defragster
Senior Member+
This 'padding' is interesting note about the 32KB blocking for ITCM : .text.itcm.padding 8548 24220
[ 58.300446] usb 1-1: new high-speed USB device number 2 using ehci-pci
[COLOR=#ff0000][ 58.659302] usb 1-1: config 1 has an invalid interface number: 3 but max is 2[/COLOR]
[COLOR=#ff0000][ 58.659305] usb 1-1: config 1 has no interface number 0[/COLOR]
[ 58.673878] usb 1-1: New USB device found, idVendor=16c0, idProduct=0476
[ 58.673881] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 58.673883] usb 1-1: Product: Teensy MTP Disk/Serial
[ 58.673884] usb 1-1: Manufacturer: Teensyduino
[ 58.673885] usb 1-1: SerialNumber: 7820070
[ 58.690544] cdc_acm 1-1:1.1: ttyACM0: USB ACM device
[ 58.693345] usbcore: registered new interface driver cdc_acm
[ 58.693346] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[COLOR=#000000][ 98.089536] usb 1-1: USB disconnect, device number 2[/COLOR]
[ 98.130423] cdc_acm 1-1:1.1: failed to set dtr/rts
#define VENDOR_ID 0x16C0
#define PRODUCT_ID 0x0476 //fake an include everything device
#define RAWHID_USAGE_PAGE 0xFFAB // recommended: 0xFF00 to 0xFFFF
#define RAWHID_USAGE 0x0200 // recommended: 0x0100 to 0xFFFF
#define DEVICE_CLASS 0xEF
#define DEVICE_SUBCLASS 0x02
#define DEVICE_PROTOCOL 0x01
#define MANUFACTURER_NAME {'T','e','e','n','s','y','d','u','i','n','o'}
#define MANUFACTURER_NAME_LEN 11
#define PRODUCT_NAME {'T','e','e','n','s','y',' ','M','T','P',' ','D','i','s','k','/','S','e','r','i','a','l'}
#define PRODUCT_NAME_LEN 22
#define EP0_SIZE 64
#define NUM_INTERFACE 3
#define NUM_ENDPOINTS 5
#define CDC_IAD_DESCRIPTOR 1 //1
#define CDC_STATUS_INTERFACE 0 //1
#define CDC_DATA_INTERFACE 1 // Serial //2
#define CDC_ACM_ENDPOINT 2 //2
#define CDC_RX_ENDPOINT 3 //3
#define CDC_TX_ENDPOINT 3 //3
#define CDC_ACM_SIZE 16
#define CDC_RX_SIZE_480 512
#define CDC_TX_SIZE_480 512
#define CDC_RX_SIZE_12 64
#define CDC_TX_SIZE_12 64
#define ENDPOINT2_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT3_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define MTP_INTERFACE 2 // MTP Disk
#define MTP_TX_ENDPOINT 4
#define MTP_RX_ENDPOINT 4
#define MTP_EVENT_ENDPOINT 5
#define MTP_TX_SIZE_480 512
#define MTP_RX_SIZE_480 512
#define MTP_TX_SIZE_12 64
#define MTP_RX_SIZE_12 64
#define MTP_EVENT_SIZE 32
#define MTP_EVENT_INTERVAL_12 10 // 10 = 10 ms
#define MTP_EVENT_INTERVAL_480 7 // 7 = 8 ms
#define ENDPOINT4_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define ENDPOINT5_CONFIG ENDPOINT_RECEIVE_INTERRUPT + ENDPOINT_TRANSMIT_INTERRUPT // ????
int count = 0;
while (!Serial && millis() < 5000) ;
// Your computer will receive thesHello World 0e characters from a USB keyboard.
