//EEPROM_I2C_Write Use to create EEPROM contents
// writes are always in groups of 5-bytes * 25 repeats
// last 3-bytes on page are left un-programmed
// p6 is page pointer
// P5 is address on page pointer
static void EEPROM_I2C_Write(uint8_t regAddr, uint8_t *val, uint16_t cnt)
uint16_t i=0;
Serial.print(regAddr, HEX);Serial.print(" "); // gsl1680 register address (start)
p2=(p6*128) + p5; // calculate byte address
Serial.print("Page Address: "); Serial.println(p2);
Wire.beginTransmission(eeprom); // slave address
Wire.write((p2 & 0x0000ff00) >> 8); // byte address high
Wire.write(p2 & 0x000000ff); // byte address low
Wire.write(regAddr); // page register (0xF0) or data register 4-bytes 0
for(i=0;i<cnt;i++,val++) // 4-bytes of page/register data
Wire.write( *val ); // value // page or register data 4-bytes
Serial.print( *val, HEX );Serial.print(" "); // gls1680 register data
uint8_t retVal = Wire.endTransmission();
delay(10); // write delay time 10mS
p5=p5+5;
if (p5>=125) {p5=0; p6=p6 + 1;}
Serial.println(" ");
// sends firmware to GSLx680 chip
void eepromXfer() {
// Serial.println("EEPROM Transfer.");
for (p6=0; p6 < 692; p6++) { // read 692 * 125 = 86500 bytes something less than 2048 + 128 = 262144 bytes
p2 = (p6 * 128);
// Serial.print("READ addr: "); Serial.println(p6, HEX);
Wire.write((p2 & 0x0000ff00) >> 8); // address high byte
Wire.write(p2 & 0x000000ff); // address low byte
for (p5=0; p5<25; p5++) { // read only 125 bytes of 128 bytes (groups of 5)
Wire.requestFrom(eeprom, 5); // read 5-bytes
if (Wire.available() >= 1) { // slave address (no stop sent)
p0=Wire.read(); // Serial.print(p0, HEX); Serial.print(" ");
p3=Wire.read(); // Serial.print(p3, HEX); Serial.print(" ");
p7=Wire.read(); // Serial.print(p7, HEX); Serial.print(" ");
p8=Wire.read(); // Serial.print(p8, HEX); Serial.print(" ");
p9=Wire.read(); // Serial.print(p9, HEX); Serial.print(" ");
// Serial.println(" ");
p4 = Wire.endTransmission();
Wire.beginTransmission(addr);
Wire.write(p0);
Wire.write(p3);
Wire.write(p7);
Wire.write(p8);
Wire.write(p9);
} // end p5 for loop
p5=0;
} // end p6 loop
} // end eepromXfer
