Results 1 to 6 of 6
Thread: Teensy 3.6 USBHost interfacing Ableton Push2
    Member Van's Avatar
    Mar 2018
    Dresden, Germany
    54
    hi there!
    I need some help with the push2 when teensy3.6 acts as a USB host.
    the obvious reason is that push2 uses multiple midi interfaces:
    amidi -l
    IO  hw:2,0,0  Ableton Push 2 MIDI 1
    IO  hw:2,0,1  Ableton Push 2 MIDI 2
    IO  hw:3,0,0  Arturia KeyStep 32 MIDI 1
    how can i specify the proper midi port?
    cheers!
    PS. Connecting to a "normal" usb midi keyboard works well.
    Member Van's Avatar
    Mar 2018
    Dresden, Germany
    54
    nobody on this?
    24,080
    Is "push 2" fully USB MIDI class compliant?
    Edit USBHost_t36 to turn on the debug printing. Then capture the huge output and post it here (use the "#" button for code tags).
    Member Van's Avatar
    Mar 2018
    Dresden, Germany
    54
    hey thank you for your attention!
    yes it is class compliant
    https://github.com/Ableton/push-inte...yInterface.asc
    here is my output:
    USB Host Testing
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 82 29 67 19 00 01 01 02 00 01
        VendorID = 2982, ProductID = 1967, Version = 0100
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: Ableton AG
    enumeration:
    Product: Ableton Push 2
    enumeration:
    Config data length = 126
    enumeration:
    Configuration Descriptor:
      09 02 7E 00 03 01 00 80 FA
        NumInterfaces = 3
        ConfigurationValue = 1
      09 04 00 00 02 FF FF FF 03
        Interface = 0
        Number of endpoints = 2
        Class/Subclass/Protocol = 255 / 255 / 255
      07 05 01 02 00 02 00
        Endpoint = 1 OUT
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 81 02 00 02 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 512
      09 04 01 00 00 01 01 00 00
        Interface = 1
        Number of endpoints = 0
        Class/Subclass/Protocol = 1 / 1 / 0
      09 24 01 00 01 09 00 01 02
      09 04 02 00 02 01 03 00 00
        Interface = 2
        Class/Subclass/Protocol = 1 / 3 / 0
      07 24 01 00 01 25 00
      06 24 02 01 01 04
      06 24 02 01 02 05
      09 24 03 01 03 01 01 01 04
      09 24 03 01 04 01 02 01 05
      09 05 02 02 00 02 00 00 00
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 512
      06 25 01 02 01 02
      09 05 82 02 00 02 00 00 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
      06 25 01 02 03 04
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF2DA0
    USBHub claim_device this=1FFF3160
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=1FFF2020
    len = 117
    MIDIDevice claim this=1FFF26E0
    len = 117
    Descriptor 5 = ENDPOINT
    len = 94
    len = 94
    Descriptor 36 =  ???
    len = 76
      Interface is MIDI
    type: 36, len: 7
        MIDI Header (ignored)
    type: 36, len: 6
        MIDI IN Jack (ignored)
    type: 36, len: 6
    type: 36, len: 9
        MIDI OUT Jack (ignored)
    type: 36, len: 9
    type: 5, len: 9
        MIDI Endpoint: 2
          tx_size = 512
    type: 37, len: 6
        MIDI Endpoint Jack Association (ignored)
    type: 5, len: 9
        MIDI Endpoint: 82
          rx_size = 512
    type: 37, len: 6
    len = 76
      Interface is MIDI
    type: 36, len: 7
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 9
    type: 36, len: 9
    type: 5, len: 9
        MIDI Endpoint: 2
          tx_size = 512
    type: 37, len: 6
    type: 5, len: 9
        MIDI Endpoint: 82
          rx_size = 512
    type: 37, len: 6
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    Descriptor 37 =  ???
    24,080
    Are you using the "BigBuffer" version of the MIDI device driver? This is a 480 MBit speed device, so the normal small buffer driver isn't enough.
    Member Van's Avatar
    Mar 2018
    Dresden, Germany
    54
    how can I set the "BigBuffer" version?
    EDIT: I figured it out: I somehow used an older version of the USBHost_t36 lib. Now it works!
    I updated to the newest github version and replaced ...
    MIDIDevice midi1(myusb);
    with
    MIDIDevice_BigBuffer midi1(myusb);
    thank you very much for helping me out!
    cheers!