//Keyboard.print("Hello World ");
//Keyboard.println(count);
// You can also send to the Arduino Serial Monitor
Serial.println(count);
// increment the count
count = count + 1;
// typing too rapidly can overwhelm a PC
delay(5000);
08:53:16.374 (post_compile 1): Begin, version=1.54-beta6
08:53:16.660 (loader): Teensy Loader 1.54-beta6, begin program
08:53:16.688 (loader): File "Simple.pde.hex". 18768 bytes, 0% used
08:53:16.689 (loader): Listening for remote control on port 3149
08:53:16.689 (loader): initialized, showing main window
08:53:16.775 (loader): remote connection 9 opened
08:53:16.775 (post_compile 1): Sending command: comment: Teensyduino 1.54-beta6 - LINUX64 (teensy_post_compile)
08:53:16.775 (loader): remote cmd from 9: "comment: Teensyduino 1.54-beta6 - LINUX64 (teensy_post_compile)"
08:53:16.775 (loader): remote cmd from 9: "status"
08:53:16.835 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:16.835 (post_compile 1): Sending command: auto:on
08:53:16.835 (loader): remote cmd from 9: "auto:on"
08:53:16.835 (post_compile 1): Disconnect
08:53:16.846 (loader): remote connection 9 closed
08:53:16.852 (post_compile 2): Begin, version=1.54-beta6
08:53:16.852 (loader): remote connection 9 opened
08:53:16.852 (post_compile 2): Sending command: comment: Teensyduino 1.54-beta6 - LINUX64 (teensy_post_compile)
08:53:16.852 (loader): remote cmd from 9: "comment: Teensyduino 1.54-beta6 - LINUX64 (teensy_post_compile)"
08:53:16.853 (loader): remote cmd from 9: "status"
08:53:16.916 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:16.916 (post_compile 2): Disconnect
08:53:16.926 (post_compile 3): Running teensy_reboot: /home/kurt/Desktop/arduino-1.8.13/hardware/teensy/../tools/teensy_reboot
08:53:16.926 (loader): remote connection 9 closed
08:53:16.926 (loader): remote connection 9 opened
08:53:16.927 (loader): remote connection 9 closed
08:53:16.927 (reboot 4): Begin, version=1.54-beta6
08:53:16.927 (reboot 4): location = /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:16.927 (reboot 4): portlabel = /dev/hidraw6 Keyboard
08:53:16.927 (reboot 4): Only location /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1 will be tried
08:53:16.927 (reboot 4): portprotocol = Teensy
08:53:16.999 (loader): remote connection 9 opened
08:53:17.002 (reboot 4): add device: subsys=usb, type=usb_device, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:17.002 (reboot 4): devnode=/dev/bus/usb/001/022, subsystem=usb, ifacenum=-1
08:53:17.002 (reboot 4): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0
08:53:17.002 (reboot 4): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:17.002 (reboot 4): model=37 (Teensy 4.1)
08:53:17.003 (reboot 4): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:16C0:04D0.001F
08:53:17.003 (reboot 4): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:17.003 (reboot 4): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:16C0:04D0.001F/hidraw/hidraw3
08:53:17.003 (reboot 4): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1
08:53:17.003 (reboot 4): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1/0003:16C0:04D0.0020
08:53:17.004 (reboot 4): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1/0003:16C0:04D0.0020/hidraw/hidraw6
08:53:17.004 (reboot 4): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:17.004 (reboot 4): devnode=/dev/hidraw6, subsystem=hidraw, ifacenum=1
08:53:17.004 (reboot 4): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2
08:53:17.004 (reboot 4): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:16C0:04D0.0021
08:53:17.005 (reboot 4): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:16C0:04D0.0021/hidraw/hidraw7
08:53:17.005 (reboot 4): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:17.020 (reboot 4): found Teensy Loader, version 1.54
08:53:17.020 (reboot 4): Sending command: show:arduino_attempt_reboot
08:53:17.049 (loader): remote cmd from 9: "show:arduino_attempt_reboot"
08:53:17.049 (loader): got request to show arduino rebooting message
08:53:17.052 (reboot 4): Sending command: comment: Teensyduino 1.54-beta6 - LINUX64 (teensy_reboot)
08:53:17.053 (loader): remote cmd from 9: "comment: Teensyduino 1.54-beta6 - LINUX64 (teensy_reboot)"
08:53:17.053 (loader): remote cmd from 9: "status"
08:53:17.115 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:17.115 (reboot 4): hid_send_feature, opened /dev/hidraw6
08:53:17.115 (reboot 4): error sending reboot command to /dev/hidraw6
08:53:17.115 (loader): remote cmd from 9: "status"
08:53:17.213 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:17.213 (reboot 4): status read, retry 0
08:53:17.313 (loader): remote cmd from 9: "status"
08:53:17.375 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:17.375 (reboot 4): status read, retry 1
08:53:17.501 (loader): remote cmd from 9: "status"
