(buf, len) function.