08:53:17.554 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:17.554 (reboot 4): status read, retry 2
08:53:17.654 (loader): remote cmd from 9: "status"
08:53:17.716 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:17.716 (reboot 4): status read, retry 3
08:53:17.817 (loader): remote cmd from 9: "status"
08:53:17.877 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:17.877 (reboot 4): status read, retry 4
08:53:18.028 (loader): remote cmd from 9: "status"
08:53:18.084 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:18.084 (reboot 4): status read, retry 5
08:53:18.184 (loader): remote cmd from 9: "status"
08:53:18.244 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:18.244 (reboot 4): status read, retry 6
08:53:18.345 (loader): remote cmd from 9: "status"
08:53:18.409 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:18.409 (reboot 4): status read, retry 7
08:53:18.558 (loader): remote cmd from 9: "status"
08:53:18.612 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:18.612 (reboot 4): status read, retry 8
08:53:18.712 (loader): remote cmd from 9: "status"
08:53:18.775 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:18.775 (reboot 4): status read, retry 9
08:53:18.875 (loader): remote cmd from 9: "status"
08:53:18.938 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:18.938 (reboot 4): status read, retry 10
08:53:19.088 (loader): remote cmd from 9: "status"
08:53:19.143 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:19.143 (reboot 4): status read, retry 11
08:53:19.243 (loader): remote cmd from 9: "status"
08:53:19.306 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:19.306 (reboot 4): status read, retry 12
08:53:19.406 (loader): remote cmd from 9: "status"
08:53:19.470 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:19.470 (reboot 4): status read, retry 13
08:53:19.622 (loader): remote cmd from 9: "status"
08:53:19.677 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:19.677 (reboot 4): status read, retry 14
08:53:19.777 (loader): remote cmd from 9: "status"
08:53:19.840 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:19.840 (reboot 4): status read, retry 15
08:53:19.940 (loader): remote cmd from 9: "status"
08:53:20.002 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:20.002 (reboot 4): status read, retry 16
08:53:20.151 (loader): remote cmd from 9: "status"
08:53:20.205 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:20.205 (reboot 4): status read, retry 17
08:53:20.305 (loader): remote cmd from 9: "status"
08:53:20.367 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:20.367 (reboot 4): status read, retry 18
08:53:20.468 (loader): remote cmd from 9: "status"
08:53:20.532 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:20.532 (reboot 4): status read, retry 19
08:53:20.679 (loader): remote cmd from 9: "status"
08:53:20.734 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:20.734 (reboot 4): status read, retry 20
08:53:20.835 (loader): remote cmd from 9: "status"
08:53:20.897 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:20.897 (reboot 4): status read, retry 21
08:53:20.998 (loader): remote cmd from 9: "status"
08:53:21.059 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:21.059 (reboot 4): status read, retry 22
08:53:21.210 (loader): remote cmd from 9: "status"
08:53:21.265 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:21.265 (reboot 4): status read, retry 23
08:53:21.365 (loader): remote cmd from 9: "status"
08:53:21.426 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:21.426 (reboot 4): status read, retry 24
08:53:21.526 (loader): remote cmd from 9: "status"
08:53:21.587 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:21.587 (reboot 4): status read, retry 25
08:53:21.737 (loader): remote cmd from 9: "status"
08:53:21.791 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:21.791 (reboot 4): status read, retry 26
08:53:21.892 (loader): remote cmd from 9: "status"
08:53:21.954 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:21.954 (reboot 4): status read, retry 27
08:53:22.054 (loader): remote cmd from 9: "status"
08:53:22.114 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:22.114 (reboot 4): status read, retry 28
08:53:22.266 (loader): remote cmd from 9: "status"
08:53:22.321 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:22.321 (reboot 4): status read, retry 29
08:53:22.421 (loader): remote cmd from 9: "status"
08:53:22.482 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:22.482 (reboot 4): status read, retry 30
08:53:22.582 (loader): remote cmd from 9: "status"
08:53:22.644 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:22.644 (reboot 4): status read, retry 31
08:53:22.798 (loader): remote cmd from 9: "status"
08:53:22.854 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:22.854 (reboot 4): status read, retry 32
08:53:22.954 (loader): remote cmd from 9: "status"
08:53:23.014 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:23.014 (reboot 4): status read, retry 33
08:53:23.115 (loader): remote cmd from 9: "status"
08:53:23.176 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:23.176 (reboot 4): status read, retry 34
08:53:23.328 (loader): remote cmd from 9: "status"
08:53:23.384 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:23.384 (reboot 4): status read, retry 35
08:53:23.484 (loader): remote cmd from 9: "status"
08:53:23.547 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:23.547 (reboot 4): status read, retry 36
08:53:23.648 (loader): remote cmd from 9: "status"
08:53:23.710 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:23.710 (reboot 4): status read, retry 37
08:53:23.865 (loader): remote cmd from 9: "status"
08:53:23.923 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:23.923 (reboot 4): status read, retry 38
08:53:24.023 (loader): remote cmd from 9: "status"
08:53:24.084 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:24.084 (reboot 4): status read, retry 39
08:53:24.184 (loader): remote cmd from 9: "status"
08:53:24.245 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:24.245 (reboot 4): status read, retry 40
08:53:24.398 (loader): remote cmd from 9: "status"
08:53:24.455 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:24.455 (reboot 4): status read, retry 41
08:53:24.555 (loader): remote cmd from 9: "status"
08:53:24.618 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:24.618 (reboot 4): status read, retry 42
08:53:24.718 (loader): remote cmd from 9: "status"
08:53:24.781 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:24.781 (reboot 4): status read, retry 43
08:53:24.931 (loader): remote cmd from 9: "status"
08:53:24.988 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:24.988 (reboot 4): status read, retry 44
08:53:25.088 (loader): remote cmd from 9: "status"
08:53:25.150 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:25.150 (reboot 4): status read, retry 45
08:53:25.251 (loader): remote cmd from 9: "status"
08:53:25.313 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:25.313 (reboot 4): status read, retry 46
08:53:25.463 (loader): remote cmd from 9: "status"
08:53:25.520 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:25.520 (reboot 4): status read, retry 47
08:53:25.620 (loader): remote cmd from 9: "status"
08:53:25.683 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:25.683 (reboot 4): status read, retry 48
08:53:25.783 (loader): remote cmd from 9: "status"
08:53:25.845 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:25.845 (reboot 4): status read, retry 49
08:53:25.993 (loader): remote cmd from 9: "status"
08:53:26.047 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:26.047 (reboot 4): status read, retry 50
08:53:26.148 (loader): remote cmd from 9: "status"
08:53:26.209 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:26.209 (reboot 4): status read, retry 51
08:53:26.310 (loader): remote cmd from 9: "status"
08:53:26.373 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:26.373 (reboot 4): status read, retry 52
08:53:26.521 (loader): remote cmd from 9: "status"
08:53:26.575 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:26.575 (reboot 4): status read, retry 53
08:53:26.675 (loader): remote cmd from 9: "status"
08:53:26.737 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:26.737 (reboot 4): status read, retry 54
08:53:26.838 (loader): remote cmd from 9: "status"
08:53:26.899 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:26.899 (reboot 4): status read, retry 55
08:53:27.048 (loader): remote cmd from 9: "status"
08:53:27.102 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:27.102 (reboot 4): status read, retry 56
08:53:27.202 (loader): remote cmd from 9: "status"
08:53:27.264 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:27.264 (reboot 4): status read, retry 57
08:53:27.264 (loader): Verbose Info event
08:53:27.364 (loader): remote cmd from 9: "status"
08:53:27.424 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:27.424 (reboot 4): status read, retry 58
08:53:27.573 (loader): remote cmd from 9: "status"
08:53:27.628 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:27.628 (reboot 4): status read, retry 59
08:53:27.728 (loader): remote cmd from 9: "status"
08:53:27.794 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:27.794 (reboot 4): status read, retry 60
08:53:27.894 (loader): remote cmd from 9: "status"
08:53:27.962 (reboot 4): Status: 1, 1, 0, 0, 0, 0, /tmp/arduino_build_803802/, Simple.pde.hex
08:53:27.962 (reboot 4): status read, retry 61
08:53:28.062 (reboot 4): Teensy did not respond to a USB-based request to automatically reboot.
08:53:28.066 (serialmon 5): Begin, version=1.54-beta6
08:53:28.066 (serialmon 5): listening for location: /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:28.115 (loader): remote connection 10 opened
08:53:28.119 (serialmon 5): add device: subsys=usb, type=usb_device, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:28.119 (serialmon 5): devnode=/dev/bus/usb/001/022, subsystem=usb, ifacenum=-1
08:53:28.119 (serialmon 5): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0
08:53:28.119 (serialmon 5): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:28.119 (serialmon 5): model=37 (Teensy 4.1)
08:53:28.119 (serialmon 5): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:16C0:04D0.001F
08:53:28.119 (serialmon 5): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:16C0:04D0.001F/hidraw/hidraw3
08:53:28.119 (serialmon 5): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1
08:53:28.120 (serialmon 5): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1/0003:16C0:04D0.0020
08:53:28.120 (serialmon 5): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:28.120 (serialmon 5): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1/0003:16C0:04D0.0020/hidraw/hidraw6
08:53:28.120 (serialmon 5): devnode=/dev/hidraw6, subsystem=hidraw, ifacenum=1
08:53:28.120 (serialmon 5): can't open /dev/hidraw6
08:53:28.120 (serialmon 5): add child: subsys=usb, type=usb_interface, location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2
08:53:28.120 (serialmon 5): add child: subsys=hid, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:16C0:04D0.0021
08:53:28.121 (serialmon 5): add child: subsys=hidraw, type=(null), location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:16C0:04D0.0021/hidraw/hidraw7
08:53:28.121 (serialmon 5): parent location=/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1
08:53:28.121 (serialmon 5): can't open /dev/hidraw6
08:53:28.149 (loader): remote connection 9 closed
kurt@kurt-XPS-8300:~/github/MTP_t4$ dmesg | tail -30
[13974.148621] usb 1-1.4.1: USB disconnect, device number 19
[14011.490461] usb 1-1.4.1: new high-speed USB device number 20 using ehci-pci
[14011.599328] usb 1-1.4.1: New USB device found, idVendor=16c0, idProduct=04d0, bcdDevice= 2.80
[14011.599331] usb 1-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14011.599333] usb 1-1.4.1: Product: Keyboard
[14011.599335] usb 1-1.4.1: Manufacturer: Teensyduino
[14011.599336] usb 1-1.4.1: SerialNumber: 8597440
[14011.600652] input: Teensyduino Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:16C0:04D0.001B/input/input30
[14011.658750] hid-generic 0003:16C0:04D0.001B: input,hidraw3: USB HID v1.11 Keyboard [Teensyduino Keyboard] on usb-0000:00:1a.0-1.4.1/input0
[14011.659613] hid-generic 0003:16C0:04D0.001C: hidraw6: USB HID v1.11 Device [Teensyduino Keyboard] on usb-0000:00:1a.0-1.4.1/input1
[14011.660534] input: Teensyduino Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:16C0:04D0.001D/input/input31
[14011.718936] hid-generic 0003:16C0:04D0.001D: input,hidraw7: USB HID v1.11 Device [Teensyduino Keyboard] on usb-0000:00:1a.0-1.4.1/input2
[14016.644287] usb 1-1.4.1: USB disconnect, device number 20
[14017.066497] usb 1-1.4.1: new high-speed USB device number 21 using ehci-pci
[14017.175062] usb 1-1.4.1: New USB device found, idVendor=16c0, idProduct=0478, bcdDevice= 1.05
[14017.175064] usb 1-1.4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[14017.175065] usb 1-1.4.1: SerialNumber: 000D1E60
[14017.176116] hid-generic 0003:16C0:0478.001E: hidraw3: USB HID v1.11 Device [HID 16c0:0478] on usb-0000:00:1a.0-1.4.1/input0
[14017.924217] usb 1-1.4.1: USB disconnect, device number 21
[14018.402487] usb 1-1.4.1: new high-speed USB device number 22 using ehci-pci
[14018.511403] usb 1-1.4.1: New USB device found, idVendor=16c0, idProduct=04d0, bcdDevice= 2.80
[14018.511415] usb 1-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14018.511417] usb 1-1.4.1: Product: Keyboard
[14018.511418] usb 1-1.4.1: Manufacturer: Teensyduino
[14018.511420] usb 1-1.4.1: SerialNumber: 8597440
[14018.512697] input: Teensyduino Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:16C0:04D0.001F/input/input32
[14018.570961] hid-generic 0003:16C0:04D0.001F: input,hidraw3: USB HID v1.11 Keyboard [Teensyduino Keyboard] on usb-0000:00:1a.0-1.4.1/input0
[14018.571952] hid-generic 0003:16C0:04D0.0020: hidraw6: USB HID v1.11 Device [Teensyduino Keyboard] on usb-0000:00:1a.0-1.4.1/input1
[14018.572979] input: Teensyduino Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.2/0003:16C0:04D0.0021/input/input33
[14018.630920] hid-generic 0003:16C0:04D0.0021: input,hidraw7: USB HID v1.11 Device [Teensyduino Keyboard] on usb-0000:00:1a.0-1.4.1/input2
Hi Paul,
could you please take a look at usb_dec.h?
I think the config for USB_MTPDISK_SERIAL is wrong. My Lubuntu (dmesg) says:
If have modified it to :Code:[ 58.300446] usb 1-1: new high-speed USB device number 2 using ehci-pci [COLOR=#ff0000][ 58.659302] usb 1-1: config 1 has an invalid interface number: 3 but max is 2[/COLOR] [COLOR=#ff0000][ 58.659305] usb 1-1: config 1 has no interface number 0[/COLOR] [ 58.673878] usb 1-1: New USB device found, idVendor=16c0, idProduct=0476 [ 58.673881] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 58.673883] usb 1-1: Product: Teensy MTP Disk/Serial [ 58.673884] usb 1-1: Manufacturer: Teensyduino [ 58.673885] usb 1-1: SerialNumber: 7820070 [ 58.690544] cdc_acm 1-1:1.1: ttyACM0: USB ACM device [ 58.693345] usbcore: registered new interface driver cdc_acm [ 58.693346] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [COLOR=#000000][ 98.089536] usb 1-1: USB disconnect, device number 2[/COLOR] [ 98.130423] cdc_acm 1-1:1.1: failed to set dtr/rts
Now, Linux seems to be happy, but I'm not entirly sure, that it is correct now.Code:#define VENDOR_ID 0x16C0 #define PRODUCT_ID 0x0476 //fake an include everything device #define RAWHID_USAGE_PAGE 0xFFAB // recommended: 0xFF00 to 0xFFFF #define RAWHID_USAGE 0x0200 // recommended: 0x0100 to 0xFFFF #define DEVICE_CLASS 0xEF #define DEVICE_SUBCLASS 0x02 #define DEVICE_PROTOCOL 0x01 #define MANUFACTURER_NAME {'T','e','e','n','s','y','d','u','i','n','o'} #define MANUFACTURER_NAME_LEN 11 #define PRODUCT_NAME {'T','e','e','n','s','y',' ','M','T','P',' ','D','i','s','k','/','S','e','r','i','a','l'} #define PRODUCT_NAME_LEN 22 #define EP0_SIZE 64 #define NUM_INTERFACE 3 #define NUM_ENDPOINTS 5 #define CDC_IAD_DESCRIPTOR 1 //1 #define CDC_STATUS_INTERFACE 0 //1 #define CDC_DATA_INTERFACE 1 // Serial //2 #define CDC_ACM_ENDPOINT 2 //2 #define CDC_RX_ENDPOINT 3 //3 #define CDC_TX_ENDPOINT 3 //3 #define CDC_ACM_SIZE 16 #define CDC_RX_SIZE_480 512 #define CDC_TX_SIZE_480 512 #define CDC_RX_SIZE_12 64 #define CDC_TX_SIZE_12 64 #define ENDPOINT2_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT #define ENDPOINT3_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK #define MTP_INTERFACE 2 // MTP Disk #define MTP_TX_ENDPOINT 4 #define MTP_RX_ENDPOINT 4 #define MTP_EVENT_ENDPOINT 5 #define MTP_TX_SIZE_480 512 #define MTP_RX_SIZE_480 512 #define MTP_TX_SIZE_12 64 #define MTP_RX_SIZE_12 64 #define MTP_EVENT_SIZE 32 #define MTP_EVENT_INTERVAL_12 10 // 10 = 10 ms #define MTP_EVENT_INTERVAL_480 7 // 7 = 8 ms #define ENDPOINT4_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK #define ENDPOINT5_CONFIG ENDPOINT_RECEIVE_INTERRUPT + ENDPOINT_TRANSMIT_INTERRUPT // ????
Thank you!
Edit: After a while, it continous to write:
Not sure, if this is normal.Code:cdc_acm 1-1:1.1: failed to set dtr/rts
Then, lsusb needs a long time (several seconds) to display the verbose info for the Teensy (tested with USB_MTPDISK_SERIAL only) and sometimes fails to prints the strings (serial-no, manufacturer etc)
Code:kurt@kurt-XPS-8300:~/github/MTP_t4$ dmesg | tail -30 [...] [14017.066497] usb 1-1.4.1: new high-speed USB device number 21 using ehci-pci [14017.175062] usb 1-1.4.1: New USB device found, idVendor=16c0, idProduct=0478, bcdDevice= 1.05 [14017.175064] usb 1-1.4.1: New USB device strings: [COLOR=#ff0000]Mfr=0, Product=0, SerialNumber=1[/COLOR] [14017.175065] usb 1-1.4.1: SerialNumber: [COLOR=#ff0000]000D1E60[/COLOR] [14017.176116] hid-generic 0003:16C0:0478.001E: hidraw3: USB HID v1.11 Device [HID 16c0:0478] on usb-0000:00:1a.0-1.4.1/input0
Frank,
I will take a look. I believe this is not stuff in the current build, but stuff you added in from @WMXZ files in the MTP_t4 project?
Created: 10/02/2021 17:42:50
Author: DESKTOP-KBCLAD0\Richard
#include <FreqCount.h>
void myDelay(int milliseconds) {
long time_end = millis() + milliseconds;
while (millis() < time_end) {}
Serial.begin(57600);
Serial.println("Hello....");
FreqCount.begin(100); // Gate time in uSec.
unsigned long count;
if (FreqCount.available()) {
count = FreqCount.read();
Serial.println(count); // Display the measured frequency
/* Displayed frequency shows the gate time is NOT
set by <FreqCount.begin(100)> but DOES correspond
with the interval set by myDelay()
Ex : 10MHz input should show 100 * 10 = 1000
Actual value is 17000139
Comment out the call to myDelay() and all is well.
// This delay simulate a lot of other things happening in real app.
myDelay(1700); // Strange delay time makes malfunction obvious.
I've taken it from Michael Meissners post here:
https://forum.pjrc.com/threads/43050-MTP-Responder-Contribution?p=269604&viewfull=1#post269604
#elif defined(USB_MTPDISK_SERIAL)
#define EP0_SIZE 64
#define ENDPOINT5_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT // ????
teensy41.menu.usb.mtpserial=MTP Disk Serial (Experimental)
teensy41.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
teensy40.menu.usb.mtpserial=MTP Disk Serial (Experimental)
teensy40.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
teensy36.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
teensy36.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
teensy35.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
teensy35.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
teensy31.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
teensy31.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
void listDir(fs::FS &fs, const char * dirname, uint8_t levels);
SD_FS_test:8: error: variable or field 'listDir' declared void
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
SD_FS_test:8: error: 'fs' has not been declared
SD_FS_test:8: error: 'fs' was not declared in this scope
SD_FS_test:8: error: expected primary-expression before 'const'
SD_FS_test:8: error: expected primary-expression before 'levels'
Used: /Applications/Teensyduino_1_54_Beta_6.app/Contents/Java/hardware/teensy/avr/libraries/SD
Not used: /Applications/Teensyduino_1_54_Beta_6.app/Contents/Java/libraries/SD
Multiple libraries were found for "SdFat.h"
Used: /Applications/Teensyduino_1_54_Beta_6.app/Contents/Java/hardware/teensy/avr/libraries/SdFat
Not used: /Users/louis/Dropbox/Dev/Arduino/libraries/SdFat_-_Adafruit_Fork
Using library SD at version 2.0.0 in folder: /Applications/Teensyduino_1_54_Beta_6.app/Contents/Java/hardware/teensy/avr/libraries/SD
Using library SdFat at version 2.0.5-beta.1 in folder: /Applications/Teensyduino_1_54_Beta_6.app/Contents/Java/hardware/teensy/avr/libraries/SdFat
Using library SPI at version 1.0 in folder: /Applications/Teensyduino_1_54_Beta_6.app/Contents/Java/hardware/teensy/avr/libraries/SPI
#include <FS.h>
#define SD_CS BUILTIN_SDCARD
//#define SD_CS 5
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if(!root){
Serial.println("Failed to open directory");
return;
if(!root.isDirectory()){
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while(file){
if(file.isDirectory()){
Serial.print(" DIR : ");
Serial.println(file.name());
if(levels){
listDir(fs, file.name(), levels -1);
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
if (SD_CS >= 0) {
pinMode(SD_CS, OUTPUT);
// initialize the SD card at full speed
if (!SD.begin(SD_CS)) {
Serial.println("Card Mount Failed");
while(1);
listDir(SD, "/", 0);
fs::FS &fs
FS &fs
wondering has anyone had any luck with Ubuntu 20.04 with USB Types that include SEREMU to have the Arduino Terminal Monitor?
I don't know. The only Ubuntu 20 issue on my radar is the problem you found with ARM64 on Raspberry Pi. Are there threads where people have reported problems on normal x86 Ubuntu 20?
I'm still on Ubuntu 18 here, but considering updating to 20 soon. Maybe it's time....
Hm I thought I try the Teensy LC audio again.. something seems to be broken with the current code from Beta6.
Maybe? First off you might try running a simple keyboard test (I commented out the outputs to keyboard ...) and see if it work there...
Note: code I ran in #29
uint8_t randomByte(void);
uint16_t randomWord(void);
uint8_t EntropyClass::randomByte(void)
return random8();
uint16_t EntropyClass::randomWord(void)
return random16();
#include <RH_NRF24.h>
const char compileTime [] = " Compiled on " __DATE__ " " __TIME__;
// Singleton instance of the radio driver
RH_NRF24 nrf24;
// RH_NRF24 nrf24(8, 7); // use this to be electrically compatible with Mirf
// RH_NRF24 nrf24(8, 10);// For Leonardo, need explicit SS pin
// RH_NRF24 nrf24(8, 7); // For RFM73 on Anarduino Mini
delay(400);
Serial.printf("NRF_24 Server %s\n", compileTime);
if (!nrf24.init())
Serial.println("init failed");
// Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
if (!nrf24.setChannel(1))
Serial.println("setChannel failed");
if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
Serial.println("setRF failed");
